Re: tips for tightening pinion nut 742
[Re: Exit1965]
#2459450
03/01/18 04:13 PM
03/01/18 04:13 PM
Posts: 960 Chicago
PurpleBeeper
Chicago
I saw somebody on FBBO that welded up a tool to do this. Basically, it's a metal plate, maybe 5"x6"or so with holes drilled into it that line up with the pinion yoke. It also had a large hole cut in the center to allow access to the pinion bolt.
That plate is welded to a 3ft. bar. You use the rear u-joint bolts (or u-bolts) to bolt to the plate, lift the car slightly so you can get under it, torque (or impact) the pinion bolt & the long bar hits the ground so the rear yoke can't turn.
I've never seen one for sale, just this home-built one.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: Exit1965]
#2459451
03/01/18 04:16 PM
03/01/18 04:16 PM
Posts: 2,885 Pattison Texas
CSK
Pattison Texas
Do not put the car on ramps & tighten the nut, sounds VERY dangerous, I use an impact when in your situation.
[Re: Exit1965]
#2459495
03/01/18 05:55 PM
03/01/18 05:55 PM
Posts: 2,086 CA
crackedback
CA
[Re: crackedback]
#2459504
03/01/18 06:16 PM
03/01/18 06:16 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I get the whole car up on stands. Put a large pipe on the handle of a big pipe wrench placed on the yolk. Spin it against the floor. Now you can tighten the yolk nut. Nice tool above, same concept applied.
I have mechanical Aptitude. I can screw up anything.
[Re: stumpy]
#2459614
03/01/18 09:59 PM
03/01/18 09:59 PM
Posts: 7,664 IN
ahy
IN
Nope. The pipe wrench clamps over the square ear of the yoke from the side so you have square bite to square ear. You could use an adjustable wrench if you had one big enough. I have used this technique also. Little to no damage and any small marks from the pipe wrench are cosmetic.
[Re: CSK]
#2459739
03/02/18 01:21 AM
03/02/18 01:21 AM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Do not put the car on ramps & tighten the nut, sounds VERY dangerous, I use an impact when in your situation. Set the parking brake, and block the tires.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: 62maxwgn]
#2459776
03/02/18 03:39 AM
03/02/18 03:39 AM
Posts: 2,746 541 slobovia
A990
541 slobovia
Lucky enough to have the real thing. Cool! Is the other end for axle end play?
[Re: A990]
#2459850
03/02/18 11:34 AM
03/02/18 11:34 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Lucky enough to have the real thing. Cool! Is the other end for axle end play? Yep !
[Re: stumpy]
#2459860
03/02/18 12:15 PM
03/02/18 12:15 PM
Posts: 10,782 North Dakota
6PakBee
North Dakota
A lot of us don't have the stuff to make a very nice tool like that. I don't know. One of my friends was setting up a Ford 9" and it would have been a real show without a tool like that. We took a piece of 1/4" scrap plate, cut the hole with a holesaw, drilled the yoke pattern and welded a piece of square tube for a handle. Took us about 25 minutes start to finish with stuff that I would guess 75% of the members have in their shop/garage. ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
