WHAT PRIMARY PIPE ARE YOU USING. #2459777
03/02/18 03:49 AM
03/02/18 03:49 AM
Australia
aus370 Offline OP
aus370  Offline OP
Australia
On your 600 hp Plus G3 Hemis, What primary pipe size are you using.
Re: WHAT PRIMARY PIPE ARE YOU USING. [Re: aus370] #2459886
03/02/18 01:12 PM
03/02/18 01:12 PM
Bowling Green, KY
BlakDak71 Offline
BlakDak71  Offline
Bowling Green, KY
2"
Re: WHAT PRIMARY PIPE ARE YOU USING. [Re: aus370] #2459999
03/02/18 05:17 PM
03/02/18 05:17 PM
Mesa, AZ
cagebob1 Offline
cagebob1  Offline
Mesa, AZ
my headers are 1 7/8 step to 2". engine dynoed at 695hp
Re: WHAT PRIMARY PIPE ARE YOU USING. [Re: aus370] #2460754
03/04/18 07:36 AM
03/04/18 07:36 AM
Australia
aus370 Offline OP
aus370  Offline OP
Australia
I knew it , my 1 3/4's are too small , Damn it ! .
Re: WHAT PRIMARY PIPE ARE YOU USING. [Re: aus370] #2460756
03/04/18 07:53 AM
03/04/18 07:53 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I make 600hp to the crank in my 426 Gen3 and run 1-3/4" headers
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: WHAT PRIMARY PIPE ARE YOU USING. [Re: aus370] #2460766
03/04/18 10:08 AM
03/04/18 10:08 AM
Australia
aus370 Offline OP
aus370  Offline OP
Australia
Now that's what i want to hear RylisPro lol's , it'd be interesting to see your dyno print out .
A while back i purchased the PipeMax software to figure out what to make for a stock 6.1 ( nothing available in right hand drive ) 1 3/4 worked out good for mid range tq and upper rpm hp .
Now when i type in the numbers for more Cubes , rpm , cam , valve sizes . PipeMax comes up with 1 7/8 - 2 1/8 .
just seeing what real results people have .
Re: WHAT PRIMARY PIPE ARE YOU USING. [Re: aus370] #2460870
03/04/18 01:44 PM
03/04/18 01:44 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: WHAT PRIMARY PIPE ARE YOU USING. [Re: aus370] #2461363
03/05/18 09:35 AM
03/05/18 09:35 AM
Australia
aus370 Offline OP
aus370  Offline OP
Australia
Ha you'd cut a good lap just leaving it in top gear . that's an eagle intake ? , what's your cam
Re: WHAT PRIMARY PIPE ARE YOU USING. [Re: aus370] #2461445
03/05/18 01:24 PM
03/05/18 01:24 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
My 6th gear is .63 only good for saving gas
Yes, Eagle intake. Just a small cam
Gross lift .584I/.552E
Dur@.5 229I/236E
Lobe sep 110
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
