Page 2 of 4 1 2 3 4
Re: Getting mixed feelings on Penn Grade Oil [Re: Chuck@Best_Machine] #2458497
02/27/18 05:58 PM
02/27/18 05:58 PM
Utah, USA
1964superstock Offline
Utah, USA
Originally Posted By Chuck@Best_Machine
We stopped using BP years ago. A lot of the Engines that come in for freshen ups that run BP have worn rocker shafts and Piston Pins. We only use Driven Brand Oil, every Big Block we Dyno has BR50 in it. In a lot of our high HP Drag engine we use XP3 after dyno but in most cases the HR series oil is a good choice. We use the 15/50 in our bracket style engines.
Thanks for this info. What oil grade do you recommend for a street strip 505 440 stroker big block, using a solid flat tappet cam, 259/263 @ 050. My 505 engine dyno'd at 620 HP, fun street car. Would you still recommend 15w-50 Driven Engine Oil like bracket type engines, or use 10w-30 or 10w-40 instead? My 505 stroker had really high oil pressure last time I used Brad Penn 20w-50 oil, so I switched to straight 30W Brad Penn. Reading all this makes me a little leary of using BP oil any longer. Your recommendation is appreciated. Thanks.
Re: Getting mixed feelings on Penn Grade Oil [Re: 6PKRTSE] #2458500
02/27/18 06:01 PM
02/27/18 06:01 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
Originally Posted By 6PKRTSE
Many of my buddies run Brad Penn. The stuff feels slippery & doesn't like to come off of your skin but I have never been a fan either for the money. I just run whatever brand oil 10W30 is on sale at that moment when I am in the parts store. Never had an issue with any of them.
At work we just run 10W30 conventional in all of our crate engines & for the race engines we use the Rotella 15W40 Diesel oil.
Don't you know that Rotella is diesel oil for low rpm and not formulated for a race engine...... rolleyes
LOL, we ran Rotella for years in a SB Chevy motor that got flogged relentlessly running 6.0 index classes. Always looked great at teardown.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Getting mixed feelings on Penn Grade Oil [Re: Sammy] #2458503
02/27/18 06:06 PM
02/27/18 06:06 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Well Lucas oil is a huge oil brand in the trucking and Heavy Highway equipment world and then they branched off into all forms of racing - they have marketing money to burn due to their size - they even have the naming rights to a the colts stadium in Indy. I starting using their hot rod oil in my coronet - seems to work pretty good and maintains pressure better than the Valvoline I used to run - I have not tried anything thing else from them. In the race engines we have switched to the Driven oil (AKA the former Joe Gibbs oil)
Re: Getting mixed feelings on Penn Grade Oil [Re: an8sec70cuda] #2458535
02/27/18 07:11 PM
02/27/18 07:11 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Originally Posted By an8sec70cuda
... Rotella is diesel oil for low rpm and not formulated for a race engine...
Chip, you can roll your eyes all you want, but there is truth to that statement. And what's being sold for diesel oil today isn't the same as it was 5-10 years ago when older blends of Rotella, etc., were a lot of people's go-to oil even for performance gas engines.
* Diesel oils don't generally contain the anti-foaming additives that are found in oils intended for higher RPM applications. I can't say at what point those really come into play, but there's got to a be a reason why certain oils have them and others don't.
* Diesel oils have a much higher ratio of detergents to anti-wear additives. The issue here is those extra detergents are scrubbing away the anti-wear components instead of letting them adhere to the metal surfaces they're intended to protect.
I'm perfectly OK w/ anyone running what works for them. However, there are functional differences between diesel oils and performance gasoline engine oils that I believe people should at least be aware of.
Carry on! grin
Re: Getting mixed feelings on Penn Grade Oil [Re: Sammy] #2458537
02/27/18 07:15 PM
02/27/18 07:15 PM
Like you said Brad, even though a lot of folks will tell you it's wrong and won't work...in reality, it works great.
CHIP
Re: Getting mixed feelings on Penn Grade Oil [Re: Sammy] #2458551
02/27/18 07:54 PM
02/27/18 07:54 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
I ran Wal-Mart special in all of my dirt motors.. Never had an oil related issue. Buddy running same class always used the highest dollar crap he could find. No discernable difference in bearings/wear on teardown.
I've used BP, VR1, Diesel oil (old stock "better" oil, additives, etc w A lowly 440 and burn cups and pushrods every 700 miles or so. Pretty !@$!$!$@ frustrating
Fwiw, best oil I've used is a special formulation a local shop had a semilocal refinery brew for them. Shop went out of business and I only have 2 gallons left.
The shop was building alot of USMTS mod motors. Oil seemed/seems like good stuff.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Getting mixed feelings on Penn Grade Oil [Re: Von] #2458561
02/27/18 08:29 PM
02/27/18 08:29 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Most of us old time racers kinda have our minds made up especially if we do our own work and engine building. But if you see something you don’t like you better be open minded enough to switch brands. Off topic but for years I was a type F transmission fluid user then 15-18 years ago my transmission builder said to use Walmart type III. Well last year a had a bad transmission issue unrelated to the fluid type and I switched back to type F because of the smell the Walmart brand had. It smelled burnt to me right out of the bottle. I now have a sorse to get type F and do my own transmissions so that will be my fluid now.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Getting mixed feelings on Penn Grade Oil [Re: Sammy] #2458578
02/27/18 09:28 PM
02/27/18 09:28 PM
AndyF Offline
AndyF  Offline
I've tried most of the race oils and these days I just use Mobil 1 that I get at Walmart for $4 a quart.
The engine shop I work with uses the Joe Gibbs break in oil on all engines but after break in I switch to 5w-30 Mobil 1.
Re: Getting mixed feelings on Penn Grade Oil [Re: Sammy] #2458580
02/27/18 09:31 PM
02/27/18 09:31 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Due to the endorsements here, I would like to switch to the Driven HR 10-40. Any chance there will be a vendor at the Indy show this weekend?
Master, again and still
Re: Getting mixed feelings on Penn Grade Oil [Re: DaveRS23] #2458747
02/28/18 10:51 AM
02/28/18 10:51 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
speedway will ship you driven by the case
www.SPEEDWAYMOTORS.COM
Part # 910038071
Tried posting the link but .. won't allow it for some odd reason
7.99 a quart
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Getting mixed feelings on Penn Grade Oil [Re: bigdad] #2458777
02/28/18 12:08 PM
02/28/18 12:08 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
WOW! Looks like HR 10-40 is on sale now for $7.25 a qt. And says free shipping after $99.
I'm in. Thanks for the link.
Re: Getting mixed feelings on Penn Grade Oil [Re: Sammy] #2458782
02/28/18 12:20 PM
02/28/18 12:20 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I buy a lot from them, 1 day service for me
Re: Getting mixed feelings on Penn Grade Oil [Re: fast68plymouth] #2459216
03/01/18 01:33 AM
03/01/18 01:33 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Originally Posted By fast68plymouth
Plenty of other choices if you're not comfortable with the Penn Grade stuff.
Driven
Red Line
Royal Purple
Torco
Champion
Lucas
To name a few
IIRC in the past you’ve mentioned guys running lower viscosity than 10w40 have had trouble in tear downs you’ve seen. Appears several here have mentioned 5w30. Could this be an issue and changing brands after an issue crops up isn’t going to solve it?
I want my fair share
Re: Getting mixed feelings on Penn Grade Oil [Re: SomeCarGuy] #2459449
03/01/18 04:12 PM
03/01/18 04:12 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Driven
Red Line
Royal Purple
Torco
Champion
Lucas
To name a few
I've run some 5x30 Valvoline syn. or Mobile-1 syn. through my stuff a few times and no issues at tear downs but usually stick to a 10x30 w/.0025+ rod and .003+ mains street/strip mid 9 second car............... thumbs
Re: Getting mixed feelings on Penn Grade Oil [Re: Thumperdart] #2459531
03/01/18 06:45 PM
03/01/18 06:45 PM
tboomer Online work
tboomer  Online Work
I find this interesting...For years people were all goo-goo eyed over Brad Penn oil...Now it isn't any good? Amazing..I have just enough for my spring oil change. Is the Wix racing oil filter junk now too? confused
Re: Getting mixed feelings on Penn Grade Oil [Re: tboomer] #2459537
03/01/18 06:53 PM
03/01/18 06:53 PM
PA.
"Little"John
"Little"John
PA.
If you are scared Ted please send it to me. I can get rid of those Wix filters for you too buddy.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Getting mixed feelings on Penn Grade Oil [Re: tboomer] #2459538
03/01/18 06:54 PM
03/01/18 06:54 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
From what I understand from reading on other sites out there on the web their under new ownership and the formula has been changed (cheaper maybe) shruggy
Have always been a Brad Penn user but last year I switched to VR-1 just because I got a case for a tip from one of my customers.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Getting mixed feelings on Penn Grade Oil [Re: pittsburghracer] #2459540
03/01/18 06:59 PM
03/01/18 06:59 PM
tboomer Online work
tboomer  Online Work
I can put it in the car and send it out to ya..... whistling
Re: Getting mixed feelings on Penn Grade Oil [Re: tboomer] #2459541
03/01/18 07:04 PM
03/01/18 07:04 PM
PA.
"Little"John
"Little"John
PA.
Pour it into one of those USPS flat rate boxes. LOL
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Getting mixed feelings on Penn Grade Oil [Re: pittsburghracer] #2459542
03/01/18 07:06 PM
03/01/18 07:06 PM
tboomer Online work
tboomer  Online Work
OK...Anything but UPS...United Package Smashers...
Page 2 of 4 1 2 3 4
