Re: Getting mixed feelings on Penn Grade Oil
[Re: Sammy]
#2457898
02/26/18 03:26 PM
02/26/18 03:26 PM
Posts: 4,457 Washington
madscientist
Washington
Very few oils are the cause of engine issues. I've never used Brad Penn but I have a hard time believing the oil is an issue, unless they are using the wrong oil for the application.
Most of the boutique oil manufacturers make 7-8 different oils in many many grades. Could be they are using the incorrect oil for the job.
[Re: Sammy]
#2457899
02/26/18 03:28 PM
02/26/18 03:28 PM
fast68plymouth
So. Burlington, Vt.
Plenty of other choices if you're not comfortable with the Penn Grade stuff.
Driven Red Line Royal Purple Torco Champion Lucas
To name a few
[Re: fast68plymouth]
#2457904
02/26/18 03:34 PM
02/26/18 03:34 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
To name a few Driven oil was recommended to me now from a reputable source thanks
[Re: Sammy]
#2457917
02/26/18 04:07 PM
02/26/18 04:07 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
I'm planning on ditching the Brad Penn for this...... http://www.schaefferoil.com/racing.htmlI had heard the Brad Penn has changed a bit since the company was sold. Can't verify this though.
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: Sammy]
#2457928
02/26/18 04:23 PM
02/26/18 04:23 PM
Posts: 13,386 Marion, South Carolina [><]
an8sec70cuda
LOL, all the while there are tons of engines making big power on parts store bought Valvoline, Mobil One, etc.
[Re: Sammy]
#2457960
02/26/18 05:32 PM
02/26/18 05:32 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
Lucas hot rod oil is the best stuff i have ever used. Easily
[Re: Sammy]
#2458058
02/26/18 08:32 PM
02/26/18 08:32 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I stopped using Brad Penn oil, and went to Schaeffers and Driven. Thats all I am going to say.
RIP Monte Smith
[Re: CompWedgeEngines]
#2458060
02/26/18 08:38 PM
02/26/18 08:38 PM
Sammy
Wind Gap,Pa.
I stopped using Brad Penn oil, and went to Schaeffers and Driven. Thats all I am going to say. Which Driven oil, theres a few different types. I'm thinking 5W30
[Re: Chuck@Best_Machine]
#2458332
02/27/18 12:56 PM
02/27/18 12:56 PM
Posts: 4,580 Motor City
6PKRTSE
Motor City
Many of my buddies run Brad Penn. The stuff feels slippery & doesn't like to come off of your skin but I have never been a fan either for the money. I just run whatever brand oil 10W30 is on sale at that moment when I am in the parts store. Never had an issue with any of them.
At work we just run 10W30 conventional in all of our crate engines & for the race engines we use the Rotella 15W40 Diesel oil.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 70satelliteguy]
#2458381
02/27/18 02:03 PM
02/27/18 02:03 PM
Posts: 1,070 Big Western Pencilveinya
Uncle Barry
"Many of my buddies run Brad Penn. The stuff feels slippery & doesn't like to come off of your skin but I have never been a fan either for the money. I just run whatever brand oil 10W30 is on sale at that moment when I am in the parts store. Never had an issue with any of them.
" for the race engines we use the Rotella 15W40 Rotella Diesel oil."
Agree with all of the above!!
Mike I run the same but also put some Lucas break in additive with it at each oil change.
#2458400
02/27/18 02:35 PM
02/27/18 02:35 PM
BradH
I stopped using Brad Penn oil, and went to Schaeffers and Driven. Thats all I am going to say. Considering you used to be one of the Brad Penn proponents, that a significant statement even without any further comments.
[Re: Sammy]
#2458405
02/27/18 02:41 PM
02/27/18 02:41 PM
BradH
I heard Brad Penn had a tendency to burn pushed tips same with Royal Purple Racing 21 oil. I heard it causes hemorrhoids, too, but do my best to filter out a lot of "static" I hear. We broke in my engine on "legacy" Brad Penn 30 break-in, but I've got 7 quarts of Driven Hot Rod 10w40 conventional ready to replace it when I drain the pan. There's also some Amsoil on my oil shelf that will get used if/when I decide to start using synthetics, again.
[Re: B3422W5]
#2458411
02/27/18 02:48 PM
02/27/18 02:48 PM
BradH
Lucas hot rod oil is the best stuff i have ever used. Easily My issue w/ Lucas, and it could be completely irrational, is that I suspect their Marketing Dept has as much influence on what goes into their oils as their Engineering Dept. Have you seen some of the ZDDP #s they put in some of their oils? They are waaaaay off the "reasonable amount" scale and jumping right into the "too much of anything is NOT a good thing" range. It also appeared for quite a while that Lucas must have been giving sh!tloads of free product (or buying sh!tloads of advertising) to all the major magazines -- at least the ones that are left -- since virtually every dyno test article they ran used Lucas oil. I'll pass, thanks.
[Re: BradH]
#2458447
02/27/18 04:06 PM
02/27/18 04:06 PM
B3422W5
Portage,michigan
Lucas hot rod oil is the best stuff i have ever used. Easily My issue w/ Lucas, and it could be completely irrational, is that I suspect their Marketing Dept has as much influence on what goes into their oils as their Engineering Dept. Have you seen some of the ZDDP #s they put in some of their oils? They are waaaaay off the "reasonable amount" scale and jumping right into the "too much of anything is NOT a good thing" range. It also appeared for quite a while that Lucas must have been giving sh!tloads of free product (or buying sh!tloads of advertising) to all the major magazines -- at least the ones that are left -- since virtually every dyno test article they ran used Lucas oil. I'll pass, thanks. Your right.... lol...... might be completely irrational I love the stuff, read lot of reviews from guys who have been using it a few years. Great on cold startups after car has sat, clings really well
