Re: fuel priming bulb for car that sits often? [Re: Mopar72Man] #2460068
03/02/18 07:45 PM
03/02/18 07:45 PM
I would like to be able to prime the edelbrock with fuel but don't particularly want to deal with an electronic pump of any sort.
that's what I'd do (k.i.s.s.) remove the lid & squirt some raw fuel in there.
Re: fuel priming bulb for car that sits often? [Re: Mopar72Man] #2460292
03/03/18 01:27 AM
03/03/18 01:27 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Don't just poor gas down it's throat. Unless you are a big "Garage Squad" fan. shock If you are going to remove the air cleaner every time you might as well fill the fuel bowls through the vents until it has a pump shot...
Re: fuel priming bulb for car that sits often? [Re: Dave Hall] #2460373
03/03/18 09:47 AM
03/03/18 09:47 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
i dont believe thats easily done on an edelbrock
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: fuel priming bulb for car that sits often? [Re: Mopar72Man] #2460481
03/03/18 02:04 PM
03/03/18 02:04 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
I have one that starts once a month, I just crank it to get the oil pressure up..by then the gas is there and it starts..
Re: fuel priming bulb for car that sits often? [Re: Dave Hall] #2460577
03/03/18 06:53 PM
03/03/18 06:53 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Give me a break.
What do you think the accelerator pump does when you step on the peddle?
Where's the emergency?
shruggy
I have mechanical Aptitude.
I can screw up anything.
Re: fuel priming bulb for car that sits often? [Re: bboogieart] #2475271
04/01/18 12:28 PM
04/01/18 12:28 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Give me a break.
shruggy
Pouring raw fuel down the throat, letting the fuel run down into the cylinder walls, opening the door, cranking the ignition key. It may not be the end of the world but it is definitely not the better way to do this.
Filling the bowl, replacing air filter, squirt the accelerator pedal the minimum amount to start the car and probably less than a second later crank and fire.
Re: fuel priming bulb for car that sits often? [Re: Sixpak] #2476238
04/02/18 06:46 PM
04/02/18 06:46 PM
Virginia's Eastern Shore
dmoore Offline
dmoore  Offline
Originally Posted By Sixpak
Electric Fuel pump...git 'er done! Anyone running a carter avs knows if it sits a while the bowls dry right out. Takes 10 cranks or so to get enough fuel into the carb if the car sits more than a few days, especially with today's alcohol-laced swill...
Thermoquad's are REAL BAD for this. And I use ethanol free 91
Re: fuel priming bulb for car that sits often? [Re: dmoore] #2476467
04/02/18 09:37 PM
04/02/18 09:37 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I use a squirt bottle to fill the bowls through the vent on car without an electric pump.
Gus beer
64 Plymouth Savoy
Dana 60
Re: fuel priming bulb for car that sits often? [Re: Magnum] #2476773
04/03/18 02:26 PM
04/03/18 02:26 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
OK I'm still missing something here.
You step on the pedal to set the choke, what happens?
The pump squirts gas into the carb.
Turn the key, Engine starts.
So...
Dump a small amount of gas down the throat, hit key, start the car.
Maybe I should have said leave the door open to get at the key quicker? shruggy
Re: fuel priming bulb for car that sits often? [Re: Mopar72Man] #2476793
04/03/18 03:03 PM
04/03/18 03:03 PM
Magnum Offline
Magnum  Offline
You are missing nothing bboogie. If you are capable of a pouring the proper amount of fuel down the throat of your engine. This will work and obviousy has.
I just trying to protect the others who don't understand that too much fuel is bad for the cylinder walls. Visions of tilting a jerry can and watching fuel flow down the throat.So my advice was just another way to do it.
Re: fuel priming bulb for car that sits often? [Re: Magnum] #2476805
04/03/18 03:31 PM
04/03/18 03:31 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Ok I get that.
Guess I was assuming too much.
We all know what the werd assume means. grin
