Re: Will factory 440 block survive for very long at 800 HP level [Re: BigHemiVegas] #2456429
02/24/18 12:30 AM
02/24/18 12:30 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
I have split one through the mains and up into the bores mixing the water and oil, that was with a 440-528 and my 200 hp shot poor tune. That was about 8 years ago, I have not run the bottle since, we live and learn.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Will factory 440 block survive for very long at 800 HP level [Re: BigHemiVegas] #2456468
02/24/18 01:38 AM
02/24/18 01:38 AM
Stockholm, Sweden
TomsCharger70 Offline
Stockholm, Sweden
My 496cid (440 block) makes 770Hp N/A. Dont have a girdle, but used aluminium main caps, studs, etc.. for the build. RPM at the finish line is about 6800RPM. I probably have about 50-60 something 1/4mile runs on the engine so far. Like many have already posted, I guess its just a matter of time untill it implodes...
/Tom
Re: Will factory 440 block survive for very long at 800 HP level [Re: ozymaxwedge] #2456527
02/24/18 04:34 AM
02/24/18 04:34 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Quitter! I don't care how many parts I sacrifice to the god of speed, they will pry that nitrous button from my cold dead fingers!
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Will factory 440 block survive for very long at 800 HP level [Re: MoparBilly] #2456529
02/24/18 05:08 AM
02/24/18 05:08 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Originally Posted By MoparBilly
Quitter!
Hahahahaha You go hard Billy, I'll go aftermarket block and procharger one day, after I rob the bank.
1971 Barracuda
Re: Will factory 440 block survive for very long at 800 HP level [Re: BigHemiVegas] #2456607
02/24/18 12:26 PM
02/24/18 12:26 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Keep those positive comments coming. NOT!!!!
Boffin Emeritus
Re: Will factory 440 block survive for very long at 800 HP level [Re: EchoSixMike] #2456610
02/24/18 12:31 PM
02/24/18 12:31 PM
moparx Online content
moparx  Online Content
Originally Posted By EchoSixMike
they dampen vibration and add rigidity, the same reasons as with fixturing machine parts. Vibration=chatter and broken tooling. S/F....Ken M
the same type of guys wonder why you can't machine a 50lb. chunk of steel on your "atlas bench top" lathe, are in wonder when the chunk flies out of the chuck when the tooling grabs.....
beer
Re: Will factory 440 block survive for very long at 800 HP level [Re: BigHemiVegas] #2456648
02/24/18 01:56 PM
02/24/18 01:56 PM
Portland, Oregon
Digger73 Offline
Digger73  Offline
Portland, Oregon
Not mine and I don't remember where I found it but here it is for your viewing pleasure.
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
Re: Will factory 440 block survive for very long at 800 HP level [Re: Digger73] #2456726
02/24/18 04:11 PM
02/24/18 04:11 PM
When it comes to decision making on race parts or hot street car parts I always think of the worst case scenario, do I really want to run over the engine parts above 100 MPH work
Not me now tsk Been there done that way to many times realcrazy
Be safe, buy good parts and pray they don't fail at speed that can hurt you and the car work
Re: Will factory 440 block survive for very long at 800 HP level [Re: BigHemiVegas] #2456731
02/24/18 04:23 PM
02/24/18 04:23 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I prefer to use the best parts I can that are up to the task, or even overkill for what we are doing. Properly put together, maintained, kept fresh, and hopefully, live a long productive life. I'm definitely not in the "build, run it till it blows, rinse, repeat" crowd. I'm weird like that.
Re: Will factory 440 block survive for very long at 800 HP level [Re: CMcAllister] #2456744
02/24/18 04:38 PM
02/24/18 04:38 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
You are not alone...
Re: Will factory 440 block survive for very long at 800 HP level [Re: BigHemiVegas] #2456786
02/24/18 05:24 PM
02/24/18 05:24 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Made 1400HP in a 440 block about 35 times. Decided not to blow it up and swapped shortblocks.
Re: Will factory 440 block survive for very long at 800 HP level [Re: CMcAllister] #2456895
02/24/18 07:41 PM
02/24/18 07:41 PM
Mo.
racerx Offline
racerx  Offline
Mo.
iagree this is how I think also.
Re: Will factory 440 block survive for very long at 800 HP level [Re: racerx] #2456980
02/24/18 10:35 PM
02/24/18 10:35 PM
N.Y.
sixpacksteve Offline
N.Y.
650-700 HP. looks like the limit. others did better, others Not so much!
take the advice. if not good luck. Remember you can only become a millionaire in Drag racing if you start out as a Billionaire!
Hell Hath No Fury Like Mine
Re: Will factory 440 block survive for very long at 800 HP level [Re: BigHemiVegas] #2457213
02/25/18 11:34 AM
02/25/18 11:34 AM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
That aluminum rod motor with the block window looks familiar. I have a pretty cool mailbox post now made from a crank.
Re: Will factory 440 block survive for very long at 800 HP level [Re: BigHemiVegas] #2457286
02/25/18 01:46 PM
02/25/18 01:46 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Race engines are disposable anyway right? If you GOT to have 800 hp, pay the price.
Re: Will factory 440 block survive for very long at 800 HP level [Re: BigHemiVegas] #2457418
02/25/18 06:32 PM
02/25/18 06:32 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine broke at about 200 passes, 6500 max, aluminum caps. Dynoed at 657hp. Took the crank, 4 rods/pistons, 8 push rods and valves.
Doug
Re: Will factory 440 block survive for very long at 800 HP level [Re: dvw] #2457432
02/25/18 06:55 PM
02/25/18 06:55 PM
PA
Harry's Taxi 2 Offline
PA
Doug
What cubic inch? cyl.heads?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
