Re: KB solid block for bracket racing
[Re: rick4106]
#2454694
02/20/18 06:16 PM
02/20/18 06:16 PM
Posts: 1,049 San Jose Ca.
boatracer572
San Jose Ca.
Anyone using a Solid KB block for bracket racing? I have a solid kb block, it's no problem in my world running 40 degree lake water through to heads, I will tell you the oil temp comes up quickly, wouldent recomend a solid block for bracket racing on asphalt
[Re: rick4106]
#2455091
02/21/18 02:38 PM
02/21/18 02:38 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
I just cannot see in a bracket situation where it would be a good idea. Especially on gasoline. Better get a HUGE oil cooler with an equally HUGE fan and figure out someway to circulate the oil between rounds. HP makes heat so if you are making any you are going to make some really warm oil especially late in the day when you get into quick turn arounds. Look no farther that what Tony is saying, he has access to unlimited COLD water to run through the engine and sees oil temps come up quick
[Re: cudaman1969]
#2455712
02/22/18 05:15 PM
02/22/18 05:15 PM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Don't the pro mods and pro stocks run billet blocks now? About as solid as you can get. Two TOTALLY different classes. In bracket racing you better be able to run the number all day and be ready for "round robin"
[Re: rick4106]
#2455746
02/22/18 06:47 PM
02/22/18 06:47 PM
Posts: 11,714 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Pro Stock still runs radiators and iron blocks. Pro Mods are making stupid boost and horsepower and need the strength. A 3/4 fill block still has water at the hottest part of the cylinder and they will show higher oil temps. Between rounds maintenance routines are a little different between Pro cars and a guy running a 7 round bracket race on Saturday night.
[Re: merpar]
#2721009
12/02/19 09:04 PM
12/02/19 09:04 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
how are you circulating water through the heads with the solid block?
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: HOTMOPR]
#2721021
12/02/19 10:02 PM
12/02/19 10:02 PM
Posts: 43,307 Bend,OR USA
Cab_Burge
how are you circulating water through the heads with the solid block? Add fittings on each end of both heads and make it work ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) I know some racer with solid blocks that use the cold water from their intercoolers to cool the heads after a run ![wrench wrench](/ubbthreads/images/graemlins/custom/wrench.gif)
[Re: Cab_Burge]
#2721023
12/02/19 10:09 PM
12/02/19 10:09 PM
HOTMOPR
Oakville, Wa
That's what I was thinking but wasn't sure. Thanks
