Page 1 of 3 1 2 3
who runs torque straps, limiters? #2454592
02/20/18 03:32 PM
02/20/18 03:32 PM
midwest
superchuck Offline OP
On thin ice
On thin ice
midwest
I don't have time to fabricate solid motor mounts or install elephant ears. I'd like to get by this year with a limiter on the driver side of the motor. I like to go from the head to the drivers side frame rail, but worry about adding a shear load to the head bolts. Where ya'll put yours?
Re: who runs torque straps, limiters? [Re: superchuck] #2454599
02/20/18 03:41 PM
02/20/18 03:41 PM
I've used torque straps forever to save the left motor mount when foot braking and on stick shift cars, even used chains with a turn buckle for a little while shruggy work
I used the power steering boss on the water pump to bolt to the 1/4x1 inch wide strap to the left front sub frames, my current street car, ex drag race car, has a piece of aluminum 1x1x.085 aluminum angle on it that worked well also up
Re: who runs torque straps, limiters? [Re: superchuck] #2454623
02/20/18 04:03 PM
02/20/18 04:03 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Yup, good location; accessory bolt locations on front of head are also good. I've used either one depending on engine for years without an issue.
If you use a rigid strut kind of strap, you'll probably notice a little added vibration transmitted, but it's never bothered me.
Re: who runs torque straps, limiters? [Re: superchuck] #2454641
02/20/18 04:40 PM
02/20/18 04:40 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
The torque strap that schumacher sells is a nice piece.
68 Barracuda Formula S 340
Re: who runs torque straps, limiters? [Re: superchuck] #2454655
02/20/18 05:05 PM
02/20/18 05:05 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
The old trick is to use a rubber mount on the left side and use what is essentially half of a motor plate and call it a strap.
Re: who runs torque straps, limiters? [Re: superchuck] #2454659
02/20/18 05:13 PM
02/20/18 05:13 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have a chain on mine but have thought about buying a set of Poly Locks, but man they are expensive!
Re: who runs torque straps, limiters? [Re: Bad340fish] #2454671
02/20/18 05:41 PM
02/20/18 05:41 PM
an8sec70cuda Offline
iagree
CHIP
'06 GMC 2500HD LBZ Duramax
Re: who runs torque straps, limiters? [Re: an8sec70cuda] #2454678
02/20/18 05:55 PM
02/20/18 05:55 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I use the Schumacher piece as well.
Easy to install and very clean looking.
My Early B has a habit of tearing the drivers side in half!
'63 Dodge 330
11.19 @ 121 mph
Re: who runs torque straps, limiters? [Re: superchuck] #2454696
02/20/18 06:22 PM
02/20/18 06:22 PM
St Louis, MO, USA
srunge55 Offline
srunge55  Offline
St Louis, MO, USA
I'm trying to figure out the best way to do this also. I have heard of some guys using a solid MM on the drivers side and a stock rubber on the passenger side.
I have also heard of using a regular MM but drilling and running a bolt through it. I think Mancini sells something called a mega mount which looks like the same thing. Seems like a simple cheap thing to do yourself but I haven't tried it yet.
Thanks,
Steve
Re: who runs torque straps, limiters? [Re: srunge55] #2454708
02/20/18 06:47 PM
02/20/18 06:47 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
This is what I made. 1/4” steel sandwiched between the isolator and mount
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: who runs torque straps, limiters? [Re: srunge55] #2454709
02/20/18 06:47 PM
02/20/18 06:47 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
A big part of using a strap or motorplate is to remove the stress and shock from the left side of the block where the mount is bolted. This would make it worse.
Re: who runs torque straps, limiters? [Re: CMcAllister] #2454712
02/20/18 06:50 PM
02/20/18 06:50 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Picture no work!
Re: who runs torque straps, limiters? [Re: superchuck] #2454815
02/20/18 10:45 PM
02/20/18 10:45 PM
Canada
onig Offline
onig  Offline
Canada
Just curious, but who has seen a block get damaged from a solid motor mount on the driver's side?
Our SB has the solid mount pushing about 650HP and still going strong.
69 Dart
Re: who runs torque straps, limiters? [Re: superchuck] #2454818
02/20/18 10:48 PM
02/20/18 10:48 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
A simple hardware store turn buckle will do just fine and not look too bad.
Master, again and still
Re: who runs torque straps, limiters? [Re: DaveRS23] #2454823
02/20/18 10:52 PM
02/20/18 10:52 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Another one...............
Re: who runs torque straps, limiters? [Re: DaveRS23] #2454857
02/20/18 11:47 PM
02/20/18 11:47 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I made my own with a piece of threaded rod and two heim ends with a piece of plastic tubing over the threaded rod. It goes from the bolt on the front of the head to the motor mount boss on the K frame. I was worried when i went from the W2 head engine to the 408 with Indy 360-1 heads that it would`t fit but it did in almost exactly the same place. Whats nice is that it is adjustable up or down if need be
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: who runs torque straps, limiters? [Re: GY3] #2454874
02/21/18 12:31 AM
02/21/18 12:31 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I just installed a Schumaker strap a few weeks ago. No drive time yet but I too was wondering if there can be any damage from bolting these onto the motor mount bracket hole. I assume the motor mount helps to support the block when mounting the strap at this location.
Re: who runs torque straps, limiters? [Re: superchuck] #2454878
02/21/18 12:51 AM
02/21/18 12:51 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Has anyone used the Shumacher Poly-Locs?
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: who runs torque straps, limiters? [Re: superchuck] #2454916
02/21/18 02:02 AM
02/21/18 02:02 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I run a Moroso solid mount on the driver side, stock mount on the pass side. I’ve heard people say that this could be hard on the block, But I’ve never seen someone’s block fail at the motor mount. I don’t make a lot of power either, so I think I’m safe.
Re: who runs torque straps, limiters? [Re: OhioMopar] #2454946
02/21/18 04:01 AM
02/21/18 04:01 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Yes the polylocs work good. The motor stays in place and does not shake like aftermarket junk. I have put them on several shaker hood cars to save the shaker, worth the money to stop damage. The strap is also nice, have one on my 340 4-speed, made shifting way better also.
Page 1 of 3 1 2 3
