Re: 340 Six Pack vacuum advance [Re: ademon] #2465634
03/13/18 04:39 AM
03/13/18 04:39 AM
Cab_Burge Online work
Cab_Burge  Online Work
Originally Posted By ademon
That's a high initial at 18* for a stock build, sure your throttle blades have enough of the transfer slot exposed???
There is no way I would ever make any carb. idle on the transfer circuit port, NEVER tsk
The idle circuit should and will control the idle mixture and RPM when set up properly up scope
Ultimately the AFR and amount of air allowed into the motor controls the RPM at idle or at WOT work twocents
OP, my 518 C.I. 400 block pump gas six pack stroker motor would idle at 850 RPM in gear and gain 100 to 150 RPM going from in gear to in neutral, all on the idle circuit with no vacuum advance with the timing set at 14 BTDC at idle and under 1200 RPM with a big solid roller race cam in it shruggy up It had a mix set of original 440 carbs. on that motor modded by C&J Engr, in Whittier, CA
It took a little work and time on my part to get it to work like that so you may need to try and test some different things on yours also up
You CAN do THIS up
Now, get to work whistling wrench grin
Re: 340 Six Pack vacuum advance [Re: Aar1064] #2465645
03/13/18 07:37 AM
03/13/18 07:37 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Try dropping your initial to 10 or 12, and resetting your idle.
