Re: Guess my Dyno numbers
[Re: 10sec440]
#2455059
02/21/18 01:33 PM
02/21/18 01:33 PM
Posts: 570 UK
rb446
UK
I can't see it making much more than 600fwhp, not enough head/small cam for them cubes to make mid to upper 600's in my opnion.
My mates 440 Dart with 12.7:1, Eddy std port MCH 325cfm heads, DC.590 solid purple cam, 1050 Dom., Victor int...just managed to hit the 600fwhp mark according to best mph/weight. and that cam was done at 6600rpm, car would slow if he shifted it over 6400 through the gears.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: 10sec440]
#2455074
02/21/18 01:56 PM
02/21/18 01:56 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The latest generation 440-1's come with CNC'd chambers, and with the right valve job and bowl work can flow quite well.
[Re: Von]
#2455087
02/21/18 02:27 PM
02/21/18 02:27 PM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
Whose dyno?? On a few dynos quoted on here, I'm sure it would show over 800...
LOL
[Re: fast68plymouth]
#2455107
02/21/18 03:09 PM
02/21/18 03:09 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
Do you have any of those #'s , I based my guess on older none ported 440-1's & the low lift cam.
[Re: 10sec440]
#2455122
02/21/18 03:41 PM
02/21/18 03:41 PM
fast68plymouth
So. Burlington, Vt.
For sure the low-ish lift of the cam(for this combo) doesn't play into the -1's attributes, especially earlier ones.
The last set I did(with cnc'd chambers) flowed 297@.600 ootb, and about 340@.600 after proper prep.
I feel like the 10.5cr is a bit low for the basic combo as well.
If the heads were similar to the last ones I did, and I had it on our dyno here, I'd be looking to be in the 650+ range........ It is a 511 after all. I'd have used 1.6 rockers for a cam like that in this type of build.
#2455125
02/21/18 03:53 PM
02/21/18 03:53 PM
CSK
Pattison Texas
Thanks Dwayne for your valuable input !!!
[Re: an8sec70cuda]
#2455134
02/21/18 04:05 PM
02/21/18 04:05 PM
Posts: 4,570 Motor City
6PKRTSE
Motor City
LOL We have (42) SAE calibrated engine dyno's. Our Dyno's have to be calibrated because of all of the OEM prototype developement & production work we do so our Dyno's are usually about 15% less than the average Joe. Believe me, you walk into most single dyno engine shops & say you want to make approx 800 HP they can make it make the number pretty easily when it is probably making more like 680ish HP.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 10sec440]
#2455147
02/21/18 04:24 PM
02/21/18 04:24 PM
Posts: 19,375 Las Vegas
Al_Alguire
Las Vegas
Cant see that combo being anything much over 600hp for sure of if it even got there. But as been pointed out dynos are dynos and not all of them spit out the most accurate of results for sure. Id say at Mountain View that combo would struggle to see 575, that's where I have my most recent dyno experience.
[Re: 10sec440]
#2455165
02/21/18 05:07 PM
02/21/18 05:07 PM
Posts: 570 UK
rb446
UK
I guess whatever numbers that dyno throws out, whats more important is knowing where the power is being made with the combo and then perhaps some gearing changes may/may not be in order.
As a guide, with an on track 620fwhp/3400lbs the ticket would look something like this> 60 Foot E.T. : 1.43 1/8 Mile E.T. : 6.48 1/8 Mile Trap Speed : 104.88 1/4 Mile E.T. : 10.27 1/4 Mile Trap Speed : 130 with it in the teens? if it 60's better than shown above. according to my calcs.
[Re: 10sec440]
#2455175
02/21/18 05:30 PM
02/21/18 05:30 PM
fast68plymouth
So. Burlington, Vt.
Since its a Comp cam, I'd be interested to know what the lobe numbers are....... And I assume you're running 1.5 rockers??
[Re: 10sec440]
#2455388
02/22/18 12:59 AM
02/22/18 12:59 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Sorry, typo it was late. 265 and 270 @ .050 I intend to spin it to 6500-7000. Thanks. Be lucky to break 600 hp, probably more like 575,??? That cam @ 265 intake is smaller them the MP 590 @ 271 @ .05 you were using. But with the new engine you will be making a lot of torque. To make HP you need to spin them a bit. Your not going to be able to spin that new engine very high in its hp band with that small of cam. It will be done by 6000 rpm. Typical 500" motors with your comp can hit around 600 HP with the mp 590, your using a even Smaller cam.
[Re: 10sec440]
#2455512
02/22/18 10:55 AM
02/22/18 10:55 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I am guessing your goal might be 10.01 et? Just a thought, has anyone had good luck with 1.7 ratio rockers and beehive springs? That would get you .630 + net lift on the intakes, and raise the net lift everywhere, which i would think should be well worth the trouble, and cheap power to boot.
[Re: 10sec440]
#2455585
02/22/18 01:46 PM
02/22/18 01:46 PM
fast68plymouth
So. Burlington, Vt.
I doubt the power increase from a ratio swap would corolate to the $1100 price tag.
If I had $1100 to throw at it, it would be on a roller cam, lifters, and springs.
[Re: 10sec440]
#2458469
02/27/18 05:02 PM
02/27/18 05:02 PM
fast68plymouth
So. Burlington, Vt.
With as widely varying as the guesses were.......someone should have been close.
#2458505
02/27/18 06:06 PM
02/27/18 06:06 PM
6PKRTSE
Motor City
We always do this at work with alot of the race engines we build. Sometimes it's $1.00 per person per guess, sometimes $5.00 per guess. Winner gets the pot. We did this on my Hemi when we dyno'd it. So many were so close but it did make more than everyone was expecting.
