Dana 60 housing questions #2453444
02/18/18 01:28 PM
02/18/18 01:28 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
I have a dana 60 car center casting with no tubes. Were there year to year differences in in this piece that would prevent it from being visually correct when re tubed? For example pinion snubber bolt pattern or drain plug area? Thanks Guys!
Re: Dana 60 housing questions [Re: crowbait] #2453507
02/18/18 04:02 PM
02/18/18 04:02 PM
CA
crackedback Offline
crackedback  Offline
CA
Drain plug might be about it.
Snubbers were the same patter throughout IIRC.
Re: Dana 60 housing questions [Re: crackedback] #2454188
02/19/18 10:41 PM
02/19/18 10:41 PM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
No drain plug on this one.
Re: Dana 60 housing questions [Re: crackedback] #2454260
02/19/18 11:32 PM
02/19/18 11:32 PM
Only Dana 60 made for Mopar cars had pinion snubbers, all the rest of them didn't shruggy
Dana Corp. made many different Dana 60 housings for cars and pickups shruggy The axle tubes , that I know of, range from 2.5 O.D. to 3.375 O.D shruggy
Re: Dana 60 housing questions [Re: crowbait] #2454290
02/20/18 12:08 AM
02/20/18 12:08 AM
Oly Wash
racerlall Offline
racerlall  Offline
Oly Wash
66 reinforcing ribs are different then later ones
Re: Dana 60 housing questions [Re: Cab_Burge] #2454572
02/20/18 02:59 PM
02/20/18 02:59 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have a 1 ton Dodge truck narrowed to fit in my Challenger with no pinion snubber mounting holes & it has the 3-3/8" dia. tubes.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Dana 60 housing questions [Re: crowbait] #2454661
02/20/18 05:14 PM
02/20/18 05:14 PM
CA
crackedback Offline
crackedback  Offline
CA
He mentioned he had a "car" center...
Re: Dana 60 housing questions [Re: crackedback] #2454843
02/20/18 11:32 PM
02/20/18 11:32 PM
You Sir are correct up
I see after rereading it blush
Re: Dana 60 housing questions [Re: Cab_Burge] #2454943
02/21/18 03:51 AM
02/21/18 03:51 AM
Brookville Pa
crowbait Offline OP
crowbait  Offline OP
Brookville Pa
Ok,tonight after work I threw it on the mill and drilled out all the plug welds(12 of em) then pressed out what was left of the tubes. It looks good at this point so tomorrow night I will throw it in the hot tank for a bath. I will probably order steel for the tubes yet this week.
Question...Who's housing ends accept the stock tapered bearing and grease seal?
Or should I look around for some used original ends?
I want to try and button up this housing project in the next week or so.
Re: Dana 60 housing questions [Re: crowbait] #2454965
02/21/18 05:24 AM
02/21/18 05:24 AM
If your going to abuse that rear end you might want to buy some thick chromemoly tubes for it.
I've used Moser 8 3/4 and Dana 60 passenger car ends on several truck Dana 60 housings for my hot rods with no problems, all of them had 35 spline axle with the green bearings though shruggy I'm almost positive that they will accept the stock wheel bearings also, regardless of the axle size or axle diameter up to 35 spline work Call Moser and ask them up scope
They are a little more costly than some of the other cheaper ends that Summit sells, but they are more than good enough for what I've done thumbs
Re: Dana 60 housing questions [Re: crowbait] #2455232
02/21/18 07:39 PM
02/21/18 07:39 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
Call Dr Diff or cut some ends off of an 8 3/4
Re: Dana 60 housing questions [Re: RV2] #2455964
02/23/18 02:07 AM
02/23/18 02:07 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
