Re: Time for a steering box sector support
[Re: BigBlockMopar]
#2454291
02/20/18 12:09 AM
02/20/18 12:09 AM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
Interesting observation. How many turns lock-to-clock do you have?
Also, with the Borgnson box, is the turning radius larger than before (when you had the factory box)?
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: BigBlockMopar]
#2456556
02/24/18 08:48 AM
02/24/18 08:48 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
Loctite might indeed be needed here but I recall I added lockwashers under (some of) the bolts earlier. Will have to check. I already had welded a simple support plate on the steeringbox mount. After this pic was taken I added another small plate to triangulate it more. The difference was noticable. Wider than stock, and modernday tires with added caster-adjustment put some more load on the steeringbox and K-member, which is mainly when any weaklinks in the setup start showing up.
[Re: BigBlockMopar]
#2456624
02/24/18 01:12 PM
02/24/18 01:12 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
Wider than stock, and modernday tires with added caster-adjustment put some more load on the steeringbox and K-member, which is mainly when any weaklinks in the setup start showing up. I'd ditch the lockwasher for Loctite exclusively. https://engineerdog.com/2015/01/11/10-tricks-engineers-need-to-know-about-fasteners/Also may need more support around the box mount. When I updated mine, I added three separate pieces around the mount in addition to grinding and redoing several of the stock welds.
