Re: Correct finish for leaf springs
[Re: ScottSmith_Harms]
#2453726
02/19/18 12:25 AM
02/19/18 12:25 AM
Posts: 140 Akron, ohio
76orangewagon
Akron, ohio
The black paint used on leaf springs was usually very thin. They were dipped as a completed unit all at once, are you sure they weren't painted black? Sure looks like little specs of black paint in your pics? Scott, When I stripped the top coat of Black paint off there was a heavy coat of White paint that looked brushed on, once I stripped that off it was bare metal, I see the specks of black your referring too but I assume those are left over paint on the white because there wasn't any large patches of OEM black visable. Were they always black ?
[Re: hemicar1971]
#2453835
02/19/18 11:26 AM
02/19/18 11:26 AM
76orangewagon
Akron, ohio
Likely a none axle package Cuda with an automatic. Close...its just a standard 3.23 S/G with a 4 speed.
[Re: autoxcuda]
#2453837
02/19/18 11:35 AM
02/19/18 11:35 AM
Posts: 892 MA
steve70
MA
Wonder if that white is pastel pink? Seen that color on them. Here's a couple pics of an original T/A's leaf springs
1970 Challenger T/A 4 speed
[Re: autoxcuda]
#2453838
02/19/18 11:36 AM
02/19/18 11:36 AM
76orangewagon
Akron, ohio
Wonder if that white is pastel pink? Seen that color on them. I will try to research that a little more I don't have the greatest original marks to go off of and had to up the saturation levels of the color to pull what I have out...I'm just happy I found something to use but I do want to accurately reapply them. I know it's not what the original post should be but does anyone have a better picture of what the paint marks should be ?
[Re: 76orangewagon]
#2454136
02/19/18 09:11 PM
02/19/18 09:11 PM
Posts: 29,652 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Evaporust can & will remove paint if the parts are left in too long.
Been there, done that.
So for marks / paint research, I learned to soak for an hour, check, photograph.
Check again in an hour, inspect, photograph, etc.
Repeat as needed.
The more rust removed, go with shorter times in between to soak, inspect & photograph.
It is amazing what details can be seen if caught at the right time.
Make sure that any parts are degreased first too, so the ER can work on the rust without fighting any residue.
[Re: 76orangewagon]
#2454163
02/19/18 10:08 PM
02/19/18 10:08 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Seymour's Stainless Steel paint (Doesn't hold-up...
[Re: 76orangewagon]
#2454451
02/20/18 10:51 AM
02/20/18 10:51 AM
Posts: 591 Pa
koak
Pa
Those weren't the OP's pics they were examples of black springs. There was someone on here who refinished "bare" springs using some gun bluing? They looked very nice and I would like to see them again with the process as I am planning on refinishing mine. Anyone? Ditto on the Seymoure's paint as well. Looks good, but I wouldn't use it unless on small brackets or with some serious primer underneath.
[Re: RSNOMO]
#2454464
02/20/18 11:31 AM
02/20/18 11:31 AM
Posts: 2,634 Nashville, TN
MOPARMIKE69
Nashville, TN
Seymour's Stainless Steel paint (Doesn't hold-up... Really? I have a road runner convertible I did the springs with this paint 20 years ago. They still look great.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
#2454635
02/20/18 04:20 PM
02/20/18 04:20 PM
Posts: 299 Hinckley, Ohio
KWF340
Hinckley, Ohio
Since they were painted as an assembly there will be very little black paint between the leaves. Either way, skip sand blasting them and soak them in a PVC pipe full of Evaporust. Once dipped any remaining black paint (if any) will be much easier to spot as the Evaporust won't remove it. Scrub off any remaining residue with a scotch brite pad and rinse them in thinner as opposed to water to clean up the residue. Once done you should have a nice natural bare steel. Originals that were unpainted had nothing on them, so anything you paint them with will be considered "wrong" at the O.E. level. If you don't care about that then there are tons of paint choices, use your eye to best match the natural color of the clean metal. .02 I agree. Instead of paint, before assembly I put RPM on on each leaf. They still look great after 2 years. BTW - I'm working on the set of springs I purchased from you back in November. Currently soaking in ER.
