Re: 1980 F-body disc brakes on a 1970 B-body. What swaps over? [Re: Alaskan_TA] #2452749
02/16/18 08:02 PM
02/16/18 08:02 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
Re: 1980 F-body disc brakes on a 1970 B-body. What swaps over? [Re: Alaskan_TA] #2452750
02/16/18 08:03 PM
02/16/18 08:03 PM
Hamtramck, PA
Alaskan_TA Offline OP
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
The car has 10" manual drums now.
A pal is selling a rusty 1980 F-body, but the brakes still work, so......
That is why I am asking.
I have already agreed to buy it, but the final price is flexible depending on what all I can use.
Re: 1980 F-body disc brakes on a 1970 B-body. What swaps over? [Re: Montclaire] #2452767
02/16/18 08:31 PM
02/16/18 08:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted By Montclaire
If you want the car to operate exactly the same but with unicast discs, then you need the 73-76 A-body or 73-74 E-body spindle, which is exactly the same height as what you have now.
And you keep saying they're readily available...maybe in your neighborhood, not mine.
Re: 1980 F-body disc brakes on a 1970 B-body. What swaps over? [Re: Alaskan_TA] #2452777
02/16/18 09:05 PM
02/16/18 09:05 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
you can use the spindles, just do the research so you get the right calipers and hoses (or just order them from doctor diff).
if your car has a factory sway bar then you want to mount the calipers to the rear, no sway bar or aftermarket, then you can front mount the calipers (swapping the spindles on each side) and the brake hose routing will be cleaner...
if the calipers on the donor car are good, you can just use all that stuff and mount the calipers on the rear like factory.
i would buy some firm feel upper control arms though so you can run more modern alignment specs since we aren't all driving on bias ply tires anymore like the cars were originally spec'd for...
Re: 1980 F-body disc brakes on a 1970 B-body. What swaps over? [Re: Alaskan_TA] #2452806
02/16/18 09:54 PM
02/16/18 09:54 PM
CA
crackedback Offline
crackedback  Offline
CA
Go with the FMJ stuff, it will work fine.
I've done a bunch of cars with both A and FMJ stuff, none drove as through they were going to toss you off the road from bump steer.
One had about 50K miles on an FMJ swap when I sold it.
The scare mongers still exist from the article written in the 90's where IIRC, the author has said he'd never heard of a ball joint failure directly related to the additional spindle height. A friend ran the numbers and the additional angle at ball joint was 1.5* at both ends IIRC, 3* total through the swing. I'm pretty sure the ball joint tolerances were not built where an additional 1.5* was going to jam a stud to housing. This garbage is like a scary movie that isn't so scary... smile
Re: 1980 F-body disc brakes on a 1970 B-body. What swaps over? [Re: Alaskan_TA] #2452843
02/16/18 11:26 PM
02/16/18 11:26 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Barry
take the spindles and caliper adapters from the F body and lovingly install them on the B Body. Buy new rotors, calipers, bearings and seals from rock auto, get some carbon metallic brake pads from firm feel and never worry about stopping. Dr Diff for brake lines. The naysayers are misspoken about the geometry as the evil spindles actually improve the roll center of the vehicle. I did not invent this reality but this is from very smart people who have analyzed the geometry of the spindles and my practical experience of using the evil spindles to run many laps at warp speed at my favorite road course. Otay?
purple
Re: 1980 F-body disc brakes on a 1970 B-body. What swaps over? [Re: Alaskan_TA] #2452853
02/16/18 11:47 PM
02/16/18 11:47 PM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Got it.
Thanks again all. wave
I have an appointment to see the brakes in person in the morning.
Re: 1980 F-body disc brakes on a 1970 B-body. What swaps over? [Re: Alaskan_TA] #2452855
02/16/18 11:51 PM
02/16/18 11:51 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've done this swap many times. Yes the spindle is taller. But what does this impact? If you study front suspension geometry you can see. It raises the the upper ball joint. Actual measurement is close to 3/8". As the upper control arm is normally angled downward this raises it causing the top of the tire to tilt outward. Is this a bad thing? Not really. Now the rear cam can be moved inward adding positive caster without creating excessive negative camber. This similar to adding offset upper bushings to add positive caster. It gives more range of adjustment. My background? ASE Master tech, my specialty? Front suspension and body shop wrecks for over 30 years. Yes I've aligned plenty of them myself. I can tell you it works because I've tested it, not just theory. Dizusters 140 mph turbo 62 Savoy runs FMJ with no issue, I've made passes in it. No difference between it and my 150 mph 64 Belvedere that has the toe pattern optimized to .10 degree though out total travel.
Doug
Re: 1980 F-body disc brakes on a 1970 B-body. What swaps over? [Re: Alaskan_TA] #2452893
02/17/18 01:17 AM
02/17/18 01:17 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Thanks for the votes of confidence from everyone . . . I know from my experience, that this is a no brainer swap !! As mentioned, 10k miles of real world driving . . . go for it
Re: 1980 F-body disc brakes on a 1970 B-body. What swaps over? [Re: Alaskan_TA] #2452920
02/17/18 03:20 AM
02/17/18 03:20 AM
AndyF Offline
AndyF  Offline
F body knuckles on this car. It went 150+ mph at Portland International on the front straight and corners as well as the Vipers and Vettes.
Re: 1980 F-body disc brakes on a 1970 B-body. What swaps over? [Re: Alaskan_TA] #2453003
02/17/18 12:23 PM
02/17/18 12:23 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
I've had spindles from a '77 Volare on my '71 Charger for over 20 years. In that time, I've run them with stock control arms, CAP (now QA1) control arms, and, currently, CAP lower and Hotchkis upper control arms. I just used '73 Charger brake hoses.
Re: 1980 F-body disc brakes on a 1970 B-body. What swaps over? [Re: Montclaire] #2453013
02/17/18 01:06 PM
02/17/18 01:06 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
1980 F-body power disc brakes on a 1970 manual drum B-body chassis. What swaps over & what if any additional parts would be needed to convert them?
15" wheel car.
Thanks!
You need everything in between the ball joints.
Originally Posted By Twostick
Someone correct me if I'm wrong but I believe if you want to use 11.75 rotors you need B-body Cordoba caliper adapters too. These are available repopped from Dr Diff and others.
Kevin
True, but the 10.5 F body units are not too shabby for a cruiser.
The F-body spindles are not the correct height. They are taller and will skew the suspension geometry. You want 73-76 A-body or 73/74 E-body.
Uhhh, how long have you been on moparts? This topic has been beat to death on here every few years since the mid 1990s from every angle possible. Significant research has been done into it and for all intent, it is a non-issue for all but a few small minority.
Re: 1980 F-body disc brakes on a 1970 B-body. What swaps over? [Re: Alaskan_TA] #2453086
02/17/18 03:58 PM
02/17/18 03:58 PM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
OK, I went to look at the doner car. The entire brake system is complete.
The metering block is all there & the brakes do work.
So, I feel that we have the front discs covered, so what about adding the power booster setup?
Car is a manual brake car right now, so what would be needed to swap in the power goodies?
Thanks again!
Re: 1980 F-body disc brakes on a 1970 B-body. What swaps over? [Re: Alaskan_TA] #2453091
02/17/18 04:20 PM
02/17/18 04:20 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I swapped over the entire 1975 Dart booster, brackets, knuckles and everything to my 70 Charger in 2002. The Charger was a 4 wheel 10" drum car. I just attached the 75 Dart power brake pushrod from the Charger pedal to the booster. It all bolted in. Now, there were changes for the F body cars. The Dart had a standoff bracket that moved the booster away from the firewall. I'm not familiar with the F body booster mounting.
Re: 1980 F-body disc brakes on a 1970 B-body. What swaps over? [Re: Alaskan_TA] #2453105
02/17/18 04:56 PM
02/17/18 04:56 PM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
It will be at least two weeks before I can get the car here for a look at how the booster mounts, but here is a photo from the front.
Re: 1980 F-body disc brakes on a 1970 B-body. What swaps over? [Re: Alaskan_TA] #2453118
02/17/18 05:31 PM
02/17/18 05:31 PM
a12rag Offline
a12rag  Offline
My Sport Satellite was manual drum brake, and I left it "manual" when I went to disc brake . . . used the aluminum 2 bolt master cylinder with adapter. . . . no issue with brake pedal feeling "too" hard, works great without the power. . .
Re: 1980 F-body disc brakes on a 1970 B-body. What swaps over? [Re: Alaskan_TA] #2453128
02/17/18 05:45 PM
02/17/18 05:45 PM
Hamtramck, PA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
I want the power & a closer to stock appearance, just because.
(For my other 1970 B, I may have some cruise control questions for you in the future.)
Re: 1980 F-body disc brakes on a 1970 B-body. What swaps over? [Re: Alaskan_TA] #2453181
02/17/18 08:01 PM
02/17/18 08:01 PM
a12rag Offline
a12rag  Offline
no worries . . . ask away . . .
Re: 1980 F-body disc brakes on a 1970 B-body. What swaps over? [Re: Alaskan_TA] #2453446
02/18/18 01:34 PM
02/18/18 01:34 PM
moparx Online content
moparx  Online Content
one thing you may run into using the F-body booster is, it might be too big in diameter causing interference with ????. you may also have to modify the firewall hole and the booster mounting holes. with that said, i used a diplomat booster when i switched over to discs on my 64 belvedere. i believe it is real close to the diameter of the F-body. i had to enlarge the rod through hole, and drill two extra holes in the firewall to mount the booster. there wasn't anything in the way to cause interference, as this was a low option car. just some things to consider. and yes, i used the taller spindles with no issues what so ever. if anyone would read up on roll couple and handling issues, the taller spindles would be the ones they would only consider. remember, ALL factory suspension systems [with only a few exceptions such as sporty, handling types] are a COMPROMISE so the masses can "drive" the car without getting into trouble. the factory engineers spend big bucks on design as has been stated, but for "joe average" ONLY, not for hot rod or sports car guys like us. this does not in any way reflect on the latest stuff out there today, only the stuff available "back in the day".
beer
Re: 1980 F-body disc brakes on a 1970 B-body. What swaps over? [Re: Alaskan_TA] #2457938
02/26/18 04:50 PM
02/26/18 04:50 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
I did this swap about 15 years ago on a 67 Satellite. The only effect of the taller spindle is a little more camber gain as the suspension compresses.
The brake hose wants to be on the opposite side of the spindle so I fabbed up a bracket in the correct new location (such that the brake hose passes through the spindle pivot axis) and made a short section of hard line to connect from the new bracket to the old.
Worked great.
