Re: New season of Street Outlaws starting soon.
[Re: pittsburghracer]
#2451922
02/14/18 11:00 PM
02/14/18 11:00 PM
Posts: 8,794 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
This may have been covered before, it's been a long thread. But school me on the cost, Mopar vs. everyone else, to play the game. At a certain point, they aren't really a "brand" anymore, correct? If Big Chief can run an aftermarket Poncho block at 40-60 pounds boost and be competitive, there's no Mopar aftermarket block that will do the same thing? I just graduated from purple shaft cams and super stock springs to strokers, so I am only about 10-12 years behind the rest of the Mopar world. Oops. 20. I still have super stock springs.
1969 Dart GTS 340 1969 Coronet R/T X9 N-96 1999 Dodge Dakota R/T RC 2015 Dodge Dart GT 2019 Ram 2500 Big Horn
[Re: Dave Hall]
#2452031
02/15/18 06:03 AM
02/15/18 06:03 AM
OhioMopar
Mt.Gilead, Ohio
Depends on what you want to call a Mopar I guess...BAE, AJ and others have Chrysler based stuff but it's all $40K and above. So what is Chevy or Pontiac based stuff in relation? $39k and below? Like I said, is there really any "brand" left in any of that stuff?
[Re: OhioMopar]
#2452036
02/15/18 08:21 AM
02/15/18 08:21 AM
Posts: 3,698 jersey
Spaceman Spiff
jersey
Depends on what you want to call a Mopar I guess...BAE, AJ and others have Chrysler based stuff but it's all $40K and above. So what is Chevy or Pontiac based stuff in relation? $39k and below? Like I said, is there really any "brand" left in any of that stuff? Big Chiefs block, will accept all stock exterior components. Heads, oil pan, timingcover, water pump, etc. you aren’t going to be able to use a stock Chevy head on a pro line block, Or a BAE block.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: Spaceman Spiff]
#2452080
02/15/18 11:24 AM
02/15/18 11:24 AM
Posts: 4,169 Mo.
racerx
Mo.
Depends on what you want to call a Mopar I guess...BAE, AJ and others have Chrysler based stuff but it's all $40K and above. So what is Chevy or Pontiac based stuff in relation? $39k and below? Like I said, is there really any "brand" left in any of that stuff? Big Chiefs block, will accept all stock exterior components. Heads, oil pan, timingcover, water pump, etc. you aren’t going to be able to use a stock Chevy head on a pro line block, Or a BAE block. So would it be safe to say Big Chief has the only stock dimensional base (aftermarket) block on that show?
[Re: racerx]
#2452087
02/15/18 11:44 AM
02/15/18 11:44 AM
Posts: 3,698 jersey
Spaceman Spiff
jersey
Depends on what you want to call a Mopar I guess...BAE, AJ and others have Chrysler based stuff but it's all $40K and above. So what is Chevy or Pontiac based stuff in relation? $39k and below? Like I said, is there really any "brand" left in any of that stuff? Big Chiefs block, will accept all stock exterior components. Heads, oil pan, timingcover, water pump, etc. you aren’t going to be able to use a stock Chevy head on a pro line block, Or a BAE block. So would it be safe to say Big Chief has the only stock dimensional base (aftermarket) block on that show? Other than Shane’s Vega, I’d say yes.
[Re: racerx]
#2452093
02/15/18 12:05 PM
02/15/18 12:05 PM
Posts: 3,698 jersey
Spaceman Spiff
jersey
Depends on what you want to call a Mopar I guess...BAE, AJ and others have Chrysler based stuff but it's all $40K and above. So what is Chevy or Pontiac based stuff in relation? $39k and below? Like I said, is there really any "brand" left in any of that stuff? Big Chiefs block, will accept all stock exterior components. Heads, oil pan, timingcover, water pump, etc. you aren’t going to be able to use a stock Chevy head on a pro line block, Or a BAE block. So would it be safe to say Big Chief has the only stock dimensional base (aftermarket) block on that show? Chuck and Shane both have small block Chevys, from the brief glimpse I have seen, they both appear to be factory style blocks.
#2452188
02/15/18 03:20 PM
02/15/18 03:20 PM
Posts: 19,602 Las Vegas
Al_Alguire
Las Vegas
Ummmmm...The Fireball Camaro has a Hemi in it...
As for cost its simple. There are simply not enough Mopar people willing to spend the money it takes to compete at that level. The ones that do use BAE stuff and boost. We do have one here FastMop who I believe is working on a BAE combo as well. Just not enough people. Chief is an exception on the No Prep front running a Pontiac, he obviously is a diehard Pontiac guy. Could a Mopar guy do it, certainly can they just have to want it bad enough.
[Re: RV2]
#2452203
02/15/18 03:50 PM
02/15/18 03:50 PM
Posts: 20,387 Park Forest, IL
slantzilla
Park Forest, IL
So is the red vega MoPar powered? Anymore info on that car? They showed a quick shot of the Monza with no hood last night. It did not appear to be Mopar based. All he said was small block with spray.
#2452205
02/15/18 03:56 PM
02/15/18 03:56 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Fireball camaro has a ajpe 481x not a hemi.
[Re: BobR]
#2452208
02/15/18 04:03 PM
02/15/18 04:03 PM
Posts: 3,698 jersey
Spaceman Spiff
jersey
Crowmod ran 6.20's at the NHRA race he entered. He was next to last on the Q sheet. Like 24 out of 25 cars. He had some tuning help for that race so it wasn't that he couldn't get that figured out. Stock type hardware just can't hang with big power. He was limited to the amount of boost he could run. He was down about 15 psi for the rules.
[Re: TRENDZ]
#2452216
02/15/18 04:12 PM
02/15/18 04:12 PM
Al_Alguire
Las Vegas
Fireball camaro has a ajpe 481x not a hemi. My bad thought I had heard on here or somewhere it was a BAE deal. I see now it is one of the ubiquitous PLR deals, don't watch the show much and Ill admit that and being wrong for sure
#2452223
02/15/18 04:20 PM
02/15/18 04:20 PM
Posts: 8,166 Left Coast
BobR
Left Coast
Crowmod ran 6.20's at the NHRA race he entered. He was next to last on the Q sheet. Like 24 out of 25 cars. He had some tuning help for that race so it wasn't that he couldn't get that figured out. Stock type hardware just can't hang with big power. He was limited to the amount of boost he could run. He was down about 15 psi for the rules. All the NHRA turbo powered pro mod car are boost limited. And 1/2 second quicker and 30 MPH faster.
[Re: Al_Alguire]
#2452227
02/15/18 04:26 PM
02/15/18 04:26 PM
TRENDZ
Milwaukee WI
Fireball camaro has a ajpe 481x not a hemi. My bad thought I had heard on here or somewhere it was a BAE deal. I see now it is one of the ubiquitous PLR deals, don't watch the show much and Ill admit that and being wrong for sure Fireball camaro has a ajpe 481x not a hemi. My bad thought I had heard on here or somewhere it was a BAE deal. I see now it is one of the ubiquitous PLR deals, don't watch the show much and Ill admit that and being wrong for sure It looks like a hemi from below the cylinder heads😁 deep skirt block, forward distributor drive,front external oil pump mount.....
#2452312
02/15/18 08:49 PM
02/15/18 08:49 PM
Posts: 8,245 Plymouth, MI
Blusmbl
Plymouth, MI
Birdman swapped over to a BAE Hemi in their Firebird a year or two ago.
