Re: What do u guys run for cranking compression
[Re: rook440]
#2451934
02/15/18 12:27 AM
02/15/18 12:27 AM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
what's the motor set up???
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: rook440]
#2451960
02/15/18 01:16 AM
02/15/18 01:16 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Was the engine blueprinted and the compression ratio calculated via measurement? That's a lot of overlap for hi cranking rpm pressures. Is there a particular reason you're looking for it?
[Re: rook440]
#2451970
02/15/18 01:40 AM
02/15/18 01:40 AM
RapidRobert
what about advancing the cam or even a smaller cam. For more performance is the ign/carb dialed in.
[Re: rook440]
#2451993
02/15/18 02:31 AM
02/15/18 02:31 AM
Posts: 4,457 Washington
madscientist
Washington
Cranking compression doesn't mean jack nothing. Hit your starter with 24 volts and watch the cranking pressure go up. Means nothing.
[Re: rook440]
#2452004
02/15/18 03:37 AM
02/15/18 03:37 AM
Posts: 4,210 New York
polyspheric
New York
Complete waste of my time, as always.
Boffin Emeritus
[Re: BradH]
#2452048
02/15/18 10:26 AM
02/15/18 10:26 AM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
What type of fuel do you use?
This. If you are using pump gas, you're pretty close now. You won't make 200 w/o using better fuel.
[Re: rook440]
#2452121
02/15/18 02:07 PM
02/15/18 02:07 PM
Posts: 31,073 Oregon
AndyF
It's a 60 over440 11.5 compression 67 heads fully ported big valves m1 intake cam is .645 lift intake .650 exhaust 280 at .50 intake 285 at.50 exhaust 106.5 Sep install at 103.5. .020 intake lash.016 exhaust You have 280@050 duration? I'm surprised it even runs with that much duration. My pump gas 470 makes 775 hp and has 264@050 duration so I think your cam is way too big.
[Re: rook440]
#2452150
02/15/18 03:02 PM
02/15/18 03:02 PM
Posts: 570 UK
rb446
UK
Back in the day I ran a stock 440SP motor with the CC.650/290@.050 SFT cam at approx 9.8:1, CP was only around 150psi, not ideal yes but it ran real sweet, ticked over@900rpm but only made 490flyhp on the track, weight/mph, mainly cos of the poor intake/small 850DP carb, not good enough 906's (255cfm) and of course the horrible weight of the bottom end, (2000gms per hole), still managed 10.6's with it....was planning to go to 12.5:1 pistons but it never happened.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: rook440]
#2452156
02/15/18 03:13 PM
02/15/18 03:13 PM
Thumperdart
State of confusion
Mines at 160 would like to see it up around 200...whats your opinions..thanks rook 170-175 w/an Isky solid roller 276-281 @ .050 470 cubes and fwiw, a buddy went low 8's a while back w/150...........
[Re: rook440]
#2452180
02/15/18 04:03 PM
02/15/18 04:03 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
What Brad said....There is not a magic number. Look for consistency. You would be surprised what we are at for a cranking compression at over 16-1. TO many factors for their to be a perfect answer.
[Re: rook440]
#2452195
02/15/18 04:29 PM
02/15/18 04:29 PM
fast68plymouth
So. Burlington, Vt.
280@.050, 11.5cr, and you're getting 160psi?
Sounds about right........ Maybe even a bit more than I would have expected.
My 383 @ just under 11:1, 256@.050 solid cam in at 102 would pump about 200 in 8 pumps, all plugs out, wot, battery charger on, engine warm.
My old 448 @ 9.8cr, 259@.050 roller cam in at 106, would pump about 155-160 in 8 pumps, all plugs out, etc.
I know several of the FAST guys have combos that pump 240-260. Lots of compression and short duration cams.
[Re: rook440]
#2452603
02/16/18 03:41 PM
02/16/18 03:41 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
I run about 220 on my pump gas 410 stroker in my dakota, 11 to 1 221@.050 cam, pulls like mad anywhere between idle and 6000 RPM, a shorter duration cam can bump up the cranking compression as can a bunch of other things like ring seal, engine temp, sterter RPM, valve seat seal...
[Re: HotRodDave]
#2452746
02/16/18 07:56 PM
02/16/18 07:56 PM
Posts: 413 Norway (old world)
Oyvind Mopar
Norway (old world)
I run about 220 on my pump gas 410 stroker in my dakota, 11 to 1 221@.050 cam, pulls like mad anywhere between idle and 6000 RPM, a shorter duration cam can bump up the cranking compression as can a bunch of other things like ring seal, engine temp, sterter RPM, valve seat seal... What sort of heads do you have, ignition timing, and do you run on pump-gas?
[Re: rook440]
#2452918
02/17/18 03:08 AM
02/17/18 03:08 AM
Posts: 1,267 North, Alabama
D-50
North, Alabama
My small block runs from 195-200 cranking compression with 10.9 comp. and a 255/266 duration cam. I have never ran anything but 93 octane pump gas. It has aluminum heads.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
