Page 2 of 3 1 2 3
Re: 6 pack metering block question [Re: mickm] #2448713
02/08/18 09:18 PM
02/08/18 09:18 PM
A727Tflite Online content
A727Tflite  Online Content
Hope you get it resolved.
For me, I have to tell you that you are the first guy that I have heard that has a lean six pack. Most everyone I have heard of or seen has always been stink rich.
That lean stench smell I describe - I usually smell it behind old school buses. Why - don't know. shruggy
Re: 6 pack metering block question [Re: A727Tflite] #2449167
02/09/18 06:10 PM
02/09/18 06:10 PM
California
mickm Offline OP
mickm  Offline OP
California
Well remember, it's lean because they didn't drill out the idle restrictor passages! I'll see what happens when I get a correct metering block in there.
With 2 1/2 turns out to get a 15:1 idle, I assume with a properly working metering block I should be able to now set it where I want.
Re: 6 pack metering block question [Re: mickm] #2451071
02/13/18 02:17 AM
02/13/18 02:17 AM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Get yourself a Promaxx metering block. They will set it up for you.
http://promaxcarbs.bizland.com/id1.html
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: 6 pack metering block question [Re: 70sixpkrt] #2451088
02/13/18 05:01 AM
02/13/18 05:01 AM
California
mickm Offline OP
mickm  Offline OP
California
I would go for that, expect I want to keep the stock look. I know I'm leaving a lot of horsepower on the table by a) having the six pack in the first place, and b) not setting it up optimally, but it's the novelty I'm going for.
Once I miss the extra horsepower of my 2X4 setup, (and I do already, just not enough yet), I'll go back to that. But for now, it's just cool having an air cleaner that reads...
"HEMI Six Barrel"
Re: 6 pack metering block question [Re: mickm] #2451095
02/13/18 08:19 AM
02/13/18 08:19 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Are you going to set up the carbs properly or just wing it and then ask questions? drive
Did you know that Tom Hoover spoke very highly of a six pak on a hemi as the fuel distribution was wayyyy much better than the 2x4 set up? I thinks it's humorous with all the talk that a few ponies were left on the table with the +6 vs 2-4s or a big fat 4bbl when a drag race would confirm that six paks rule!.
Re: 6 pack metering block question [Re: mickm] #2451194
02/13/18 02:26 PM
02/13/18 02:26 PM
70sixpkrt Offline
70sixpkrt  Offline
"HEMI Six Barrel"
You don't see the metering block with the air cleaner on.
4-speed
3:54 Dana
Re: 6 pack metering block question [Re: ThermoQuad] #2451220
02/13/18 03:31 PM
02/13/18 03:31 PM
California
mickm Offline OP
mickm  Offline OP
California
No, I did my research first, installed them following some specific instructions I got here on the board, and now am asking questions for the small issues I'm having problems with.
That was one of the reasons I did it, was talking to Tom Hoover about it a few years ago at MATS. But first of all, that was a 426 he was talking about, not a 540. Then there is the fact that at 4bbl ratings, the six pack flows 935 cfm, where the two Edelbrocks I have flow 1300. Then there is the dual plane design of the 6 pak manifold as compared to the single plane Stage V dual 4 I use, which dyno'd by FHO produced 40 more HP than a stock manifold. And yes, setting up a set of drag 6 pak carbs with all 500 CFM carbs may put it back in the range of a single or two 4's, but probably not with that manifold. So this really is in no way and apples to apples comparison.
So yes, it is down on power, and would lose miserably on the track to my other setup.
Re: 6 pack metering block question [Re: mickm] #2451762
02/14/18 06:37 PM
02/14/18 06:37 PM
California
mickm Offline OP
mickm  Offline OP
California
Ok, the conclusion to all this. Got the new metering block from Holley, same result. Probably my fault, but I reminded them, (may not have told them in the first place, thought I did), that I'm dealing with a 540, and they said, Oh, in that case there is nothing we can do for you. This is designed for a 440, and will supply it well, but we can't do or say anything about a larger displacement engine.
Called ProMax, and they said "Yep, that is what our metering blocks are designed for." He also said the six pack metering block is an odd duck, in that it doesn't have an idle restrictor passage in the usual place, which started all this.
So I live with it, or get a Promax block, as Ricky suggested.
All I wanted to do was clean up a stinky idle. I'll live with it for now...
Re: 6 pack metering block question [Re: mickm] #2451766
02/14/18 06:44 PM
02/14/18 06:44 PM
70sixpkrt Offline
70sixpkrt  Offline
I wouldn't run too lean. You could wash out some cylinders.
4-speed
3:54 Dana
Re: 6 pack metering block question [Re: mickm] #2451783
02/14/18 07:14 PM
02/14/18 07:14 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Some times you can not get the carb down to the idle circuit and still have enough air to keep the car running, I drilled a small hole in each butterfly plate to allow additional air flow so the car will stay running while down on the idle circuit.
Re: 6 pack metering block question [Re: mickm] #2451808
02/14/18 08:04 PM
02/14/18 08:04 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
how big is the cam and what is the LSA ?
if it has alot of overlap you might be stuck with a stinky idle...
also you have three carb to adjust idle mix on?? can you richen the outboard carbs up a bit and get the center carb a little more in line with traditional settings??
Re: 6 pack metering block question [Re: mickm] #2451813
02/14/18 08:08 PM
02/14/18 08:08 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i guess as a test, you could always put some thin wire in the idle air bleeds, readjust idle mix to where it likes it and see if the exhaust is still stinky...
Re: 6 pack metering block question [Re: mickm] #2451836
02/14/18 08:57 PM
02/14/18 08:57 PM
70sixpkrt Offline
70sixpkrt  Offline
"HEMI Six Barrel"
Mick if decide to pull the Sixpack off, let me know.
4-speed
3:54 Dana
Re: 6 pack metering block question [Re: 70sixpkrt] #2451864
02/14/18 10:02 PM
02/14/18 10:02 PM
California
mickm Offline OP
mickm  Offline OP
California
"HEMI Six Barrel"
I'll swap manifolds one of these days, but will keep the six pak setup. No sense in getting rid of it, it's a fun novelty! But I will let you know.
Re: 6 pack metering block question [Re: krautrock] #2451866
02/14/18 10:05 PM
02/14/18 10:05 PM
California
mickm Offline OP
mickm  Offline OP
California
I have it farther down, in the 14+ range, just turns the screws farther out.
I'm just going to live with it. There are other things that need attention, this is just more of a nuisance than anything else.
I didn't expect it to take this much time and energy, but since it is what it is and doesn't harm anything, it's good enough.
Re: 6 pack metering block question [Re: mickm] #2451892
02/14/18 10:57 PM
02/14/18 10:57 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
If you hate the stinky smell switch to 101 low lead AV gas,you'll love it then !! grin
Re: 6 pack metering block question [Re: 62maxwgn] #2451896
02/14/18 11:05 PM
02/14/18 11:05 PM
California
mickm Offline OP
mickm  Offline OP
California
Is that a sarcastic "you'll love it"? Besides with what I imagine to be $7-10 / gallon prices, I'm not sure about that!
Re: 6 pack metering block question [Re: mickm] #2451928
02/15/18 12:11 AM
02/15/18 12:11 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
If you have a large overlap cam you should be focusing on idle quality, not what an O2 meter is reading. It simply does not read right. If the O2 meter is reading 15:1 the the combustion charge AF ratio could still be far too rich. Some have reported as high as 18:1 meter reading at best idle quality w a big cam
Re: 6 pack metering block question [Re: mickm] #2451929
02/15/18 12:14 AM
02/15/18 12:14 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Not sarcasm,fact.All I've ever ran in my sixpack Superbird and wagon since 1992,airport is 10 mi over the mountain,$4.35 gal.
Re: 6 pack metering block question [Re: 62maxwgn] #2452006
02/15/18 03:46 AM
02/15/18 03:46 AM
Do you know about the Federal law restricting using leaded fuel of any type on any public U.S. roads, freeways or highways in all of the U.S.? If not be aware of it, it carries a $10,000 for the first offence work down
I can tell you that every law enforcement agency in California that I've talk to or heard about are aware of it and they know the local courts get to keep all of the fine money from that citation puke down shruggy
I was warned by a San Bernardino County sheriff about that back n the 1990s when he saw one of my old race cars with current tags at the old LACR race track, he assumed I drove it on the street regularly, which I hadn't done in his presents at that time, he was a drag racer also work The smell gives it away shruggy
Page 2 of 3 1 2 3
