Re: BB Water Pump [Re: 71birdJ68] #2451631
02/14/18 12:55 PM
02/14/18 12:55 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Three core aluminum Champion radiator, Milodon 160 degree high flow stat, cheap OEM aluminum water pump and twin Ford Contour electric fans. Hold my 512 stroker at 180 degrees on the hottest of summer days. Would go cooler if I set the controller lower.
Re: BB Water Pump [Re: 71birdJ68] #2451677
02/14/18 03:00 PM
02/14/18 03:00 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Originally Posted By 71birdJ68
It will run 210/215 on a hot day. I know everybody says that that temp is ok, but I have the rad off for some other things, so I thought if a pump upgrade would lower it a few degrees, then I would give that a try.
OEM A/C set-up on a '71 Ply B-body...
Including A/C water pump w/180 thermo...
Years of extreme driving conditions...
Including a lot of summer putt-putt in traffic...
NEVER gone past 180...
Re: BB Water Pump [Re: RSNOMO] #2451686
02/14/18 03:35 PM
02/14/18 03:35 PM
Morristown Tn.
71birdJ68 Offline OP
Morristown Tn.
I have all of that covered, I was just wondering about the water pump. If anybody made one with 8 vanes, and an anti cav plate. Looks like they don't, so I may try to make my own.
Re: BB Water Pump [Re: 71birdJ68] #2451690
02/14/18 03:48 PM
02/14/18 03:48 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Before I re-did the engine, I was at 210 all the time, too...
Lots of casting 'sludge' in the coolant passages when I pulled it down...
Two 'dips' in the hot-tank, and some righteous scrubbing with the gun cleaning brushes took care of all that...
Didn't know about 'burn and tumble' then, or I would've went that route...
Re: BB Water Pump [Re: 71birdJ68] #2452676
02/16/18 06:05 PM
02/16/18 06:05 PM
is that around town or on the highway? & the reading is confirmed with a good mech gauge. Any overheating symptoms other than what the current gauge is showing (& I ain't saying 210 is critical).
Re: BB Water Pump [Re: RapidRobert] #2452747
02/16/18 07:57 PM
02/16/18 07:57 PM
Morristown Tn.
Morristown Tn.
That is on the highway, and around town, after the engine gets good and warm. The reading is taken with an inferred thermometer at the thermostat housing, or the factory sending unit
Re: BB Water Pump [Re: 71birdJ68] #2452916
02/17/18 03:03 AM
02/17/18 03:03 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
What are you building that some of these previous posts won't help you???
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: BB Water Pump [Re: hemi-itis] #2452929
02/17/18 03:51 AM
02/17/18 03:51 AM
Morristown Tn.
Morristown Tn.
All I asked was, if anybody knew of a 8 vain pump with aaa anti cav plate all ready installed.
Re: BB Water Pump [Re: 71birdJ68] #2452933
02/17/18 04:05 AM
02/17/18 04:05 AM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Don't forget the Aluminum requirement!
And You're So Vain, you probably think this thread is about you, don't you?
8 vane.
All good LOL
Re: BB Water Pump [Re: Pacnorthcuda] #2453015
02/17/18 01:11 PM
02/17/18 01:11 PM
Morristown Tn.
Morristown Tn.
Yes, and there is also the blue vain meat roll.
Re: BB Water Pump [Re: 71birdJ68] #2453049
02/17/18 02:14 PM
02/17/18 02:14 PM
AndyF Offline
AndyF  Offline
Re: BB Water Pump [Re: 71birdJ68] #2456625
02/24/18 01:14 PM
02/24/18 01:14 PM
MA
K
Kevin Kowalski Offline
K
MA
There are several 6 vanes with a anti cal plate. I'm looking to up grade. Guess I could get a Mildon, which has 8, and add a plate.
I read this post before ordering a Milodon #16260 high volume pump which I received yesterday. To my surprise it has a welded anticavitation plate and 6 vanes. The op also described his current one as a 6 blade with the anticav plate. For reference the pump has 'GMB' and 'CR20' cast on the front.
Re: BB Water Pump [Re: Kevin Kowalski] #2456630
02/24/18 01:23 PM
02/24/18 01:23 PM
moparx Online content
moparx  Online Content
GMB pumps have a good reputation, so i wouldn't have any worries about running that pump.
beer
Re: BB Water Pump [Re: moparx] #2456673
02/24/18 02:37 PM
02/24/18 02:37 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
This is a "for what it's worth" no
A few years ago there was a fellow on B-body's only forum that was bound and determined that he was going to re engineer Chrysler's cooling system.He spent weeks doing what he thought was better,never accomplished anything but wasted time.He finally got beat up enough on the forum that he finally left and never came back.Every car I have ever owned (a lot),modified or not had/has the factory cooling system working as it should and have "never " had a cooling issue under any condition.Being old,I will stick with what worked for me for over 60 + yrs. twocents
Re: BB Water Pump [Re: 71birdJ68] #2456675
02/24/18 02:39 PM
02/24/18 02:39 PM
BlueRacer69 Offline
BlueRacer69  Offline
And its aluminum. Has everything the O.P. ask for except the 8 vanes.
