Page 2 of 4 1 2 3 4
Re: Engine oil [Re: 62SAVOY] #2451756
02/14/18 06:28 PM
02/14/18 06:28 PM
America
WedgeFED Offline
WedgeFED  Offline
America
http://rehermorrison.com/tech-talk-98-oil-is-everything/
I think this guy is a pretty smart fellow...
Re: Engine oil [Re: BradH] #2451758
02/14/18 06:29 PM
02/14/18 06:29 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Originally Posted By BradH
Originally Posted By mopar dave
I think my message would be oil is not oil. Looks to me that some has more additives than others and pass testing with higher marks as well.
My message is that the majority of oil discussions on here turn into big stinkin' piles of opinions without any empirical data to back them up.
Oil, religion, politics... possibly The Big Three of things which can never be discussed objectively.
I'll wait and see where this goes before I decide step back in here again. popcorn
What the heck do you want for proof Brad. You know the guys that race and the guys that don’t.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Engine oil [Re: pittsburghracer] #2451761
02/14/18 06:35 PM
02/14/18 06:35 PM
jersey
Spaceman Spiff Offline
jersey
Some people swear by brad penn... I know of at least three people using it, where the cams went flat.
What works great for some, will not work great for all.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Engine oil [Re: Spaceman Spiff] #2451768
02/14/18 06:51 PM
02/14/18 06:51 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Nothing wrong with Bradd Penn. I have used it many times when low on funds. I have also used valvoline vr1, good stuff, but i get the Bradd Penn for $5/qt. When funds are good i use Amsoil. Im not a racer, but engines dont get babied either and i will not buy the cheapest oil at the corner store.
Re: Engine oil [Re: pittsburghracer] #2451771
02/14/18 06:55 PM
02/14/18 06:55 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
You should know as well as anyone that just because someone races doesn't mean they know squat about oil... or carb tuning... or engine maintenance... or ... well, you get my point.
I'd be more interested in hearing from engine builders than engine abusers on a subject like this. wink
Re: Engine oil [Re: mopar dave] #2451772
02/14/18 06:57 PM
02/14/18 06:57 PM
BradH Offline
BradH  Offline
... Bradd Penn... Bradd Penn...
One "d" in "Brad" tonguue
OK, back to my hole while the rest of y'all hash this out (again...)
Re: Engine oil [Re: 62SAVOY] #2451791
02/14/18 07:29 PM
02/14/18 07:29 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I moved on to Driven (Joe Gibbs) oil. Lost 2 hydraulic flat tapped cams with Valvoline VR-1.
Re: Engine oil [Re: 62SAVOY] #2451795
02/14/18 07:40 PM
02/14/18 07:40 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I have used them all Valvoline, Joe Gibbs, Brad Penn, Torco, Amsoil and LAT.
This is my ranking:
1.) Joe Gibbs
2.) LAT
the rest are tied and all good oils.
Flat tappet cams are a tuff deal. I recommend hyd rollers anytime I'm asked to do a flat tappet. It's always about the cost but in the long run one flat cam and the hyd roller pays for it's self.
Re: Engine oil [Re: 62SAVOY] #2451827
02/14/18 08:31 PM
02/14/18 08:31 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
No offence to anyone but if you have to put a additive in your oil it's not the right oil.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Engine oil [Re: WedgeFED] #2451867
02/14/18 10:10 PM
02/14/18 10:10 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Well, I was about to move to the 10w30 VR-1 until I read that. Guess I'll stay with the 20w50 that I have been running for years. Is this a case of 'if it ain't broke, don't fix it'?
Master, again and still
Re: Engine oil [Re: 62SAVOY] #2451873
02/14/18 10:23 PM
02/14/18 10:23 PM
Ohio
lockjaw-express Offline
Ohio
I have been using 20w-50 VR-1 and a small bottle of ZDDP+ that I buy on ebay on every oil change on my 440 solid flat trappet cam engine, and just VR1 20W-50 in my Hemi with a roller cam.
I guess I will continue to use that unless, someone tells me of something better?
Mark
Re: Engine oil [Re: DaveRS23] #2451884
02/14/18 10:47 PM
02/14/18 10:47 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Read the interesting linc and that guy knows a thing or two. Think i'll stay with the 20/50 as well.
Re: Engine oil [Re: 62SAVOY] #2451887
02/14/18 10:51 PM
02/14/18 10:51 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
With the all the flat tappet cams going flat could some of it be from to much spring pressures and not necessarily oil???
Re: Engine oil [Re: 62SAVOY] #2451895
02/14/18 10:58 PM
02/14/18 10:58 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Redline Oil here. Elixir of the Gods! fart
Re: Engine oil [Re: Jacob Pitt] #2451900
02/14/18 11:17 PM
02/14/18 11:17 PM
PA.
"Little"John
"Little"John
PA.
I look at it this way. I build all my own engines and have for many many years. I have also been a Brad Penn (Kendal) user for those same 40 plus years. Oil as we know it has changed over the years and so has the quality of the metals used in our cams and lifters. Now throw into the mix I run alcohol and we all know the issues with that. (water moisture). Now with the 650 lift solid lifter cam and higher spring pressures that I run adding a bottle of additive and EDM lifters is cheap insurance. I have no issues running my engine for 3 years between engine freshen jobs. Wrong oil? I don't think so but what do I know. Hopefully when I freshen my small block next time I will grind my R3 block so I can run roller lifters and I will sleep even better at night.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Engine oil [Re: 62SAVOY] #2451903
02/14/18 11:21 PM
02/14/18 11:21 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
15-40 Delo 400
Re: Engine oil [Re: 62SAVOY] #2451918
02/14/18 11:51 PM
02/14/18 11:51 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
What oil should i run?
Clean oil.
Re: Engine oil [Re: NTOLERANCE] #2451930
02/15/18 12:18 AM
02/15/18 12:18 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Clean oil.
by the looks of the car on your post I would say clean oil would not be necessary
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Engine oil [Re: NTOLERANCE] #2451933
02/15/18 12:21 AM
02/15/18 12:21 AM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I'm surprised that no one has mentioned Schaeffer's Racing oil. I know most on here are either drag race or street/strip guys, but round trackers swear by it. A lot of these racers are limited to flat tappet cams (no rollers). I also know a bunch of large engine drag racers that use it with great success
Brian
Re: Engine oil [Re: '72CudaRacer] #2451946
02/15/18 12:47 AM
02/15/18 12:47 AM
Schaeffers make some excellent gear lube for transfer cases and drag race rear ends up
The only problem I know of with the drag race gear oil it is 250 Wt. shock Which means you need run the car on jack stands for 2 to 5 minutes to warm it up before pulling into the lanes to race shruggy
My Son in Law use to work for a ski resort in SO CA maintaining all their track vehicles, they used Shaeffer brand lubes only in all of their vehicles from the general managers SUV to all the big snow cats, he was amazed that none of their lubes would not mix with the water(from condensation) in the snow cat transfer cases or engine oil, the water would drain out first and then the oil or lube would follow work up
I wish I knew of a west coast distributor that I could buy their products from up here in central Oregon help grin
Page 2 of 4 1 2 3 4
