Re: Battery in the trunk, photo's?
[Re: RV2]
#2456822
02/24/18 06:09 PM
02/24/18 06:09 PM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
Is it true that a acid/lead plate battery should be mounted horizontal? I don't know, but I did mount my battery so the plates go front to back.
[Re: justinp61]
#2456926
02/24/18 08:46 PM
02/24/18 08:46 PM
Posts: 43,309 Bend,OR USA
Cab_Burge
Is it true that a acid/lead plate battery should be mounted horizontal? I don't know, but I did mount my battery so the plates go front to back. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) That is the best way to avoid problems with a wet cell lead acid battery in mounting them But that only applies to hard leaving cars, not tire spinners
[Re: Dragula]
#2457755
02/26/18 06:39 AM
02/26/18 06:39 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I put mine in a marine case because since its a street car I put many things in my trunk. Including my jacket and clothes sometimes so I don't want any acid to get on anything in my trunk. Ron Is that on the drivers side? Yes it is. I know the deal about how it should be on the pass side but my cable was given to me and it was just a bit to short to put it on the right rear. So since its just a street car I put it in the left rear where I had enough cable to reach. And its worked fine there as for a mild street car it hooks fine and I just tweaked the torsion bars to keep the ride height level. Ron
