Re: I think I might have an engine problem... [Re: BSB67] #2447801
02/07/18 12:41 AM
02/07/18 12:41 AM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Yup. lol
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: I think I might have an engine problem... [Re: Porter67] #2447822
02/07/18 01:43 AM
02/07/18 01:43 AM
Cab_Burge Online work
Cab_Burge  Online Work
Originally Posted By EV2Bird
Clearly not everyone is as smart as this guy....
https://www.youtube.com/watch?v=Pn-sNkeW7uA
I'm sure both of his parents owned and drove Chevy as well as smoke the old good stuff whistling grin
Re: I think I might have an engine problem... [Re: Cab_Burge] #2448083
02/07/18 05:07 PM
02/07/18 05:07 PM
Planet Earth
RoadRunnerLuva Offline
Planet Earth
What (if anything) did Brian at IMM say about your engine dilema?
You said you took it back to him to have it tuned? HE built it...
what was HIS advise to you? You also said you were done with shops...
I am assuming he was of no help to you? work
And BTW his reputation isn't all it's cracked up to be, I have dealt
with him in the past myself as a customer, and it didn't end well. twocents
Plymouth Makes It!
Re: I think I might have an engine problem... [Re: Porter67] #2448119
02/07/18 06:03 PM
02/07/18 06:03 PM
Washington
madscientist Offline
Washington
That dude is weird. He has a face I just can't trust. And the engine was rebuilt by HIM.
Re: I think I might have an engine problem... [Re: Porter67] #2448219
02/07/18 09:54 PM
02/07/18 09:54 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
That was a really annoying and waste of 2 minutes 4 seconds.
Facts are stubborn things.
Re: I think I might have an engine problem... [Re: MuuMuu101] #2448285
02/08/18 12:45 AM
02/08/18 12:45 AM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
For the record, I wasn't expecting/blaming IMM for building me a broken motor. If it is broken, I probably would have assumed it was my fault anyway. IIRC, IMM set initial timing to about 34 degrees. Unfortunately, Brian forgot to give me cam specs and they seem to be lost. I just know it's something like a 238/242.
Since November, I have been driving the car every weekend. Generally I let the car warm-up for 5-10 minutes and then I go for about a 15-20 minute ride. Generally, when I've been driving, the engine runs between 180-200F for the water temp. So, it has been getting to operating temperature every time I've driven it.
As for the rest, thank you for the advice. I think I'm going to start simple and pull the spark plugs and inspect them whenever I get free time. While I'm at it, I'll change the oil (as it needs it anyway).
When the car was first built, the person who put it together set the fuel pressure to about 8 psi. At my first autocross, I ended up flooding the carb on the first turn 3/4 runs. After that incident I turned the fuel pressure down to 6.5 psi as the youtube video on tuning Holley carbs I watched said 7 psi MAX. I think I may bump it down a little more (5 psi-ish) as, like you're all saying, it seems like its running a little too rich.
I think I'll take it on longer runs on the weekend to the gf's house which is 30 miles one way and generally a 30-40 minute drive.
Re: I think I might have an engine problem... [Re: MuuMuu101] #2448298
02/08/18 01:10 AM
02/08/18 01:10 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Adjusting fuel pressure is not the way to lean out a tune. Too much pressure can push fuel past the floats and through the jets. Once you are below that threshold [7psi], you need to be adjusting idle mixture screws and jetting.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: I think I might have an engine problem... [Re: GoodysGotaCuda] #2448301
02/08/18 01:18 AM
02/08/18 01:18 AM
SoCal
SoCal
Coolio. I'll watch some youtube videos from Holley to adjust idle mixture screws and jets.
Re: I think I might have an engine problem... [Re: MuuMuu101] #2448488
02/08/18 01:42 PM
02/08/18 01:42 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
first thing i would do is pull the plugs and see if they are black.
and also set your float level, mid way up the glass if it has that in the bowls, if it's just a screw, the fuel should be right at the bottom if you pull the screw out, engine idling when you check this...
proper idle mix tune won't have the car idling well until it warms up some. tune the idle mix after the motor is completely warm.
go around the carb (all four idle screws) screwing them in 1/8th turn (leaner) until the idle stops getting higher and smoother, then maybe richen it up just a touch from there, like 1/16th of a turn on all screws...
you can also tune the idle mix for highest vacuum reading instead of RPM.
if your plugs are real black.
for the jetting, lean it out in small steps. drive down the hwy steady cruise, maybe 2000rpm, once you are too lean you will feel some very subtle surging. from there jet it back up two sizes maybe.
because of the power valve in the primary side, the seconday jets will be larger by something like 8 sizes or so. (look up the baseline tune for your carb).
Re: I think I might have an engine problem... [Re: MuuMuu101] #2448520
02/08/18 02:41 PM
02/08/18 02:41 PM
amxautox Offline
amxautox  Offline
And check to see if the power valve is blown.
Tom
author unknown
Re: I think I might have an engine problem... [Re: MuuMuu101] #2448641
02/08/18 06:43 PM
02/08/18 06:43 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
I'd rejet sooner rather than later. Fuel washdown of the cylinder walls can destroy your ring seal.
Another option would be having it dyno tuned.
Re: I think I might have an engine problem... [Re: MuuMuu101] #2449954
02/11/18 04:30 AM
02/11/18 04:30 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
The white smoke and the black soot can be as simple as it is pig rich. Rich can cause condensation in the exhaust if it is not driven a lot and burned out. The black soot is just the water washing the carbon out of the pipes.
