LOWER BALL JOINT -- HIGH FRICTION?
#2446844
02/05/18 02:14 PM
02/05/18 02:14 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
I'm replacing my older front spindles with '73-up so to install the 11.75" Cordoba rotors (still to buy); engine is out and won't be installed until a few months from now. I've purchased new Moog Lower Ball Joints; Upper Ball Joints still good, not loose, etc... reusing them. I've also welded the K-frame and added lower control arm reinforcement plates (all Firm Feel, etc); engine bay also re-done like new!
When I torque the UPPER BJ nut (100 ftlbs) and the LOWER BJ nut (80 ftlbs.. per my Challenger spec manual) then try to turn the spindles by hand L-R, there is a lot of effort required... doesn't seem correct... very tough to turn L-R by hand.
I had used anti-seize lube on the UBJ and LBJ studs and threads, so, disassembly was easy.... re-did the install, same results. I've noticed the UPPER BJ stud turns when I grab and turn the assembly, but the LOWER BJ stud doesn't turn.
Could the anti-seize be causing the LOWER BJ stud NOT to turn, even though its torqued to 80 ftlbs?
I had also re-greased the UBJ and LBJ with red synthetic grease, gushed out to assure enough was inside.
The UPPER BJ stud (attached by itself) allows free motion of the spindle (and not loose or wobbly), but when I attached and torque the LOWER BJ stud, that's when the problem seem to develop -- very difficult to move the spindles L-R.
Could these new LOWER BJs be bad? Why are they so tight and won't move (twist) like the UPPER BJ stud?
I'm tempted to buy another pair of LOWER BJs (perhaps Moog, again); maybe a different brand. I know for a fact that the OEM front suspension parts (BJs, tie-rods/ends, etc) were all from TRW -- they supplied the dominance of the OEM big-three suspension parts back then), but they are hard to find in the aftermarket.... Moog is pretty dominant now.
Any helpful advice or replies will be appreciated.
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
Re: LOWER BALL JOINT -- HIGH FRICTION?
[Re: Mopar Mitch]
#2446937
02/05/18 04:46 PM
02/05/18 04:46 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You realize that using antisieze on the threads results in substantially more effective torque than specified.
Do not substitute, or use, lubricants unless specifically called for. Unless you are capable of recalculating the required torque.
You've probably overstretched the stud.
[Re: Mopar Mitch]
#2447043
02/05/18 08:07 PM
02/05/18 08:07 PM
Mopar Mitch
T/Anks for both of your replies.
Mopar Mitch
[Re: Mopar Mitch]
#2447087
02/05/18 09:58 PM
02/05/18 09:58 PM
Supercuda
About to go away
About to go away
up yours
I did a bit of research, as a rule of thumb when using antisieze you should drop the torque value 40% compared to dry. Here's a handy chart for reference is all else fails http://www.alliedsystems.com/pdf/Wagner/Forms/80/80-1057.pdf
[Re: Supercuda]
#2447396
02/06/18 03:07 PM
02/06/18 03:07 PM
Mopar Mitch
Yes... Thanks for the chart.
Mopar Mitch
[Re: NV69B7RR]
#2447399
02/06/18 03:08 PM
02/06/18 03:08 PM
Mopar Mitch
I recall seeing a blue grease inside the Moog LBJ.
Mopar Mitch
[Re: Mopar Mitch]
#2447795
02/07/18 12:28 AM
02/07/18 12:28 AM
Mopar Mitch
I phoned the Moog tech line today.... spoke with Jerry. He commented that the usage of the anti-seize on the studs and threading should not have made any difference to the functioning of the ball joint. He said the studs of the ball joints are tough and rather stiff, but they will loosen and become more free as the car is used. The studs should twist L-R as the spindle is also turned L-R.
I'm going to disassemble the BJs and clean-up the anti-seize, anyway, and re-torque carefully. Also, I'll see if the LBJ can be moved by disconnecting the UBJ first, then leveraging the spindle so to see if the LBJ stud will actually move. If I'm not pleased, I may just go ahead and purchase/replace again the LBJs.
One other thing, when I first torqued the passenger side together, I was torquing with the tall rubber snubber (under the the UCA), which I have extended the height, against the UCA, in other words, the rubber snubber was being compressed as I tightened the spindle upper and lower nuts... possibly making the effort tighter.... and that's the spindle assembly with much more friction making it difficult to turn L-R. However, when I re-did it without the snubber, it made no difference.
Then, when I did the driver's side, I didn't install the extended rubber snubber, so, it was easier to torque the nuts.... less friction overall turning the spindle L-R.
So, maybe I may just need to replace the passenger side LCA... ;possibly it was extensively over-tightened within its guts.
Learning lessons! I'll let everyone know of the final outcome.
T/Anks!
Mopar Mitch
[Re: Mopar Mitch]
#2447982
02/07/18 01:17 PM
02/07/18 01:17 PM
Posts: 668 Los Osos, Ca
CKessel
Los Osos, Ca
Keep an eye out for different stud lengths on the ball joints, even with the oe replacement stuff. I've been seeing a trend for awhile now where the stud length is not the same as what was removed and you now have to stack washers under the nuts to get the cotter pin hole to line up with the castle nut slot. Both the tapered portion of the stud and the straight portion have been changed. When I was at SEMA, I talked to the rep from ProForged about this and he verified that the companies, his included, have consolidated a lot of stud differences and use one stud to fit many more applications as opposed to being the correct length. Changes in the stud length can change your geometries plus can cause binding issues if the joint hits other components.
Carl Kessel
[Re: RylisPro]
#2449150
02/09/18 05:03 PM
02/09/18 05:03 PM
Mopar Mitch
RylisPro -- T/Aanks for the effort you've offered. Those rubber boots were a bit difficult to install so to grasp in-place.
Gen3 and 6spd.. sure!
Mopar Mitch
[Re: Mopar Mitch]
#2466367
03/14/18 02:09 PM
03/14/18 02:09 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
I had to log in to ask about this because it sounded so wrong to me... why would you ever want to see a ball joint stud twist after installation?
Doesn't that mean the stud isn't actually seated in the spindle taper?
I was pretty dead sure stud is supposed to stay in place until you take the nut off and knock it loose from the spindle taper, at least that's how I've been operating for years.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
[Re: Mopar Mitch]
#2466428
03/14/18 03:52 PM
03/14/18 03:52 PM
Mopar Mitch
I re-did the problem side that was super stiff (bought another new LBJ). and this time I didn't tighten it against the extended rubber snubber... now A-OK... same as the other side.. both same with minor friction. It looks to me as though I over-tightened that one stud.. appears possibly bent.
So, a learning lesson to me.
T/Anks for the replies to all! Forward motion on the re-assembly of the car! Engine has been brought to a shop for prepping.
Mopar Mitch
