Re: Pro Comp BB Victor CNC heads
[Re: fast68plymouth]
#2464312
03/10/18 03:38 PM
03/10/18 03:38 PM
fast68plymouth
So. Burlington, Vt.
Just for grins I went on ebag to see where the current prices are for these things.
Looks like it's right about $1500/pr bare, $1800/pr assembled with HR springs, free shipping. It would be interesting to see what the valve job situation was like between the bare and assembled heads.
#2464641
03/11/18 11:11 AM
03/11/18 11:11 AM
Porter67
You can buy bulk china man products from here and skip the middle man, some of the places show there facilites some dont in there info. Weather some agree with me or not but ALOT of the products sold with there cnc name in them is alot of hype and smoke and mirrors as at the end of the day most are just cleaned up checked china based products. https://www.alibaba.com/trade/search?fsb...mopar+440+heads
#2464644
03/11/18 11:25 AM
03/11/18 11:25 AM
Porter67
$200-$300 per assembeled https://www.alibaba.com/product-detail/N....15027a88hg7cnZNon cnc I know procomp buys then non cnc from china and sends them up the street from them to have it done. If one had there own cnc program...hmm. Then again time vs labor some of the cnc work is a bit cosmetic imo.
#2484589
04/18/18 12:35 PM
04/18/18 12:35 PM
fast68plymouth
So. Burlington, Vt.
I just figured I'd post the final details of this job.
These heads use valves the same length as Indy heads, and I used 2.19/1.81 valves in this set. After remachining the valve seats the installed height came out right at 1.900 with a .060 spring cup and a Comp Cams 10* steel retainer with std height locks. Ti retainers could gain you about .030"-.050" depending on what brand and part number you used.
The chamber volume was right at 82cc, again..... This is after cutting the seats.
The decision was made to shoot for 72cc. I guesstimated about .0055" per CC, so I cut them .055". As it turned out, that was worth 12cc, so they ended up at 70cc's. I took .066" off the intake surface to get the manifold to fit correctly.
Mocked up on an uncut 440 block with .040 head gaskets and Superformance .062" thick manifold gaskets, the bolt holes and ports lined up pretty well. The 6412 std port intake gaskets are a pretty good match for the port sizing and alignment with these heads.
Heads are assembled with Comp 928 springs, 749 retainers, 611 locks, , steel jacketed viton valve seals, and 1.680 OD spring cups(which required no machining to fit).
![Name: image.jpg
ID: 322854 image.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/322854/filename/image.jpg) ![Name: image.jpg
ID: 322855 image.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/322855/filename/image.jpg)
#2484767
04/18/18 07:44 PM
04/18/18 07:44 PM
BradH
Did cutting them that much regain anything in lost quench pad due to the extensive CNC carving in the chamber? If they stay together, those could be some pretty effective flat-tappet cam heads.
[Re: BradH]
#2484849
04/18/18 10:26 PM
04/18/18 10:26 PM
fast68plymouth
So. Burlington, Vt.
Did cutting them that much regain anything in lost quench pad due to the extensive CNC carving in the chamber? If they stay together, those could be some pretty effective flat-tappet cam heads. Not really.....the chambers didn’t appear to shrink from the sides with that amount of milling.
#2484992
04/19/18 10:28 AM
04/19/18 10:28 AM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
You do some beautiful work Dwayne.
#2486217
04/21/18 10:50 PM
04/21/18 10:50 PM
Posts: 274 Granbury TX
Prochargedmopar
Granbury TX
Good info. I enjoyed reading this thread.
"Old" member Registered: Sep 2001 Lost my credentials, I'm Back!! LOL 71 Ply Satellite Procharged 73 Dodge Dart Swinger 73 Ford F-100 390/Sniper efi/back to carb 01 Town and Country Limited 08 Dodge 2500 6.7 5" Deleted 02 Mercedes C230K 19 Camry
#2486229
04/21/18 11:27 PM
04/21/18 11:27 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
Thank you Dwayne for sharing !!!!
#2558196
10/03/18 12:18 PM
10/03/18 12:18 PM
fast68plymouth
So. Burlington, Vt.
(It would appear the post that I’m responding to here has been deleted. Apparently the rocker shaft fit in the saddles is a bit loose, and the poster was unhappy that I didn’t catch that when prepping the heads........ so this was my response to that. I figure if this is a potential problem with these heads, then that’s info that should be out there, so I’ll leave my response up to highlight the fact that this is something that should be looked at.)
I’m the “head specialist” in question........ if you’re referring to the particular heads in this thread.
There isn’t really any excuse for not catching this issue, other than to say it’s something I’ve never come across on any Mopar head I’ve put on a motor in 38 years. Frankly, the shaft saddles not being machined to the correct size never entered my mind.
Also, just the be clear........ I didn’t sell these heads. I was contacted about whether I’d be interested in prepping a set of these heads, so I said “sure”........ and a few weeks later the cnc’d bare castings showed up.
To my recollection, I never had the rocker gear here that was going to be used on these heads to test fit any of it.
If the saddles are simply machined to a slightly larger diameter than they should be, you should be able to lay some shim stock in there to properly locate the shafts. And if the hold down clamps are machined to the correct diameter, I would think it should work fine.
Another possible solution would be to contact Mike at B3RE to see about having some shaft relocation spacers made, with the lower arc of the spacer made to match your heads. He’d likely instruct you that you need the spacers anyway, so it would just be a matter of whether he could match the arc of those saddles or not.
#2558264
10/03/18 02:34 PM
10/03/18 02:34 PM
fast68plymouth
So. Burlington, Vt.
If I’m not mistaken, I believe two different competitors in the EMC have used these castings for their entries in the past. I wonder if their heads had this issue........ and if they did, how they worked around it.
