Page 3 of 3 1 2 3
Re: 99 V10 engine noise...Bad cats?? [Re: chargers777] #2440735
01/25/18 09:48 PM
01/25/18 09:48 PM
ND
dodgedon Offline OP
dodgedon  Offline OP
ND
Yes, It's a little loose. Was looking For a replacement and all I see is just the chain... I thought that was a no no? Didn't find any listings for a chain and gears set...
The rods are all showing brass and some are down to the metal on the bearing shells. None of them were spun. The mains look perfect. The first rod Journal has a small step on it and is too deep to fix, so I ordered a different crankshaft. I'm finding there is not much for parts available for these engines
67 Charger 383 auto
75 Dodge CNT 800 CAT Diesel
2012 Ram Crew cab 5.7 4x4
Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon] #2441410
01/27/18 10:27 AM
01/27/18 10:27 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Never really was. Hope you find what you're looking for.
Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon] #2442094
01/28/18 10:41 AM
01/28/18 10:41 AM
Guitar Jones Offline
There are things that interchange with the magnum small block but I don't know exactly what. Timing chain and gears may be one such thing.
Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon] #2442095
01/28/18 10:46 AM
01/28/18 10:46 AM
A quick cross reference on rock auto shows they both use the same chain so an aftermarket set for a small block should work for you.
Re: 99 V10 engine noise...Bad cats?? [Re: Guitar Jones] #2442244
01/28/18 03:03 PM
01/28/18 03:03 PM
ND
dodgedon Offline OP
dodgedon  Offline OP
ND
The magnum set won't work. The chain may be the same but the upper sprocket has the ring cast on it for the cam sensor. What I have found is that you can buy the chain, and the lower sprocket separately from Napa, but not the upper sprocket. I did find a timing "set" listed for this from Auto zone #73153. Not for sure that they can even order it still... Or who even makes it. Anyone have any opinion on the quality of their parts?
67 Charger 383 auto
Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon] #2443267
01/30/18 04:38 AM
01/30/18 04:38 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Autozone's website says that they're available.
https://www.autozone.com/internal-engine...odel=&year=
They even list them on Ebay with two different number and prices.
https://www.ebay.com/itm/Engine-Timing-S...qGq&vxp=mtr
https://www.ebay.com/itm/Engine-Timing-S...kS1&vxp=mtr
Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon] #2446437
02/04/18 07:45 PM
02/04/18 07:45 PM
ND
dodgedon Offline OP
dodgedon  Offline OP
ND
Problem solved... I did order that timing set from Auto Zone. It said Made in the USA on the package but not sure by who. It looked good and was almost identical to the original. Dropped in the new crank and bearings and ran it yesterday and drove it to town today. It hums like a V-10 with no funny rattling noise between shifts. The engine had a little lifter noise on start up before too and that is also gone now. I know now that the engine oil was bleeding down from the loose rods when it sat.
After all these years of wondering what it was, I'm happy to be done with it.
67 Charger 383 auto
Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon] #2446484
02/04/18 08:49 PM
02/04/18 08:49 PM
Glad to hear you got it fixed and glad you updated your thread. Too many people don't do that.
Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon] #2446642
02/05/18 01:56 AM
02/05/18 01:56 AM
Cleveland Ohio
sportfury70 Offline
sportfury70  Offline
Cleveland Ohio
You replaced crank in chassis? How difficult was that?
Re: 99 V10 engine noise...Bad cats?? [Re: sportfury70] #2446706
02/05/18 04:53 AM
02/05/18 04:53 AM
ND
dodgedon Offline OP
dodgedon  Offline OP
ND
No, I pulled the pan in chassis but when i realized what was wrong I ended up pulling the motor out.
67 Charger 383 auto
Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon] #2447914
02/07/18 10:39 AM
02/07/18 10:39 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Glad to hear that you got it figured out and it's now fixed. up
Re: 99 V10 engine noise...Bad cats?? [Re: dodgedon] #2449030
02/09/18 11:21 AM
02/09/18 11:21 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
....and make sure you use GOOD plug wires and route them correctly. We used to see crossfire hammer rod bearings out of these things.
Page 3 of 3 1 2 3
