Throttle response and Low speed performance in a 440 stick. #2445715
02/03/18 05:02 PM
02/03/18 05:02 PM
ohio
2
2264PLY Offline OP
2264PLY  Offline OP
ohio
My '68 GTX 440 stick 3.54 gear is less than impressive in terms of throttle response and low speed performance. I've experienced this in similar cars owned by friends. They are all basic garden variety 440s. Cam intake headers holleys 10 to 1 compression. The 340 stick cars I've owned seemed to have much better throttle response and low speed performance. THe cam in the GTX is a Comp. 305 Magnum. Used this cam in 440 A/body automatic. And it seemed to work much better. I'm wondering if it's cyl. pressure or duration related. Thought about dropping the intake duration down to 268 adv. and seeing if that makes a difference.Always degree the cams and try different ignition advance combinations.
Re: Throttle response and Low speed performance in a 440 stick. [Re: 2264PLY] #2445719
02/03/18 05:10 PM
02/03/18 05:10 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Need more specifics about the combo.
Re: Throttle response and Low speed performance in a 440 stick. [Re: fast68plymouth] #2445748
02/03/18 06:06 PM
02/03/18 06:06 PM
ohio
2
2264PLY Offline OP
2264PLY  Offline OP
ohio
Hedman 1 3/4 primary tube, Holley list 4780 Performer RPM intake 906 heads KB flat top pistons stock dist. with electronic conversion.Currently have 1 Mr Gasket spring in the dist. At idle its at full advance 34 degrees. I'm looking for someone who's had a similar experience and what changes remedied the situation. Certainly welcome thoughts and opinions.
Re: Throttle response and Low speed performance in a 440 stick. [Re: 2264PLY] #2445752
02/03/18 06:13 PM
02/03/18 06:13 PM
So. Burlington, Vt.
So. Burlington, Vt.
Of you have an adjustable valvetrain, I'd strongly suggest going to a solid cam.
If that's not an option, and you're going to stick with a hyd...... I'd look at taking 20-25deg @.050 out if it.
Something along the lines of a Comp XE274 or XE275HL.
Re: Throttle response and Low speed performance in a 440 stick. [Re: 2264PLY] #2445766
02/03/18 06:30 PM
02/03/18 06:30 PM
ohio
2
2264PLY Offline OP
2264PLY  Offline OP
ohio
Currently stock rockers. A close friend with similar 440 with a stick difference being rpm heads roller rockers with the XE275HL. I didn't ride in his car but we were talking about it and he expressed the same feelings. I definitely respect his opinion.His car did have a 3.91 gear.His engine was also professionally built. He pulled the engine out of his '71 300 which was an automatic and put it in a "69 B body.He felt the motor definitely worked better in front of the automatic. I was thinking the same way you are about the duration. After talking with him I started to wonder about that. Going to a solid cam makes sense.
Re: Throttle response and Low speed performance in a 440 stick. [Re: 2264PLY] #2445807
02/03/18 07:20 PM
02/03/18 07:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
IMHO, too much cam and too big of a carb for good throttle response.
If you want really snappy throttle response, a carb with small bores will give it.
Re: Throttle response and Low speed performance in a 440 stick. [Re: John_Kunkel] #2445829
02/03/18 08:08 PM
02/03/18 08:08 PM
IN
ahy Offline
ahy  Offline
IN
That cam, with 253@.050" duration is bound to be soggy down low with a manual transmission. It would need a high stall an auto with high stall converter and 4.10's to feel strong.
Suggest you go down 20-30 degrees... 222-235 @.050 range to get the low and mid range torque back. A
Re: Throttle response and Low speed performance in a 440 stick. [Re: 2264PLY] #2445857
02/03/18 08:53 PM
02/03/18 08:53 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Could also try advancing the current cam a few degrees if you don't have piston to valve clearance issues.
I ran a Mopar .509 4* advanced in a low compression 440 stick car, even occasionally running it with 2.76's it wasn't objectionably bad.
Re: Throttle response and Low speed performance in a 440 stick. [Re: 2264PLY] #2445880
02/03/18 09:44 PM
02/03/18 09:44 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Assuming you want to keep your axle?
Lighter flywheel
3.09:1 1st gear
Boffin Emeritus
Re: Throttle response and Low speed performance in a 440 stick. [Re: 2264PLY] #2446013
02/04/18 01:50 AM
02/04/18 01:50 AM
ohio
2
2264PLY Offline OP
2264PLY  Offline OP
ohio
A few things have gone through my mind. The weight of the rotating assembly and the length of the stroke. I've had 383s that had better throttle response and low speed performance. I've thought about advancing the cam. I've had good results with that in the past. It's a heavy car and I'd like to keep the 3.54 gear in it. That in itself presents a bit of a challenge. In this situation it seems like the automatic is more forgiving. Anxious to try some different things and hoping to get the chance soon.
Re: Throttle response and Low speed performance in a 440 stick. [Re: 2264PLY] #2446072
02/04/18 05:14 AM
02/04/18 05:14 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Just curious as to how tall the rear tires are ? Ron
Re: Throttle response and Low speed performance in a 440 stick. [Re: 2264PLY] #2446074
02/04/18 05:19 AM
02/04/18 05:19 AM
There are a bunch of things that can make a motor not accelerate well like to rich at part throttle, valve lifters with not enough preload or to much preload, degreeing the cam off of the exhaust lifter instead of the intake lifter blush, not enough advance at low RPM on the ignition timing, to cold on the heat range on the spark plugs and probably some others that aren't coming to mind right now shruggy
How tall are your rear tires now?
Is your NP 833 a 2.65 low gear set or is it the later 2.2? low gear set work As already suggested using a lower first gear ratio like the stock 3.09 low gear set makes a bunch of difference on the street shruggy
Been there done that years ago when the early A body trans. where plentiful in our local SO CA junk yards up
I put one of those gear sets in a friend of mines 1970 Duster 340 4 speed street race car that ended up with a set of 5.57 rear gears in the Dana 60 , you needed to be on your game on the first three gear changes in that rascal boogie grin It flat hooked and book with a set of 13x30x15 drag slicks on a set of 12 inch rims devil
It showed a bunch of BB Chevy the tail lights on lots of occasions devil
Re: Throttle response and Low speed performance in a 440 stick. [Re: 2264PLY] #2446093
02/04/18 10:44 AM
02/04/18 10:44 AM
gregsdart Offline
gregsdart  Offline
Calculate the cranking compression to see how much that cam is hurting you for starters. Best off idle will be helped a great deal by coming up with a combo of cam, compression, and cam installed centerline that will be as high as the fuel you use can take.
Re: Throttle response and Low speed performance in a 440 stick. [Re: 2264PLY] #2446099
02/04/18 10:55 AM
02/04/18 10:55 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
What is your cylinder pressure? Get that first so we know what your working with.
My friend's 68 4 speed GTX w/ 3.54 drove like it was on ice in 1st gear. Small cam, fairly low cylinder pressure, good factory heads, factory spreadbore intake and matching carb. Car was a blast on the street. That being said, it really wasn't that fast at the track, so don't confuse the two, as they may or may not be the same thing.
Re: Throttle response and Low speed performance in a 440 stick. [Re: 2264PLY] #2446339
02/04/18 05:18 PM
02/04/18 05:18 PM
ohio
2
2264PLY Offline OP
2264PLY  Offline OP
ohio
I haven't checked the cranking compression.The rear tire is a 275/60/R15.The trans is an older 18 spline which I believe has the original 1st gear in it. I'm guilty of tuning it like my automatics.The post has opened up my mind a little more. I just have to do the homework.
Re: Throttle response and Low speed performance in a 440 stick. [Re: Cab_Burge] #2446373
02/04/18 05:56 PM
02/04/18 05:56 PM
Washington
madscientist Offline
Washington
I put one of those gear sets in a friend of mines 1970 Duster 340 4 speed street race car that ended up with a set of 5.57 rear gears in the Dana 60 , you needed to be on your game on the first three gear changes in that rascal boogie grin It flat hooked anjd book with a set of 13x30x15 drag slicks on a set of 12 inch rims devil
The 70 and later 4 speeds has a 2.44 first.
Re: Throttle response and Low speed performance in a 440 stick. [Re: 2264PLY] #2446377
02/04/18 06:11 PM
02/04/18 06:11 PM
Minn
SportF Offline
SportF  Offline
Minn
A lot of sophisticated answers here. Why not try something real easy like bumping that timing up to 36-38 degrees. Just try it. Then work on the acceleration rich factor.
Re: Throttle response and Low speed performance in a 440 stick. [Re: madscientist] #2446385
02/04/18 06:24 PM
02/04/18 06:24 PM
The 70 and later 4 speeds has a 2.44 first. [/quote]
Not true tsk Only the T/A and AAR Cuda 4 speed cars had the close ratio stock in 1970, all 1971 and later 4 speed cars had them until Corporate decided to go to the NP833 O.D. trannys in what ever year that was shruggy
Re: Throttle response and Low speed performance in a 440 stick. [Re: 2264PLY] #2446388
02/04/18 06:27 PM
02/04/18 06:27 PM
Kirkland, Washington
Pacnorthcuda Offline
2264Ply-- can you expand a little on "low speed performance" in terms of RPM?
Are we talking 2000 or 3000 rpm or something else altogether. Are you talking about the engine actually lugging? At what RPM?
Is there an RPM where you powerband comes on and the engine starts to pull fine? If so, what RPM?
Re: Throttle response and Low speed performance in a 440 stick. [Re: Cab_Burge] #2446424
02/04/18 07:27 PM
02/04/18 07:27 PM
Washington
Washington
Not true tsk Only the T/A and AAR Cuda 4 speed cars had the close ratio stock in 1970, all 1971 and later 4 speed cars had them until Corporate decided to go to the NP833 O.D. trannys in what ever year that was shruggy [/quote]
My point is there never was a 2.2 first gear 833. Ever. Look at what I quoted.
