Re: trans case number on 69 cuda m-code cars
[Re: cudaman1969]
#244558
03/05/09 11:07 PM
03/05/09 11:07 PM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
the 093 is correct, the 091 is for a 383 4bbl with A/C
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
[Re: cudaman1969]
#244566
03/06/09 01:15 AM
03/06/09 01:15 AM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
it all depends if hurst just added the engine with the trans still in the car or they got engine and trans together from the factory. and by the way 69 a12s where just stock 440s with a good intake and carbs 70 got all the good stuff in the engine. but i stiil like em
69 A12's were faster!
[Re: cudaman1969]
#244567
03/06/09 10:17 AM
03/06/09 10:17 AM
Posts: 75,088 A Banana Republic near you.
JohnRR
70 got all the GOOD stuff ??? The heavy rods SLOWED the 70 down ...
Line up a 69 against a 70 and let the azz kickin' BEGIN ....
When it comes to 6pk cars , A12's are KING of the MOUNTAIN.
Where's Rhinodart , he can put this one to rest .
[Re: AZ_A12_BEE]
#244571
03/06/09 02:31 PM
03/06/09 02:31 PM
Posts: 8,948 Harlan, Iowa
69CoronetRT
Harlan, Iowa
I'm looking at the Chrysler parts manual. All the 383HP/440HP B Body and bigger cars came with the 093. The Valiant/Barracuda/Dart with 383 4 BBL came with an 091 in them. It was considered an A727B as was the 093 trans. They do not show a 383HP or 440HP listing for an A Body? Only a 383 4 BBL. They just say that the Satellite/Coronet w/383HP and 440HP eng, the Chrysler w/440 HP and the Ply/Dodge except SW w/440 and HP engines had the A727B p/n 2892093. It seems like the M code should have had an 093 in it because it was behind a 440HP?
John, the 091 trans is for 383 4 bbl A/C cars, since M code A bodies cannot have A/C it would not have that trans in it even if the car started out as a 383 car and the 440 was put in by an outside vendor
Seeking:
1969 St. Louis plant VINs, SPD, and VONs. Over 2,000 thanks to you!
[Re: 69CoronetRT]
#244572
03/06/09 02:43 PM
03/06/09 02:43 PM
JohnRR
Doooooh ....
[Re: charge70]
#244575
03/06/09 06:32 PM
03/06/09 06:32 PM
Posts: 1,187 USA
big-block-dave
USA
Guys, i have started a '69 M-code A-body 40th reunion at Carlisle in July. Watch carlisleevents.com soon for a sign up to bring your car!! Other ads maybe on this site, other mopar websites and 3 of the 4 mopars mags. Any M-code A-bodies can email me at mcodecuda@yahoo.com for more info and a invite/informational letter mailed to you!! I'm also in the process of reproducing the right side exhaust spacer that goes inbetween the manifold and head pipe! HELP SPREAD THE WORD!!!!! Dave
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
