Re: Victor or Trickflow heads most bang for the buck?
[Re: Digger73]
#2445734
02/03/18 05:51 PM
02/03/18 05:51 PM
Posts: 304 Portland, Oregon
Digger73
Portland, Oregon
Yes I have the Super Victor #2891. In fact I bought it from Andy a few years ago. You fellas have made my day. I was thinking that to change heads was a money pit that my better half would squawk about. If I can use my bolt on parts I have then I will have new heads on the way shortly. If I decide to port the manifold, how far up will I need to go in the runner?
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
[Re: 451Mopar]
#2445772
02/03/18 06:41 PM
02/03/18 06:41 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
) B1Bs head only flows 295 cfm a
My heads didn't get close to that number. OOTB. Mine were in the 270 range, ootb. They are respectable after DP worked them. But no way Id buy another set, ever. They had their place...many moons ago.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Von]
#2445783
02/03/18 07:00 PM
02/03/18 07:00 PM
Posts: 20,202 PA.
pittsburghracer
"Little"John
"Little"John
PA.
My good friend has been running 8.60’s-8.80’s for years in his charger so B1BS heads in the right hands work pretty good
[Re: BradH]
#2445858
02/03/18 08:56 PM
02/03/18 08:56 PM
Digger73
Portland, Oregon
I think the OP should consider a different cam to go with the new heads, etc. What cam would you recommend? Right now I am thinking that I need to concentrate on the heads then do more upgrades at a later date. I was thinking about some 1.6 or even 1.7 rockers with the cam that I have? Digger73 (Mike)
[Re: AndyF]
#2446063
02/04/18 04:24 AM
02/04/18 04:24 AM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
Read the 270 articles that I've written and study the pictures. You'll see that I used standard offset rocker arms on the 270 heads and that I've used a standard port intake on the 270 heads.
It might not be "ideal" but it can get you up and running and then6 you can upgrade from there. Andy , You say you used an offset rocker . Trickflow on Summit show Harland Sharp S70015KE , which lists for a Edelbrock rpm on HS site Victors are listed as using S70015EVK which are .650 offset So do the 270s use non offset or offset ? Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2446127
02/04/18 12:09 PM
02/04/18 12:09 PM
Posts: 4,287 Morrow, OH
markz528
Morrow, OH
It might not be "ideal" but it can get you up and running and then6 you can upgrade from there. Andy , You say you used an offset rocker . Trickflow on Summit show Harland Sharp S70015KE , which lists for a Edelbrock rpm on HS site Victors are listed as using S70015EVK which are .650 offset So do the 270s use non offset or offset ? Tex Not offset. S700115KE supposedly corrects geometry issues with the Trick Flos. Just bought a set.
[Re: tex013]
#2446214
02/04/18 02:26 PM
02/04/18 02:26 PM
Posts: 31,077 Oregon
AndyF
It might not be "ideal" but it can get you up and running and then6 you can upgrade from there. Andy , You say you used an offset rocker . Trickflow on Summit show Harland Sharp S70015KE , which lists for a Edelbrock rpm on HS site Victors are listed as using S70015EVK which are .650 offset So do the 270s use non offset or offset ? Tex I said "standard offset".
[Re: Sport440]
#2446219
02/04/18 02:30 PM
02/04/18 02:30 PM
Thumperdart
State of confusion
I agree that 280*/283* @ .050 is rather large for your 11.5 comp. With a mechanical roller, something between 265/270 on the intake with .650 lift should be a better fit. IMO I wouldn't even Try to use that big cam you have, don't bother IMO. Mikey's 470 that Pettis built w.11.7? comp has a monster(to some)cam and I think is even bigger than this one and he's flying w/an 1150 dommy I did and has a string of 6.0's and 9.50's...........My turd has 276-281 @ .050 and is an easy docile car to drive street/strip........... ![drive drive](/ubbthreads/images/graemlins/custom/drive.gif)
[Re: Von]
#2446397
02/04/18 06:48 PM
02/04/18 06:48 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
My heads didn't get close to that number. OOTB. Mine were in the 270 range, ootb. They are respectable after DP worked them. But no way Id buy another set, ever. They had their place...many moons ago. I was quoting the flow advertised from Brodix. I was a bit curious about the 295 cfm rating too, but maybe they made a few changes in the last 25+ years from when I bought my set. I think the heads I bought were from the second batch of castings, and were not drilled in the front for accessories. I bought them from Koffels with stage I porting (kind of like port and bowl clean-up work), 1.6:1 ratio rocker arms, and cut to length pushrods and I think the bill was right about $3,000 (around 2001?) A few years ago I had them tested on the flow bench, and I think they flowed about 298 cfm?
[Re: AndyF]
#2446406
02/04/18 06:56 PM
02/04/18 06:56 PM
tex013
Sydney,Australia
Andy , I misunderstood . "What rocker arms do you have now? The 270 uses standard rocker arms so what you have might work." OP has Crane rockers for standard port Stealth heads . Thanks for your input
Tex
[Re: markz528]
#2446410
02/04/18 07:02 PM
02/04/18 07:02 PM
tex013
Sydney,Australia
It might not be "ideal" but it can get you up and running and then6 you can upgrade from there. Andy , You say you used an offset rocker . Trickflow on Summit show Harland Sharp S70015KE , which lists for a Edelbrock rpm on HS site Victors are listed as using S70015EVK which are .650 offset So do the 270s use non offset or offset ? Tex Not offset. S700115KE supposedly corrects geometry issues with the Trick Flos. Just bought a set. Thanks markz528 So you could possibly use the Crane standard rocker if geometry works ? I know it sounds like I am beating this to death BUT if I go this way I am looking at over $1300 of my quality Aussie dollars plus shipping . Tex
[Re: Digger73]
#2446419
02/04/18 07:16 PM
02/04/18 07:16 PM
fast68plymouth
So. Burlington, Vt.
Just to keep things off topic.......
I haven't had a B1BS in the shop in quite a long time. As I recall, ootb they did flow close to 290...... But didn't get near that until .700 lift.
One thing I remember about the first one I tested was, the low/mid-lift flow was so bad I stopped about 1/2 way through the test to make sure there wasn't a problem with the bench. I couldn't believe that an aftermarket head with a 2.20 intake valve could be that bad.
I ended up getting them to work pretty well...... Around 320@.700 while keeping the runner fairly small, and making some nice improvements in the low/mid flow.
On a flat top 446 in a 3900lb car they were good enough to let the car run high 10.40's with a single 850, and high 10.20's@130 with the MP TR and 2 x 750's on it.
[Re: tex013]
#2446461
02/04/18 08:21 PM
02/04/18 08:21 PM
markz528
Morrow, OH
It might not be "ideal" but it can get you up and running and then6 you can upgrade from there. Andy , You say you used an offset rocker . Trickflow on Summit show Harland Sharp S70015KE , which lists for a Edelbrock rpm on HS site Victors are listed as using S70015EVK which are .650 offset So do the 270s use non offset or offset ? Tex Not offset. S700115KE supposedly corrects geometry issues with the Trick Flos. Just bought a set. Thanks markz528 So you could possibly use the Crane standard rocker if geometry works ? I know it sounds like I am beating this to death BUT if I go this way I am looking at over $1300 of my quality Aussie dollars plus shipping . Tex You can use them if you can tolerate the geometry. The Harlan Sharp are expensive - around $950 standard price!
[Re: Digger73]
#2446492
02/04/18 08:57 PM
02/04/18 08:57 PM
fast68plymouth
So. Burlington, Vt.
“ in theory” the HS “E” rockers are basically the same length as the Crane golds.
[Re: fast68plymouth]
#2446495
02/04/18 09:02 PM
02/04/18 09:02 PM
AndyF
Yes or use the Mancini rocker arms. The Mancini rocker arms are a copy of the old Crane rocker arms. They are made by Harland for Mancini as a low end rocker arm. They work on the Trick Flow heads but are unbushed and probably won't last a super long time. But some race cars only make a few passes a year so in a situation like that they could last a life time.
