Re: 1621-16 ultra pro magnum rockers convert to ball adjusters? [Re: lockjaw-express] #2448516
02/08/18 02:38 PM
02/08/18 02:38 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Thank you for all of your assistance!
Glad it all worked out well for you up
Re: 1621-16 ultra pro magnum rockers convert to ball adjusters? [Re: lockjaw-express] #2448660
02/08/18 07:33 PM
02/08/18 07:33 PM
Ohio
lockjaw-express Offline OP
Ohio
No, the cam sheet that I got from Randy B's cam card...I have not yet tried to measure at the retainer.
Re: 1621-16 ultra pro magnum rockers convert to ball adjusters? [Re: fast68plymouth] #2686331
08/10/19 07:09 PM
08/10/19 07:09 PM
wi
Furys Offline
Furys  Offline
wi
could you tell me how many threads you have showing or how far the ball adjuster is out odf the rocker arm,I have the 1621,s and am just now going to try to getpushrod length,I heard the oil hole in the center of the adjuster must line up with the hole inside the rocker,is this true or does oil find its way throught the threads to the holes if they are not alighned,any help with this if you can,thanx
Re: 1621-16 ultra pro magnum rockers convert to ball adjusters? [Re: Furys] #2686359
08/10/19 08:55 PM
08/10/19 08:55 PM
Quote
Read Mike Beachels geometry papers at B3 raceing & there is a utube vid on it, in a nutshell he wants a 90 deg (right) angle between rocker/valve at 1/2 lift, gives the most area under the curve & he wants minimal (~.050" iirc) & centered wipe pattern on the valve tip for minimal wear.
Re: 1621-16 ultra pro magnum rockers convert to ball adjusters? [Re: lockjaw-express] #2687228
08/13/19 12:47 PM
08/13/19 12:47 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I have no doubt Mr. Borowski would approve, as long as you're having fun with it!
You've really made some nice improvements to the car up
That's me in the other lane. What a great time we had that day. RIP Randy.
https://www.youtube.com/watch?v=eq8Rmz3ErsA
Rich H.
Esse Quam Videri
