Re: Cooling system plumbed with AN fittings [Re: cl440] #2456196
02/23/18 03:49 PM
02/23/18 03:49 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I had the radiator custom made for my application.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Cooling system plumbed with AN fittings [Re: Forest] #2456249
02/23/18 05:25 PM
02/23/18 05:25 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Originally Posted By Forest
I haven't ran this setup yet, but its dual -12 an hoses with a Meziere radiator mounted pump and Meziere adapters on the motor plate..
This I like.
Re: Cooling system plumbed with AN fittings [Re: 6PKRTSE] #2456511
02/24/18 03:22 AM
02/24/18 03:22 AM
Portland, Oregon
Digger73 Offline
Digger73  Offline
Portland, Oregon
If the picture works this is what I did.
I had fittings welded to the motor plate and installed the AN adapters and plumbed the radiator mounted pump to the front of the radiator.
Not sure if it works yet should be on the track this year.
Digger73 (Mike)
I live with fear everyday but, sometimes she lets me race!
Re: Cooling system plumbed with AN fittings [Re: CMcAllister] #3220080
03/13/24 07:14 AM
03/13/24 07:14 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Originally Posted by CMcAllister
This I like.
iagree...killer setup here upWondering if he'd still a member here work
Re: Cooling system plumbed with AN fittings [Re: racerx] #3220492
03/14/24 09:20 PM
03/14/24 09:20 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
I am but I no longer have the car...
Re: Cooling system plumbed with AN fittings [Re: Forest] #3220536
03/15/24 05:19 AM
03/15/24 05:19 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Re: Cooling system plumbed with AN fittings [Re: racerx] #3220538
03/15/24 06:34 AM
03/15/24 06:34 AM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
AN16 works fantastic for upper and lower radiator lines. I use 16 for the upper and lower radiator hoses and 12 for the lines from the water pump to the block. I run a remote mount Meziere pump. Many street driving miles as well as track passes with no issues ever.
Re: Cooling system plumbed with AN fittings [Re: racerx] #3220540
03/15/24 06:40 AM
03/15/24 06:40 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
The 150's work fine for me but I used Earl's 3/4 pushlock non-braided rubber on -12 ends at the radiator. NPT to barb with hose clamps buried beneath the accessories at the Indy rev motorplate SBC waterpump adapter. The inlet is a conventional -20 where I welded male fittings to the rad and and waterpump tube.
Re: Cooling system plumbed with AN fittings [Re: STEFF] #3220541
03/15/24 06:46 AM
03/15/24 06:46 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
A remote mount pump is so much better. I keep saying I'll retrofit one to mine but for now I don't want to deal with the packaging changes and it'll be tight. When you have a Jesel timing belt, it makes the most sense but seeing the timing marks, priming the pump and service are some of the reasons as well.
Re: Cooling system plumbed with AN fittings [Re: HardcoreB] #3220569
03/15/24 10:31 AM
03/15/24 10:31 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have won at many car shows and cruise nights for my plumbing and engine bay detailing. I didn't even know that was a thing until I won several times??? Lol.
Re: Cooling system plumbed with AN fittings [Re: 6PKRTSE] #3220580
03/15/24 11:14 AM
03/15/24 11:14 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We have done it on I think 6 of our cars so far. No issues at all. Usually use a radiator mounted pump but have also used remote pumps on the dragsters.
