Page 2 of 4 1 2 3 4
Re: electric fuel pump set up [Re: 383man] #2436131
01/17/18 03:11 AM
01/17/18 03:11 AM
las vegas,nv
mopar muscle7271 Offline OP
las vegas,nv
Thanks that be cool,im no hurry for it.
Re: electric fuel pump set up [Re: mopar muscle7271] #2436185
01/17/18 10:03 AM
01/17/18 10:03 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I have mine mounted on the inside of the rear frame rails along side the fuel cell. I have filters mounted to the rear frame crossmember between the cell and pumps. As you can see the pumps are lower than the cell, so I have gravity feed. I have the relays inside the trunk and run the main feed off the battery cut-off switch. I have the switches in the dash and plummed through the oil pressure cut-out switch (Holley if I remember correctly). It only takes about a 3 amp fuse for at the switches. Wire it as safely as you possibly can!
Re: electric fuel pump set up [Re: mopar muscle7271] #2436195
01/17/18 10:41 AM
01/17/18 10:41 AM
las vegas,nv
las vegas,nv
I never would never wire the on/off switch like that.it should be wired underneath the dash.
Re: electric fuel pump set up [Re: mopar muscle7271] #2436202
01/17/18 11:02 AM
01/17/18 11:02 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Not sure who your replying to...
If it was this reply, maybe you should read what he said.
70HemiGTX
If you're referring to the switch in the pic it's a battery disconnect which is required at the track if you have a trunk mounted battery.
From your replies, You just might be better off paying someone who actually knows what they're doing to work on your car. whistling
Re: electric fuel pump set up [Re: SNK-EYZ] #2436626
01/17/18 11:41 PM
01/17/18 11:41 PM
las vegas,nv
las vegas,nv
Ok i know people who still have that switch by there dash frame to.
Re: electric fuel pump set up [Re: mopar muscle7271] #2436726
01/18/18 05:27 AM
01/18/18 05:27 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Then you know people who don't know how to properly wire things on a car.
Copying them would be a very bad idea, unless you want to show us how Darwinism really works. whistling
Re: electric fuel pump set up [Re: mopar muscle7271] #2437338
01/19/18 06:24 AM
01/19/18 06:24 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Sorry as we got snow yesterday so it may be a few days before I can try and get a pic for you. Ron
Re: electric fuel pump set up [Re: 383man] #2437729
01/19/18 11:36 PM
01/19/18 11:36 PM
las vegas,nv
las vegas,nv
Ok no rush ,whenever you have a chance to.
Re: electric fuel pump set up [Re: mopar muscle7271] #2437783
01/20/18 01:37 AM
01/20/18 01:37 AM
n.c.
geo. Offline
geo.  Offline
n.c.
Lots of good info. here!
My '70 Challenger was set up with the Holley blue pump ABOVE the fuel cell, on its side in the trunk. The previous owner built it this way, I've had the car 20 years, and the pump finally needed a new check valve this year. Do I recommend this? NO! but it has worked fine for a long time. If I was starting from scratch I'd try to lower the pump, but if it aint broken.....
Back in the late '70s a friend put a delco pump in the engine compartment of his Barracuda, worked fine 'till it heated up and then car would starve for fuel, DON'T put it there!
Find a spot as close to the tank as you can.
Re: electric fuel pump set up [Re: 383man] #2442246
01/28/18 03:04 PM
01/28/18 03:04 PM
las vegas,nv
las vegas,nv
were you ever able to get a pic of your electric fuel pump setup?
Re: electric fuel pump set up [Re: mopar muscle7271] #2442290
01/28/18 04:17 PM
01/28/18 04:17 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Just mount it near the fuel tank like everyone said already twocents
All cars and exhaust systems are different so you will have to figure the best place for your application. I mounted mine on the right rear frame rail but if you have a full exhaust that might not work for you. shruggy
Gus
64 Plymouth Savoy
Dana 60
Re: electric fuel pump set up [Re: fourgearsavoy] #2442307
01/28/18 04:41 PM
01/28/18 04:41 PM
las vegas,nv
las vegas,nv
I don't have exhausts i got turn downs at the end of the mufflers.
Re: electric fuel pump set up [Re: mopar muscle7271] #2442366
01/28/18 06:44 PM
01/28/18 06:44 PM
Rittman Ohio
Rittman Ohio
Did you Google images of this project? There are hundreds of pictures showing how to mount them.
64 Plymouth Savoy
Dana 60
Re: electric fuel pump set up [Re: mopar muscle7271] #2442430
01/28/18 08:44 PM
01/28/18 08:44 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
All wire-cables should be as short as possible when carring a lot of amps, wire that pump to a regular starter relay, mounted in the trunk, then just run a ground wire to the dash switch, no amps, no power loss. I put my pump-pumps-filter behind the fuel cell or tank on RACE cars, If just going to shows, a regular engine fuel pump will be enough, why a noisy electric?
Re: electric fuel pump set up [Re: cudaman1969] #2442507
01/28/18 10:22 PM
01/28/18 10:22 PM
las vegas,nv
las vegas,nv
I need a electric pump givin it gas at all times.i tried a regular pump,couldn't get no gas anymore goin to carb.the Pump was new as well. i had to put a air compressor hose down the tank with compressor on to give it gas at all times.l like the sound of a electric pump. Im running a 850 demon mighty carb to.they need alot of gas,so it doesn't starve for fuel.
Re: electric fuel pump set up [Re: mopar muscle7271] #2442558
01/29/18 12:05 AM
01/29/18 12:05 AM
fredericksburg,va
fredericksburg,va
Not being rude but you got big problems somewhere, the NASCAR guys used a mechanical pump and ran 200 mph on 800 hp engines, never had a problem keeping their carb full.
Re: electric fuel pump set up [Re: cudaman1969] #2442570
01/29/18 12:17 AM
01/29/18 12:17 AM
I have seen a cable driven mechanical fuel pump feed a 2500+ HP supercharged motor shruggy
Re: electric fuel pump set up [Re: mopar muscle7271] #2442575
01/29/18 12:27 AM
01/29/18 12:27 AM
las vegas,nv
las vegas,nv
Its my car i can put a electric fuel pump on if i want to,i ask how to set one up.not to told to put a junk pos stock mechanical pump on.further more i have no big problems somewhere.
Re: electric fuel pump set up [Re: mopar muscle7271] #2442643
01/29/18 01:42 AM
01/29/18 01:42 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Bolt a plate big enough to hold the fuel pump to the frame rail in a safe location between the rear axle and the tank. You can power the fuel pump through an ignition hot power source, but it won't run the pump until the ignition switch is in the rum position. That is the way I run mine. Powered this way, the pump will run whenever the key is in the run position. If you wreck the car, turn off the ignition switch. If you set the power source up with a relay and ground the relay through the oil pressure switch, the pump won't run until the motor has oil pressure, and it won't run if you loose oil pressure, a pretty good safety feature.
Mount the pump so it is below the fuel line coming out of the tank, then have the electric fuel pump mount mounted so that then inlet (coming from the tank) on the pump is slightly below the level of the outlet. What this will do is assure the inlet is covered with fuel as soon as it is turned on. If there is fuel the pump can pick up, having fuel at the inlet upon powering the pump will allow the pump to pull the fuel into the pump. A pump without defects will last a long time. Gene
Re: electric fuel pump set up [Re: mopar muscle7271] #2442758
01/29/18 09:35 AM
01/29/18 09:35 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Sounds more like you need either a new gas tank, pick-up, fuel line, or maybe even all 3. If you needed to use compressed air to get gas to your carb., an electric pump will not do it for you. By using the compressed air, you pressurized your gas tank, forcing the gas out the easiest exit. How much psi did you use to get gas to flow? Yes you need to mount your fuel pump below the tank, BUT from your tank to the pump is gravity feed. You will starve your electric pump if you do not have a full flow of fuel to the pump.
Do what you want. Guys on here are just answering YOUR question and pointing out problems that you could possibly run into. Simply because they have seen or had these problems sometime in life.
Have fun!
Page 2 of 4 1 2 3 4
