Page 3 of 4 1 2 3 4
Re: electric fuel pump set up [Re: 70HemiGTX] #2442793
01/29/18 11:28 AM
01/29/18 11:28 AM
las vegas,nv
mopar muscle7271 Online content OP
mopar muscle7271  Online Content OP
las vegas,nv
I don't need all three your full of crap.it was working good the pump then stop working.i clean the tank out and sealed it.some of you over act.
Re: electric fuel pump set up [Re: mopar muscle7271] #2442808
01/29/18 12:06 PM
01/29/18 12:06 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Maybe you don't actually have a clue of what you're doing.
If you have to pressurize the tank to get fuel up to the front there's a problem.
You say you've cleaned and coated the tank.
Well then either the sending unit(tank pick up) or the fuel line has a restriction in them.
Putting on am electric pump won't fix that.
You ask people what they think, then argue with their replies on how to fix your car. realcrazy
Re: electric fuel pump set up [Re: mopar muscle7271] #2442879
01/29/18 02:53 PM
01/29/18 02:53 PM
las vegas,nv
las vegas,nv
No i have a clue,there replies are full of bs,just like yours to.
Re: electric fuel pump set up [Re: mopar muscle7271] #2442884
01/29/18 03:02 PM
01/29/18 03:02 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If you are so sure then why bother asking for advise. Just go ahead a do what you want. Then come back and tell us how that worked out for you. As for BS some of the guys answering you have worked on these cars longer than you have been alive.
Re: electric fuel pump set up [Re: stumpy] #2442901
01/29/18 03:31 PM
01/29/18 03:31 PM
las vegas,nv
las vegas,nv
When a fuel pump goes bad,its obvious i had a bad pump.i can check my pick up line and sending unit.i know for a fact there is nothing wrong with them.when i clean my tank out and sealed the inside of it i put a new sending unit in as well to.
Re: electric fuel pump set up [Re: mopar muscle7271] #2442925
01/29/18 04:16 PM
01/29/18 04:16 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Looks one of the facebook mopar "experts" found his way to Moparts..
Prob one of the same guys trying to clown the 600HP FAST motor for sale on one of the fb forums....
Re: electric fuel pump set up [Re: mopar muscle7271] #2442943
01/29/18 04:50 PM
01/29/18 04:50 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Call Worman at JYC, he'll fix you up, very knowledgable.
Re: electric fuel pump set up [Re: mopar muscle7271] #2442964
01/29/18 05:22 PM
01/29/18 05:22 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Have fun.
Re: electric fuel pump set up [Re: mopar muscle7271] #2442999
01/29/18 06:51 PM
01/29/18 06:51 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
With every reply that you make you prove a little more to everyone on here that you have no idea what you're doing working on a car.
If you actually want to fix the problem, listen to what the people on here recommend that you do.
Just because you have a new sending unit doesn't mean that there isn't a problem (restriction) with it.
From your description there's a restriction keeping the fuel from getting to the engine.
Re: electric fuel pump set up [Re: mopar muscle7271] #2443048
01/29/18 08:33 PM
01/29/18 08:33 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I almost believe our collective leg is being pulled.
Re: electric fuel pump set up [Re: mopar muscle7271] #2443198
01/30/18 02:07 AM
01/30/18 02:07 AM
las vegas,nv
las vegas,nv
Re: electric fuel pump set up [Re: mopar muscle7271] #2443207
01/30/18 02:41 AM
01/30/18 02:41 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
we know who the troll is and he came here asking for help and seems to know it all and won't bother to listen to good advice. Just wants to runs his mouth. Dude give it a rest.
Re: electric fuel pump set up [Re: stumpy] #2443225
01/30/18 03:15 AM
01/30/18 03:15 AM
las vegas,nv
las vegas,nv
You give it a rest,to the ones who said where to mount the pump and how thanks.the others are useless bs trolls with worthless advice who like to agrue.
Re: electric fuel pump set up [Re: mopar muscle7271] #2443258
01/30/18 04:19 AM
01/30/18 04:19 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
So says the troll. laugh2
You've been told where to mount the pump, just in front of the fuel tank in the area near the rear axle.
StealthWedge67 even posted a pic of his set up.
You kept going on about wanting to mount it in the engine compartment, even after people told you not to mount it there.
You bash people who said you could run a mechanical pump.
No one said stock pump they said mechanical pump, there is a difference.
I ran a carter mechanical fuel pump on the 572 Hemi with two 750 carbs on it in my last car and didn't have fuel supply issues.
Original tank, new sending unit and new 3/8ths fuel line.
You said
I need a electric pump givin it gas at all times.i tried a regular pump,couldn't get no gas anymore goin to carb.the Pump was new as well. i had to put a air compressor hose down the tank with compressor on to give it gas at all times.l like the sound of a electric pump. Im running a 850 demon mighty carb to.they need alot of gas,so it doesn't starve for fuel.
If you have to pressurize the tank to get fuel to flow out of it there's a problem that an electric pump isn't going to cure.
If you don't understand it by now, I can't draw a picture on here with crayons so that you can understand it any better.
Take your car to someone who's an adult and qualified to work on your car, obviously you're not. whistling
Re: electric fuel pump set up [Re: SNK-EYZ] #2443389
01/30/18 02:01 PM
01/30/18 02:01 PM
moparx Offline
moparx  Offline
if an air supply is needed to pressurize the tank to get fuel to the carb, just get one of those hand pumps that were used extensively in pre-ww2 hot rods. .............. biggrin i'm not an expert, as i have only been playin' with this junk since 1959 with my grandpa.
beer
Re: electric fuel pump set up [Re: mopar muscle7271] #2443504
01/30/18 04:29 PM
01/30/18 04:29 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Getn better than a soap opra
Re: electric fuel pump set up [Re: mopar muscle7271] #2443513
01/30/18 04:45 PM
01/30/18 04:45 PM
las vegas,nv
las vegas,nv
So funny i forgot to laugh,how dumb.
Re: electric fuel pump set up [Re: SNK-EYZ] #2443515
01/30/18 04:49 PM
01/30/18 04:49 PM
las vegas,nv
las vegas,nv
Im not bashing anyone who does,i see a mechanical pump is another name for the high volume fuel pump.
Re: electric fuel pump set up [Re: mopar muscle7271] #2443591
01/30/18 07:00 PM
01/30/18 07:00 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Nobody and I mean nobody of this Mopar site wants to see you or your car fail. We want it to be top notch to show off that Mopar, everything that's been said to help your car is true so please believe us when we ask questions or make suggestions.
There are many many years of experience and knowledge on here, let us help.
Re: electric fuel pump set up [Re: mopar muscle7271] #2443630
01/30/18 08:10 PM
01/30/18 08:10 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
🤔. Huh??
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Page 3 of 4 1 2 3 4
