Re: What device 2 mount Tach on column the old school way?
[Re: fullmetaljacket]
#2441310
01/27/18 01:04 AM
01/27/18 01:04 AM
Posts: 11,769 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
That's what we used. Don't forget the prism tape on the dash, the Kraco 8 track, woodpecker header mufflers, the rear end housing painted white and air shocks pumped up to 150# so the M50s don't rub.
#2441431
01/27/18 12:18 PM
01/27/18 12:18 PM
Posts: 12,326 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have the tach mounted on the column of my current Cuda the same way that I had it mounted on my first car back in the early 70s. Radiator clamp.
Back then I used black electrical tape under it to keep from scratching the column's paint. Today, I slip the clamp into some heat shrink.
Master, again and still
[Re: lockjaw-express]
#2441492
01/27/18 02:19 PM
01/27/18 02:19 PM
Posts: 4,993 new jersey usa
11secdart
new jersey usa
Hose clamp on my Dart been there for over 35 years!
[Re: moparts]
#2441601
01/27/18 05:07 PM
01/27/18 05:07 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
That's what we used. Don't forget the prism tape on the dash, the Kraco 8 track, woodpecker header mufflers, the rear end housing painted white and air shocks pumped up to 150# so the M50s don't rub. McCreary M50's hanging out of the wheel well , with shackles so long that they had to remove the rear valence on my Challenger R/T when I first bought it. He did say "period correct".
#2441655
01/27/18 06:34 PM
01/27/18 06:34 PM
Posts: 1,896 Spahn Ranch
RMCHRGR
Spahn Ranch
What kind of tach is he using Lee? Hopefully a Sun or SW! This is as old-school as it gets. Obviously the column mount one has the curved bottom... yes, I said curved bottom. SK has large T-bolt clamps if he wants something other than a hose clamp.
'71 Duster '72 Challenger '17 Ram 1500
[Re: RMCHRGR]
#2441741
01/27/18 10:21 PM
01/27/18 10:21 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
wrap a thin piece of rubber under the hose clamp and don't forget traction bars!
Hell Hath No Fury Like Mine
