Re: everything you never wanted to know about 904's [Re: Mcode69] #24417
05/28/06 04:55 PM
05/28/06 04:55 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I wish to thank all the contributers of this post. I don't get to build 904/998/999's very often, and this is very good information from real world school of hard knocks. I had my own 904 5 clutch, roller E/SA debacle back in the late 80's that left a trail of broken parts behind it, and it left a bad taste since then. (I did end up with a shelf of cores and parts though. ) Thanks again.
Re: everything you never wanted to know about 904's [Re: Leigh] #24418
05/28/06 08:15 PM
05/28/06 08:15 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Good stuff here, I'll archive this one
If anyone has more tips or pictures to add
please do so
Re: everything you never wanted to know about 904's [Re: ZIPPY] #24419
05/28/06 08:26 PM
05/28/06 08:26 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
one other thing to concider is the drilling of a 1/16 hole from the passage under the rear support in to the sprag for better oiling, sorry no pic.
Re: everything you never wanted to know about 904's [Re: dartman366] #24420
06/03/06 09:37 AM
06/03/06 09:37 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Well I guess that's that, into the archives it goes
Again, if anyone has more info to add...give me a holler.
Even though the membership can not add a reply to this post once it is archived, if you PM me with the info or post it on another board I can add it....and your name will be on it.
Rich H.
Esse Quam Videri
Re: everything you never wanted to know about 904's [Re: ZIPPY] #24421
06/04/06 10:43 AM
06/04/06 10:43 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Clutch plates:
Moparts Extras >> Moparts Tech Archive Previous Index Next Threaded
Pages: 1
clonestocker
super gas
Reged: Jan 20 2003
Loc: Tucson, Arizona 904 Clutch Plates?
#2670549 - Fri Jun 02 2006 12:25 PM (216.253.194.218) Edit Reply Quote Quick Reply
Is there a difference in clutch material in the two different clutch packs? Taking my trans apart I have two different types of clutches? The guy at the parts store said it doesn't make a difference. I had Borg Warner in the high gear drum, and these black plates in the direct drum(?). These black plates are falling apart. Is it a problem to use the Borg Warner plates in both clutch packs? thx matt s
Post Extras: Manage this thread
1100HPSmallBlock
Reged: Apr 19 2006
Loc: Jersey Re: 904 Clutch Plates? [Re: clonestocker]
#2670611 - Fri Jun 02 2006 12:49 PM (64.251.156.141) Edit Reply Quote Quick Reply
The forward (rear clutches) are thinner than the direct(front). If you swap them you have clearance issues.
8.42 @ 165 MPH
dartman366
Reged: Jan 18 2004
Loc: Mt. Vernon, Ohio Re: 904 Clutch Plates? [Re: clonestocker]
#2670617 - Fri Jun 02 2006 12:52 PM (65.24.53.120) Edit Reply Quote Quick Reply
I don't believe it make's any diff on the material, but the thing that I have found is the grooves in the facing, one will have grooves straight across the face and the other will look like a waffle, the only other thing to watch is the thickness of the fiber plate, when I got my master overhaul kit from Mancini the fiber disc's were all the same blue plate material.
new best of 6.89 1/8 mile and 11.05 1/4 mile.....speed cost's money son,, how fast do you want to go??
dartman366
Reged: Jan 18 2004
Loc: Mt. Vernon, Ohio Re: 904 Clutch Plates? [Re: 1100HPSmallBlock]
#2670638 - Fri Jun 02 2006 12:59 PM (65.24.53.120) Edit Reply Quote Quick Reply
that being the case then after reviewing a NAPA kit that I have, then the direct clutches are the waffle ones and yes there is a thickness difference, and the material appears to be the same in that kit also.
Edited by dartman366 (Fri Jun 02 2006 01:01 PM)
clonestocker
super gas
Reged: Jan 20 2003
Loc: Tucson, Arizona Re: 904 Clutch Plates? [Re: dartman366]
#2670677 - Fri Jun 02 2006 01:20 PM (216.253.194.218) Edit Reply Quote Quick Reply
The waffle plates are .082 thick. The other plates are .062 thick. Using the .062 plates allows you to put 5 plates in the front drum. I was told to do this by Dave Smith @ ProTrans. Need more input. thx matt s
John_Kunkel
Reged: Jan 20 2003
Loc: Rio Linda, CA Re: 904 Clutch Plates? [Re: clonestocker]
#2671013 - Fri Jun 02 2006 04:47 PM (24.7.147.107) Edit Reply Quote Quick Reply
One reason for the difference in clutch material is because the rear clutch normally engages at idle with the car at a standstill and remains engaged for all forward gears, the front clutch engages under power.
'98 Ram QuadCab Sport
'97 Viper GTS
'92 D350 Turbo Diesel Car Hauler
'62 Dart Max Wedge
'62 Dart Wagon 2 door conversion
'62 Lancer Coupe
'57 Chrysler New Yorker
clonestocker
super gas
Reged: Jan 20 2003
Loc: Tucson, Arizona Re: 904 Clutch Plates? [Re: John_Kunkel]
#2671137 - Fri Jun 02 2006 06:03 PM (68.0.167.7) Edit Reply Quote Quick Reply
John, Do you think it matters if the front drum clutches are in the rear drum also? thx matt s
dizuster
Reged: Jan 12 2005
Loc: Waterford, MI Re: 904 Clutch Plates? [Re: clonestocker]
#2671385 - Fri Jun 02 2006 08:04 PM (68.248.72.29) Edit Reply Quote Quick Reply
Oh I'm so glad I read this. . . do not put 5 clutch plates in the high gear drum without being very careful. Yes it works but there is a potential for a big problem there. The problem is that the input shaft/rear clutch drum splines do not engage the bottom (5th) clutch. I had one that I went round and round on trying to figure out why it would only flare the 2-3 shift at high rpm. It's because the bottom clutch wasn't engaged which caused it to keep the whole clutch pack from clamping. Now there are several different height rear drum splines, so if you have the right spline height on the drum you can do it, but I have not had good sucess. Search for my other post "everything you never wanted to know about a 904" There is a lot of detail about what I went through. . . Just my 2 cents, and maybe you already have the right rear drum spline, but just be careful!!
dizuster
Reged: Jan 12 2005
Loc: Waterford, MI Re: 904 Clutch Plates? [Re: dizuster]
#2671387 - Fri Jun 02 2006 08:07 PM (68.248.72.29) Edit Reply Quote Quick Reply
By the way, I got my original brilliant idea from having a protrans apart from a pro nostalgia car. It seemed like a great idea, but they must make sure they use the correct drum.
Also supposidly because the direct drum is a dynamic apply, the waffle grooves cut in the clutches allow it to relieve the fluid between the plates. That's why the direct clutches are waffled and the rear clutches are not. The rear clutch is on in all forward gears so it never really gets a dynamic apply (unless you neutral slam it of course lol . . )
DavidDean
super street
Reged: Mar 29 2003
Loc: Lubbock,TX Re: 904 Clutch Plates? [Re: dizuster]
#2671614 - Fri Jun 02 2006 10:13 PM (64.185.32.101) Edit Reply Quote Quick Reply
With the right parts as described above I used 5 clutches (thin) in the front drum with good sucess .But as stated above and in the 904 post you must have the right parts.I'm building a spare 904 and I've been back to the trans supply shops a number of times looking for the right parts LOL!
John_Kunkel
Reged: Jan 20 2003
#2673059 - Sat Jun 03 2006 05:11 PM (24.7.147.107) Edit Reply Quote Quick Reply
The front discs usually have a waffle pattern to allow fluid to be squeezed from between the discs during engagement, the channels in the waffle pattern reduce the actual surface contact area but this is a necessary tradeoff for good application.
The rear clutches aren't applied under power and therefore don't need the waffle pattern so the reduction in surface area has no tradeoff benefit as it does in the front. A flat pattern with occasional diagonal slots and metallic lining is the traditional rear disc and offers the maximum surface area.
My , I'm sure some others will disagree.
'97 Viper GTS
'62 Dart Max Wedge
'62 Lancer Coupe
440Jim
moparts member
Reged: Jan 19 2003
Loc: Lexington Park, MD Re: 904 Clutch Plates? [Re: John_Kunkel]
#2673763 - Sat Jun 03 2006 11:14 PM (69.72.26.165) Edit Reply Quote Quick Reply
I agree with John 100%. (or more)
And in the 904, it is more important than the 727 since everything is smaller.
clonestocker
super gas
Reged: Jan 20 2003
#2673898 - Sun Jun 04 2006 12:09 AM (68.0.167.7) Edit Reply Quote Quick Reply
Thanks John. matt
Rich H.
Esse Quam Videri
