Re: Best bang for the buck 440 heads and rods [Re: Cab_Burge] #2440409
01/25/18 04:08 AM
01/25/18 04:08 AM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Originally Posted By Cab_Burge
Never say never with any American car company, NEVER tsk whistling grin
(There was even a 350...
Re: Best bang for the buck 440 heads and rods [Re: dodge turbo] #2440476
01/25/18 11:50 AM
01/25/18 11:50 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
A friend of mine has a 60 Chrysler with 383 RB.
Kevin
Re: Best bang for the buck 440 heads and rods [Re: Twostick] #2440623
01/25/18 04:48 PM
01/25/18 04:48 PM
Cab_Burge Online work
Cab_Burge  Online Work
Does he know the bore and stroke on that motor?
Please find out and if he does please post it on here luck
Re: Best bang for the buck 440 heads and rods [Re: Skeptic] #2440656
01/25/18 05:58 PM
01/25/18 05:58 PM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
Originally Posted By Skeptic
haha So many Chebby guys have no clue that Chrysler built a 383 that wasn't a stroker.
Actually, it kinda was...it began as a 361 I believe....
71 440-6 4spd & 69 Hemi 4spd
Re: Best bang for the buck 440 heads and rods [Re: hemi_doug] #2440763
01/25/18 11:15 PM
01/25/18 11:15 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
by that "logic" a 440 is a stroker motor too. Still isn't a [censored] Chevy.
Re: Best bang for the buck 440 heads and rods [Re: Cab_Burge] #2440769
01/25/18 11:31 PM
01/25/18 11:31 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Cab,All RB's are 3.75" stroke stock.I had to look up the bore dimension,I found 4.03" for the RB 383 engine.
RT
Re: Best bang for the buck 440 heads and rods [Re: Skeptic] #2440792
01/26/18 12:09 AM
01/26/18 12:09 AM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
by that "logic" a 440 is a stroker motor too. Still isn't ag [censored] Chevy.
Nope..not the same block...not being a Chevy aside.
Re: Best bang for the buck 440 heads and rods [Re: dodge turbo] #2440870
01/26/18 03:47 AM
01/26/18 03:47 AM
New York, USA
Chargerfan68 Offline
New York, USA
I also have a good friend with an all original 60 Windsor wagon with a 383 RB. 3.75 stroke
Re: Best bang for the buck 440 heads and rods [Re: dodge turbo] #2440872
01/26/18 04:02 AM
01/26/18 04:02 AM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Forget the 440/B/RB stuff. G3 hemi is the only way to go
Re: Best bang for the buck 440 heads and rods [Re: hemi_doug] #2440882
01/26/18 05:44 AM
01/26/18 05:44 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
It actually began as a 350 then 361 to 383 and then 400. I had heard the RB 383 was built for two years but I am not 100% sure on that. Ron
Re: Best bang for the buck 440 heads and rods [Re: A990] #2440956
01/26/18 01:06 PM
01/26/18 01:06 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
If you don't have any B/RB stuff now, absolutely. The transmission bolts up to the small block, and you're going to have to change the engine mounts anyway. Much better heads and no waiting for unobtanium, overpriced aftermarket blocks. Lighter than a B/RB too. twocents
Re: Best bang for the buck 440 heads and rods [Re: 383man] #2441154
01/26/18 07:38 PM
01/26/18 07:38 PM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
thank you sir, I stand corrected...
