426 Hemi solid lifters w/EDM hole #244005
03/05/09 11:52 AM
03/05/09 11:52 AM
San Ramon, CA.
Topcat Offline OP
Topcat  Offline OP
San Ramon, CA.
I'm going to be running a solid cam and would like to find out what companies have available 426 Hemi solid lifters with the EDM hole feature.
JSYK...Comp cams doesn't offer them.
Re: 426 Hemi solid lifters w/EDM hole [Re: Topcat] #244006
03/05/09 11:59 AM
03/05/09 11:59 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
all big block mopars use the same lifters , they are not hemi specific . Howard's has edm lifters , the cup is higher in the lifter so you will need a shorter pushrod is you already have a set .
Re: 426 Hemi solid lifters w/EDM hole [Re: Topcat] #244007
03/05/09 12:08 PM
03/05/09 12:08 PM
San Ramon, CA.
Topcat Offline OP
Topcat  Offline OP
San Ramon, CA.
Thanks for the info regarding the push rods also.
I'll give em a call.
Re: 426 Hemi solid lifters w/EDM hole [Re: Topcat] #244008
03/05/09 08:35 PM
03/05/09 08:35 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I bought a set for my Hemi from Howards two years ago, no problems yet. It seems to me hydraulic pushrods are the correct length for the Howards solid lifters. Mine are custom length though.
Sheldon
Re: 426 Hemi solid lifters w/EDM hole [Re: RUNCHARGER] #244009
03/05/09 08:46 PM
03/05/09 08:46 PM
San Ramon, CA.
Topcat Offline OP
Topcat  Offline OP
San Ramon, CA.
Sheldon
Good to know. I still have hyd. push rods almost brand new I might re use w/them.
After I called up Howard cams, I found out about another company making them out in MI. They make their own. But 6-8 weeks L/T right now.
http://www.wathomas.com/sec_home.html
Kinda pricey but came with a lifetime warranty.
Re: 426 Hemi solid lifters w/EDM hole [Re: Topcat] #244010
03/05/09 09:18 PM
03/05/09 09:18 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Hello
Im doing this very build right now. I picked up some Howards EDM lifters, to use with my Ray Barton custom Bullet cam.
Anyways
I have heard a bunch of people talk about burning push rods up, and lack of oil to the cups etc. This engine (572) uses all new stuff, the block is a new One from World with a 4.5 bore. CNC ported heads...bla, bla, bla
Seeing how these lifters make it possible for push rod oiling, due to actually being a AMC lifter... I plan to use them in this fashion. Manton Push rods will install a .030 restricter in each push rod for free, to keep oil control down, and bleeding oil to much. The valve train will oil in the normal fashion, but this to me is worth the extra trouble, and wont cost me a dime really if you already have the lifters..
Re: 426 Hemi solid lifters w/EDM hole [Re: Topcat] #244011
03/05/09 09:47 PM
03/05/09 09:47 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Sheldon
I still have the set I had listed for sale last month in the classifieds. They're in a Comp box, but I'm sure they all come from the same place. PM me if interested...
