Re: Balance and weght mods- worth it? Bang:buck? What order? [Re: MRGTX] #2441469
01/27/18 01:51 PM
01/27/18 01:51 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
The Red Brick has:
- battery in the RR corner of the trunk.
-Aluminum heads, intake, wage pump, radiator, trans case
-Cage with really low door bars
-Sparco seats that were as low to floor as you could go
-No stereo
-No heater box
-Lightweight air cleaner housing and lid
-removed torsion rods from trunk
-No rear seat
Basically a lot of thought was given as to lightening as much up as you could, and keeping what weight you did have as low as possible. It has all steel panels and bumpers. Its scaled weight is with almost a full tank of gas (stock tank).
Re: Balance and weght mods- worth it? Bang:buck? What order? [Re: MRGTX] #2441567
01/27/18 04:27 PM
01/27/18 04:27 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Just a caution:
The 50.1% and 50.4% numbers in Rylispro and NV69B7RR posts are Left and Right percentage.
Not Front to Rear percentage.
....Sorry my mistake, I should have had the scale readout set FF/RR %. Later in the day I fixed that.
Re: Balance and weght mods- worth it? Bang:buck? What order? [Re: MRGTX] #2441627
01/27/18 05:47 PM
01/27/18 05:47 PM
Colorado
Bob J Offline
Bob J  Offline
Colorado
You guys talked me into moving the battery to the trunk. I'm also rethinking the rear bumper and will start with steel and see what I think plus I could use the cash other places. Autoxcuda what car did your horn come from? I was thinking one of the German imports but it will be what pull and pay has.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: Balance and weght mods- worth it? Bang:buck? What order? [Re: NV69B7RR] #2441658
01/27/18 06:40 PM
01/27/18 06:40 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Originally Posted By NV69B7RR
The Red Brick has:
-No stereo
-No heater box
-No rear seat
Mine is a little bit similar, but mine has the following:
-Cast Iron heads, aluminum intake, aluminum water pump, aluminum radiator, T56 transmission
-Cage with swing out door bars.
-Corbeau LG1's with stock brackets.
-Has stereo (non-functional)
-No heater box
-Standard air cleaner
-torsion rods from trunk still in place
-No rear seat
Similar setup, aside for the weight difference between a Valiant and Dart, cast-iron heads, beefier cage, T56 vs 4-speed weight, and the fact that his has a full-tank and mine has only 2-3 gallons.
Overall, mine probably weighs about 200 lbs more than the Red Brick with a full tank of gas. But there's still a lot that can be done to reduce weight. I just calculated it, the Red Brick is 54/46 weight distribution while the Dart is 56/44 weight distribution. So, aluminum heads and lighter hoods, bumpers, and quarter panels will do wonders.
When I finish my master's program (in June) I hope to make some composite pieces/body panels for the Dart. I'd like to do CF, but it's hard to justify when CF is at least $40/yard vs. Fiberglass which is $6/yard.
Re: Balance and weght mods- worth it? Bang:buck? What order? [Re: MRGTX] #2441670
01/27/18 07:38 PM
01/27/18 07:38 PM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
Anyone have a car under 3000 pounds without the driver? I would guess you could get a well thought out A body down to 2800 ready to race...
A new iron curtain drawn across the 49th parallel
Re: Balance and weght mods- worth it? Bang:buck? What order? [Re: 67autocross] #2442024
01/28/18 03:41 AM
01/28/18 03:41 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
A 65 or older Valiant would be the best to start.
2800 will have fiberglass and not stock interior. Problem is when you put a cage to make a car rigid with sticky tires the weight goes back on.
The circle track late model race cars I worked on had full fabricated chassis with a thin floppy fiberglass skin body weighed 2650 lbs (with the trickest parts) before we put lead back in it. Most others were 2750 lbs.
Drag cars are a different animal.
Re: Balance and weght mods- worth it? Bang:buck? What order? [Re: MRGTX] #2442318
01/28/18 05:00 PM
01/28/18 05:00 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
The biggest bang for the buck in dollars spent per pounds lost is in fiberglass body panels. Nothing else comes close. After that is the swiss cheesing and aluminum vs steel approach of various minor components throughout the car. Then come the big ticket items likes engine and suspension components, interior changes, etc.
In concert with that, as the battery discussion has pointed out, relocating existing weight within the car can net improvements without necessarily reducing weight.
