Page 2 of 3 1 2 3
Re: Broken pushrod piece ,where does it end up? [Re: cudaman1969] #2440259
01/24/18 10:18 PM
01/24/18 10:18 PM
APACHE JUNCTION AZ
Joesixpack Offline OP
APACHE JUNCTION AZ
got lucky today, met Richard Rippy a retired machinist....i took him the rocker arms and he is going to flat spot them for the lock nut, and run a clean up tap in the threads.here is his garage at home!
Re: Broken pushrod piece ,where does it end up? [Re: Joesixpack] #2440265
01/24/18 10:28 PM
01/24/18 10:28 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
Originally Posted By Joesixpack
cant am in middle of street and no room
I like that Plymouth!
Re: Broken pushrod piece ,where does it end up? [Re: lewtot184] #2440748
01/25/18 10:25 PM
01/25/18 10:25 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
Picked up rockers from machinist
spot faced in a bridgeport.
threads chased. look like they will work great now with new adjusters and lock nuts.
Re: Broken pushrod piece ,where does it end up? [Re: Joesixpack] #2440804
01/26/18 12:43 AM
01/26/18 12:43 AM
Lucky you, stay on his good side.
Re: Broken pushrod piece ,where does it end up? [Re: RapidRobert] #2440966
01/26/18 01:28 PM
01/26/18 01:28 PM
moparx Online content
moparx  Online Content
iagree lots of things can be done on a bridgeport.
beer
Re: Broken pushrod piece ,where does it end up? [Re: moparx] #2441118
01/26/18 06:27 PM
01/26/18 06:27 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Beautiful car.
HOA in a trailer park. That's rough.
Are there any garages for rent near by?
I had to do that when I lived in West Alis, a suburb of Milwaukee.
Was well worth the rent money.
Make sure it's properly insured though.
I learned that the hard way too.
Looks like you got a handle on the situation.
Happy Hot Rodding. up
I have mechanical Aptitude.
I can screw up anything.
Re: Broken pushrod piece ,where does it end up? [Re: moparx] #2441130
01/26/18 07:01 PM
01/26/18 07:01 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Yeah, mostly they make razor sharp chips that get stuck in your shoe and wind up in the living room carpet...you find them when you're walking barefoot there.
Re: Broken pushrod piece ,where does it end up? [Re: bboogieart] #2441138
01/26/18 07:13 PM
01/26/18 07:13 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Originally Posted By bboogieart
Beautiful car.
I used to rent a 10x20 storage place for a garage several times when I was stuck in an apartment situation.
Don't be the exception.
Re: Broken pushrod piece ,where does it end up? [Re: John_Kunkel] #2441165
01/26/18 07:56 PM
01/26/18 07:56 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Yeah - and that's why the wife makes you build a shop out back and get the Bridgeport out of the attached garage...........
Re: Broken pushrod piece ,where does it end up? [Re: markz528] #2441184
01/26/18 08:46 PM
01/26/18 08:46 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
ripped the intake off today in rapid fashion.....pushrod rod tip sitting here,,,,,yea
Re: Broken pushrod piece ,where does it end up? [Re: Joesixpack] #2441185
01/26/18 08:47 PM
01/26/18 08:47 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
here are my valve springs...people were asking what i had
Re: Broken pushrod piece ,where does it end up? [Re: Joesixpack] #2441186
01/26/18 08:48 PM
01/26/18 08:48 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
valve springs
Re: Broken pushrod piece ,where does it end up? [Re: Joesixpack] #2441330
01/27/18 01:49 AM
01/27/18 01:49 AM
What cut that rascal in half? work shruggy
Need to fix that now before reassembling it scope wrench twocents
Re: Broken pushrod piece ,where does it end up? [Re: Cab_Burge] #2441439
01/27/18 12:45 PM
01/27/18 12:45 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
not really sure, the break is exactly on the shiny line were the pushrod was contacting the head.partial blame falls on me for not keeping up with the valve adjustment.supposed to be 28/32 and when i checked all of them before a took it apart they were very loose.
Re: Broken pushrod piece ,where does it end up? [Re: markz528] #2441458
01/27/18 01:29 PM
01/27/18 01:29 PM
i MUST take my shoes off in the mud room before i'm even allowed to peak into the kitchen [first room accessible from the garage]. the BOSS rules, so i listen. biggrin
beer
Re: Broken pushrod piece ,where does it end up? [Re: Cab_Burge] #2441463
01/27/18 01:40 PM
01/27/18 01:40 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
am going to put one new pushrod in that particular cylinder,put the rocker shaft on,adjust the lash and rotate the engine 360 to make sure the valve is not bent or stuck.
Re: Broken pushrod piece ,where does it end up? [Re: Joesixpack] #2441564
01/27/18 04:20 PM
01/27/18 04:20 PM
Good idea up Maybe rotate it 720 degrees for one full power cycle work
Test, test and test some more before hurting more parts scope up bow
Re: Broken pushrod piece ,where does it end up? [Re: Cab_Burge] #2441843
01/28/18 12:22 AM
01/28/18 12:22 AM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
ok 120 parts cleaned
Re: Broken pushrod piece ,where does it end up? [Re: Joesixpack] #2441846
01/28/18 12:24 AM
01/28/18 12:24 AM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
test fit...
Re: Broken pushrod piece ,where does it end up? [Re: Joesixpack] #2441848
01/28/18 12:25 AM
01/28/18 12:25 AM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
both sides on
Page 2 of 3 1 2 3
