3/8 vs 1/2 inch oil pickup. Do I even need 1/2? #2438979
01/22/18 01:50 PM
01/22/18 01:50 PM
Northeast MA
Charger446 Offline OP
Northeast MA
I was swapping my oil pan from a Moroso 7 qt to a Hemi 6 qt and my new oil pickup tube is too small. Turns out, my 440 block was drilled and tapped to accept a 1/2 inch oil pickup tube which is what I had on there apparently.
My 440 is very mild, Edelbrock heads, stock sixpack pistons, a MP 484 cam and headers. Do I really need to run the 1/2 pickup on this motor or can I simply get a bushing/reducer and use the 3/8 pickup? I assume I would need to trial/error the height to make sure it sits properly on the bottom of the pan first.
Has anyone done this before?
Re: 3/8 vs 1/2 inch oil pickup. Do I even need 1/2? [Re: Charger446] #2439014
01/22/18 02:59 PM
01/22/18 02:59 PM
s. e. pa.
calrobb2000 Online content
calrobb2000  Online Content
s. e. pa.
not needed 3/8 will work fine
Re: 3/8 vs 1/2 inch oil pickup. Do I even need 1/2? [Re: Charger446] #2439026
01/22/18 03:22 PM
01/22/18 03:22 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Any time you incorporate a larger size on the suction side of the pump is better. I would get a 1/2" pick up pipe since the block is opened up.
Whitch straw is easier to suck thru, small or big one? Your oil pump is trying to do the same thing. HP!
Re: 3/8 vs 1/2 inch oil pickup. Do I even need 1/2? [Re: Charger446] #2439055
01/22/18 03:56 PM
01/22/18 03:56 PM
My 440 is very mild
Your app wouldn't need it right now but as said since it is already tapped & I would get a 1/2 pickup & bend/mod it to get the pickup at the height you prefer. there has been mention of the block pickup threaded boss being too thin on one side after drilling along the original CL so you might check that. I like to have the pickup touching the pan with some added spacers so there is no restriction down there & the pickup is supported on both ends to avoid potential vibration cracking tho likely not a dealbreaker, just my OCD talkin.
Re: 3/8 vs 1/2 inch oil pickup. Do I even need 1/2? [Re: Charger446] #2439092
01/22/18 05:07 PM
01/22/18 05:07 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Your Moroso pickup probably has just 1/2 threads and a 3/8 tube anyway. I’d get the 1/2 pickup though. Also look into if the turn has been opened up in the block. Should be pics or diagrams on the interwebs on that.
I want my fair share
Re: 3/8 vs 1/2 inch oil pickup. Do I even need 1/2? [Re: Charger446] #2439101
01/22/18 05:29 PM
01/22/18 05:29 PM
Stinnett, Tx
rumblebee4232 Offline
Stinnett, Tx
I don't think I have ever seen a 3/8 pickup, I would find a 1/2..
Re: 3/8 vs 1/2 inch oil pickup. Do I even need 1/2? [Re: Charger446] #2439112
01/22/18 05:48 PM
01/22/18 05:48 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
3/8 was standard.Imade my 440 1/2.But there were other mods needed to utilise all the advantages.I had the things here but lost them over the years.Rocky
Chrysler Firepower
Re: 3/8 vs 1/2 inch oil pickup. Do I even need 1/2? [Re: therocks] #2439115
01/22/18 05:51 PM
01/22/18 05:51 PM
Northeast MA
Northeast MA
Thanks for all of the great feedback guys, its appreciated.
Re: 3/8 vs 1/2 inch oil pickup. Do I even need 1/2? [Re: Charger446] #2439399
01/23/18 03:46 AM
01/23/18 03:46 AM
Get the stock 1970/71 street hemi oil pickup, they are 1/2 inch up
In the future don't let any one talk you into modding any stock B or RB to 1/2 inch pickup tsk twocents
The bypass spring in the pump determines how much oil goes into the pump and block, not the internal size of the oil pick up shruggy
Re: 3/8 vs 1/2 inch oil pickup. Do I even need 1/2? [Re: Cab_Burge] #2439446
01/23/18 10:41 AM
01/23/18 10:41 AM
Northeast MA
Northeast MA
Thank you, that is exactly what I ended up doing yesterday.
I bought the engine about 20 years ago and it was already modified by the previous owner who had much larger plans for it than I ended up using it for.
Re: 3/8 vs 1/2 inch oil pickup. Do I even need 1/2? [Re: rumblebee4232] #2439514
01/23/18 01:26 PM
01/23/18 01:26 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
There is, the 440-4 and 440-6 in 70 and 71 used the hemi pan and had a 3/8" pickup. The pickup tube was available , now ?
I used a moroso 1/2" pickup threaded end, its a separate part welded to the tube, to neck down to the 3/8 pickup tube for the original A body 383 pan, the block had already been drilled when I was building it for a different application.
Re: 3/8 vs 1/2 inch oil pickup. Do I even need 1/2? [Re: Cab_Burge] #2439548
01/23/18 02:19 PM
01/23/18 02:19 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Have to disagree, the suction side of the system is the critical limiting factor. Even with the bypass fully closed, if you can't get it to the pump the volume output will suffer.
Re: 3/8 vs 1/2 inch oil pickup. Do I even need 1/2? [Re: John_Kunkel] #2439739
01/23/18 09:29 PM
01/23/18 09:29 PM
IN
ahy Offline
ahy  Offline
IN
In practice, the 3/8" pickup has worked fine on my B based 496 run on road track up to 6,500 RPM and street. I do not think the bigger pickup has practical benefit in a relatively mild engine... though I agree less restriction in theory is better. The bigger pickup has drawbacks also like potential for block cracks and stroker clearance.
From your starting oint, I agree with Cab and others... you are already tapped for 1/2" so get a hemi re-pop 1/2" pickup and call it good. A bushing is just another potential failure point and I would avoid that.
Re: 3/8 vs 1/2 inch oil pickup. Do I even need 1/2? [Re: Charger446] #2439783
01/23/18 11:09 PM
01/23/18 11:09 PM
Chicago
PurpleBeeper Offline
Chicago
I'm wrestling with this same question on a "street only" 440 I'm starting to build.... Is the 1/2" pickup necessary?
One thing I did find out (the hard way) is to match the pan with the pickup (same manufacturer). I put on a "hemi/six pack" Milodon pan & my 70/71 Hemi pickup tube (1/2") didn't fit. I had to buy a Milodon 1/2" pickup.
Also, fyi, I still have that 70/71 Hemi pickup in one of my boxes of parts.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: 3/8 vs 1/2 inch oil pickup. Do I even need 1/2? [Re: John_Kunkel] #2439831
01/24/18 01:07 AM
01/24/18 01:07 AM
SomeCarGuy Offline
SomeCarGuy  Offline
Plus Mopar didn’t use 1/2 for no reason. The outer limit of a 3/8 might be beyond nascar needs, which wouldn’t apply to many doing this, but they did it nonetheless.
Re: 3/8 vs 1/2 inch oil pickup. Do I even need 1/2? [Re: SomeCarGuy] #2439872
01/24/18 02:49 AM
01/24/18 02:49 AM
I run real loose (.0035+)bearing and lifter clearances(.002+) on all of my street and strip builds with 5W20 Wt. oil now with the high volume oil pumps with 65 Lb. + pressure at or above 2300 RPM with hot oil up No bearing or other oiling issues using the stock type 3/8 oil pickups with 1/8 inch or less pick up clearances to the bottom of the oil pan by checking that clearance through the drain plugs on the last 12 motors shruggy
I use to use 1/2 inch pickups with 50Wt racing oil realcrazy I have ruin several stock blocks while modding them for the larger 1/2 thread sizes and had to block the stock oil passage off in the blocks under the oil pump and use a Milidon swinging external oil system shruggy
No more twocents
Re: 3/8 vs 1/2 inch oil pickup. Do I even need 1/2? [Re: John_Kunkel] #2440192
01/24/18 07:30 PM
01/24/18 07:30 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
right again john.
Re: 3/8 vs 1/2 inch oil pickup. Do I even need 1/2? [Re: Cab_Burge] #2440225
01/24/18 09:08 PM
01/24/18 09:08 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I never have, so is your anecdotal experience more valid than mine?
Re: 3/8 vs 1/2 inch oil pickup. Do I even need 1/2? [Re: John_Kunkel] #2440314
01/25/18 12:12 AM
01/25/18 12:12 AM
Are you a machinest? I'm not shruggy
Maybe your luckier than I am on some things pertaining to modifying engines shruggy
Re: 3/8 vs 1/2 inch oil pickup. Do I even need 1/2? [Re: Charger446] #2440384
01/25/18 03:12 AM
01/25/18 03:12 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
3/8 is fine....
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
