Re: Oil Pump Instal [Re: stumpy] #2439591
01/23/18 03:55 PM
01/23/18 03:55 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Man,it sure can get complicated on something as easy as changing an oil pump !! no
Re: Oil Pump Instal [Re: 62maxwgn] #2439607
01/23/18 04:26 PM
01/23/18 04:26 PM
A727Tflite Offline
A727Tflite  Offline
Some guys blueprint a pump and some guys don't centerline a camshaft.
shruggy
Re: Oil Pump Install??? [Re: A727Tflite] #2439727
01/23/18 09:08 PM
01/23/18 09:08 PM
dogdays Offline
dogdays  Offline
As the engine rolled off the assembly line, did it even have a gasket? Chrysler was saving money everywhere they could and they would put machined surfaces together without a gasket, as in the exhaust manifold to head mating surface.
Vaseline is a straight petroleum product, while greases have non-petroleum thickeners added. Possibly Cab is half right. Vaseline should melt into the oil but the thickeners in grease won't melt or dissolve.
I seem to remember 30 years ago someone giving advice to use the grease but change the oil filter with the break-in oil That would take care of any excess grease.
I found out the hard way that looking at the oil pump before installing it takes little time and can save a lot of hassle.
R.
Re: Oil Pump Install??? [Re: 71birdJ68] #2439827
01/24/18 12:56 AM
01/24/18 12:56 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
That's why I said white lube not wheel bearing grease.
