Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt] #2439420
01/23/18 05:47 AM
01/23/18 05:47 AM
NW PA
V10nacuda Offline
V10nacuda  Offline
NW PA
Is it possible one of the front sensors went bad in the time you were trying to repair the rear?
Re: 03 1500 9 1/4 rear end swap issue [Re: V10nacuda] #2440797
01/26/18 12:20 AM
01/26/18 12:20 AM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
Pulled truck in garage in morning, and out at end of day. Lights on once swap was done. Going to look at the fuses, relay, and brake light switch this weekend.
Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt] #2440849
01/26/18 02:57 AM
01/26/18 02:57 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Originally Posted By Bull1tt
Still haven’t got a code reader on it yet, but I did take terminal off and touched them together for a while. That DID clear my check engine light, but ABS and Brake dash lights are still on.
Well I'm going or try that on my Ram Van (engine light on)
Make sure you've blead the brakes good, I replaced two lines and the ABS lights stayed on till the third time I bled them. I guess that little bit of air was messing it up.
Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt] #2441308
01/27/18 12:57 AM
01/27/18 12:57 AM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
Didnt have to bleed brakes, has disc brakes on the rear. Just hung calipers and lines with zip ties. I will check out fuses, relays, tomorrow.
Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt] #2441595
01/27/18 05:01 PM
01/27/18 05:01 PM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
Fuses are all good...
Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt] #2441763
01/27/18 10:46 PM
01/27/18 10:46 PM
Plymouth, MI
Blusmbl Online content
Blusmbl  Online Content
Plymouth, MI
There should be a stored code on the ABS module, not the PCM. If it shows up immediately at key on I would look at the wiring you had to modify for the sensor in the rearend or the sensor itself. If it doesn't show up until you start driving it may have to do with the tone ring that is in the diff carrier.
