Re: Dollar for dollar best investment for 650+ HP [Re: V194] #2435024
01/15/18 03:22 PM
01/15/18 03:22 PM
Outside
thedriver Offline
thedriver  Offline
Outside
Gen 3 for sure. Just because you can pick a complete one out of a wrecker and more less supercharge it etc. Look at the ls swaps. Nobody is picking 350’s anymore to hotrod.
1973 challenger
Dana. 4 speed. Low deck.
Re: Dollar for dollar best investment for 650+ HP [Re: V194] #2435058
01/15/18 04:15 PM
01/15/18 04:15 PM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
I know that it wasn't in the options above, but why not a well build 5.9 LA or magnum and turbo or supercharge it? I wouldn't think that you would to far away from the goal of 650. Plus parts for these are cheaper and more plentiful then the Gen3 parts.
Re: Dollar for dollar best investment for 650+ HP [Re: V194] #2435093
01/15/18 05:37 PM
01/15/18 05:37 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I don't have the answer. I just started looking into Gen III stuff.
I think if you are working on an older Mopar, Then a stroked big block may be easiest because it will fit the stock K-member.
I think either option may be close in a hp per dollar for the engine, with many differences in fitment, accessorys and drive, and fuel system.
If you want modern EFI, coil near plug, serpentine belt drive, with high output alternator, A/C, and power steering, I think starting with the GenIII will save money, but fitting the engine to a old car and the computer/electronics may add to the costs?
A big block with carb, and minimal accessories likely will be less expensive, but converting the old big block to modern accessories and port EFI can be expensive.
In my case, I overspent converting the 505" stroked 440 in the convertible to port EFI and Billet Specialities Tru-Track.
The Tru-Track serpentine belt system was over $3,000 plus all the lines, remote reservoir(s), and other stuff likely an additional $500?
The Edelbrock XT EFI was about $4,000 and I ended changing out the ECU, fuel pump and such to about all I really used with the intake, TB, and sensors. The total cost got out of control likely an additional $3,000 on top of that for the FAST XFI 2.0, dual sync dist, wiring, EFI fuel tank and such.
On the other hand, I picked up a 80,000 mile 2008 6.1L Hemi with NAG trans off E-Bay for $4,000 with all the accessories, manifolds, stock wiring harness and computer. I think I spent $200 on a new electronic accelerator pedal and transmission shifter. I haven't decided on what to do with the electronics yet as more options are starting to come out. Looking at the Holley Dominator EFI?
The conversion K-Members are a bit pricy. The RMS alterKtion K-member / handling suspension kits are around $5,300+ brakes at $700 to $2,000.
Re: Dollar for dollar best investment for 650+ HP [Re: V194] #2435175
01/15/18 08:00 PM
01/15/18 08:00 PM
BDW Offline
BDW  Offline
Original scenario said for a driver with part time strip use.
Just how "driveable" do you think a stoker 440 with high compression will be?
Gen3 on the other hand would make the Power Tour with no issues.
Gonna have AC on that stroked 440?
Re: Dollar for dollar best investment for 650+ HP [Re: V194] #2435179
01/15/18 08:07 PM
01/15/18 08:07 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
I think it will depend on what you have available to start with. If you have a base of anything, the trip to 650 HP will cost about the same money. Being able to actually use the 650 HP may change everything, and how you intend on using the 650 HP also has to be accounted for. How long you expect the motor to live will have a dramatic effect on the cost, regardless of what you start with.
If your starting with no motor, but have a drag car chassis available, you use the motor/trans that fits the easiest in the car. It would be much more easy to get 650 hp hooked up going down a quarter mile strip then it would be to get 650 hp hooked on on the street while expecting to drive across the country. 650 hp looks a lot different if you put that into a car on a NASCAR track, or a mud bog truck.
Otherwise, have fun. Gene
Re: Dollar for dollar best investment for 650+ HP [Re: poorboy] #2435227
01/15/18 09:35 PM
01/15/18 09:35 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
iagree there is no right answer. Built to take the power with maximum amount of reliability for the street would probably be a turbo of some sort. They only make power when you tell them to. LA motor with a turbo would be cheapest probably.
Re: Dollar for dollar best investment for 650+ HP [Re: Dave Hall] #2435254
01/15/18 10:20 PM
01/15/18 10:20 PM
IN
ahy Offline
ahy  Offline
IN
I will add it depends on what character you want the car to have.
The gen 3 hemi can make the power NA. The heads have the flow potential and the block can take it. You just have to spin it up... torque is limited by displacement.
The BB stroker can have lots of mid range torque aided by higher displacement. It may feel stronger in normal driving.
Turbo or supercharger options on either one can increase both torque and power. I do not think these are budget options however. Also there may be trial and error involved (eg. trashed long block) which can increase cost significantly.
Re: Dollar for dollar best investment for 650+ HP [Re: GY3] #2435338
01/16/18 12:29 AM
01/16/18 12:29 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Originally Posted By GY3
I did a mild, street driver 505" 440 for right at $7,500.
Molnar crank and rods, Mahle pistons and CNC Stealth heads. It's just under 600 HP but more than enough for the street and a blast at the track!
You save a lot of money if you can build it yourself.
That makes a huge difference if you can do your own work. I have to laugh at some of my friends who are mechanics for a living. They seem to be happy being the parts replacing mechanic where they slam parts on cars and make all the money they can but as soon as a real problem job comes in their shop they say.....take it to the dealer. And they pay a machine shop to built their complete eng ??? Why would you have a trade as a mech and pay someone else to build your engine ?? Myself I became a mechanic/tech so I could learn to do everything on a car and I sure as heck did not become a tech for a living to not build my own eng. I can see if your not a tech/mechanic but I do all my own work that I can which is most other then some machine work or head porting which I have done but I am no pro head porter and I now have back problems that mess with bending over a bench.
But if your are able to do most or all of your own work you will save a ton of money. I know for my stroker kit , cam , heads and little things I spent at least 7k and that's just parts. If I had payed to have the eng built that's most likely somewhere from $1500 on north.
The other question is are you talking naturally aspirated eng or do you plan on a power adder as that makes a big difference. If N/A I think the bigblock B/RB stroker is one of the best bets. But if you are including power adders heck a stock 5.7 to 6.2 Hemi with a supercharger on it should be right there.
Or look at what DVW's son (I forgot his handle) has done with a mild 360 and twin turbo's on his 62 Mopar. I don't know how much he has in it but his car runs mid 9's and makes a lot of power. Myself I like the N/A bigblock stroker eng but I grew up in a world where you just did not see power adders that much on muscle cars. But in todays world you can make big power fast with power adders and the new Hemi eng seems to be strong enough to stay together with superchargers slapped on them that are basically stock.
Its close without added up all the figures but I would consider just what car and eng combo you like and what you plan to use the car as. Me I love the 60's and 70's muscle cars with naturally aspirated engines and that's the way I would and did go but you should consider what type of car/eng combo you like also. Good luck with it. Ron
Re: Dollar for dollar best investment for 650+ HP [Re: 383man] #2435345
01/16/18 12:47 AM
01/16/18 12:47 AM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Instead of 650Hp would a better question be what is it going in, and how fast do you need to go? 11.50 and faster requires a cage and other stuff that can make the car a pain on the street.
My observation with power adder cars is that no serious bracket racer here seems to use them. Too sensitive to heat fluctuations and harder to dial in. Cars that do have them are fast, but seem to struggle going back to back on the same dial in. Most of the guys who have turbos, blower, + nitrous are the test and tune guys who just want to let it rip once every few weeks for fun. The guys who are more race than street all have simple single 4 barrel big blocks. If it breaks they can get it going again before the next race with minimal downtime and expense.
Re: Dollar for dollar best investment for 650+ HP [Re: V194] #2435383
01/16/18 01:30 AM
01/16/18 01:30 AM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
I have a 645 hp 500" 440 that will be street driven, it has iron heads so it has a stout cam and I know it will probably get less than 3 mpg on e-85. This combination has been together for twenty five years but if I was to start from scratch it would be a gen 3 turbo. It would be nice to have more drivability....10 , 15 miles per gallon in addition to more power.
Have a great day
Iowan
"obsolete is neat"
Re: Dollar for dollar best investment for 650+ HP [Re: Iowan] #2435404
01/16/18 01:55 AM
01/16/18 01:55 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
What iron heads are you running at that power level?
Re: Dollar for dollar best investment for 650+ HP [Re: RTSrunner] #2435454
01/16/18 04:09 AM
01/16/18 04:09 AM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
An old pair of 915s, 2.18/1.81. 67cc
Have a great day
Iowan
"obsolete is neat"
Re: Dollar for dollar best investment for 650+ HP [Re: Iowan] #2435460
01/16/18 04:27 AM
01/16/18 04:27 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Nice!
Re: Dollor for dollar best investment for 650+ HP [Re: OhioMopar] #2435965
01/16/18 10:41 PM
01/16/18 10:41 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Originally Posted By OhioMopar
Most likely a B/RB. 650 horespower doesn't really have a low cost option. Lol. Or not one that will live very long!
You can build an Indy head stroker for under 10K that will last forever if you do your own assembly carefully. It can be done with a flat tappet cam but a roller would make the 650 number easier and possibly live longer. The roller would probably bump the price over 10K for the package to support the roller.
You don't really need external oiling with the correct rod and crank choice so that would save a bunch of dough.
Gus beer
64 Plymouth Savoy
Dana 60
