Re: 440 A/C Compressor Bracket Dilemma for the Big Block Experts [Re: NachoRT74] #2434511
01/14/18 05:26 PM
01/14/18 05:26 PM
3
340clone Offline OP
340clone  Offline OP
Originally Posted By NachoRT74
and well, a bit off topic but since you are returning to stock look... here is a stock 73/74 intake modified for performance.... that could be a great item for you
https://www.ebay.com/itm/440-Mopar-Intak...w4B&vxp=mtr
Thanks for the link! This would definitely be a contender if I had not already spent a good bit rebuilding my AVS.
Re: 440 A/C Compressor Bracket Dilemma for the Big Block Experts [Re: 340clone] #2434531
01/14/18 05:55 PM
01/14/18 05:55 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
72 brackets are diff from 73/74 as I exposed on pics
Re: 440 A/C Compressor Bracket Dilemma for the Big Block Experts [Re: 340clone] #2435396
01/16/18 01:45 AM
01/16/18 01:45 AM
3
340clone Offline OP
340clone  Offline OP
OK, I really need to be figure out out to post pics. After installing the '68 manifold on the motor, I tried again to test fit the compressor with the '74 brackets. I flipped the original '74 passenger side bracket 180 degrees and it lines up almost perfectly with the forward coil bracket bolt hole! Unbelievable! So, since the bracket set up is bolted up to the water pump and the driver side intake, is it OK to use the 5/16 bolt for the coil bracket to secure this bracket? I may be able to tap to 3/8 but not sure if it's necessary...
Re: 440 A/C Compressor Bracket Dilemma for the Big Block Experts [Re: 340clone] #2435400
01/16/18 01:50 AM
01/16/18 01:50 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Same existant bolt than the coil bracket. No need for more
Re: 440 A/C Compressor Bracket Dilemma for the Big Block Experts [Re: NachoRT74] #2435433
01/16/18 03:01 AM
01/16/18 03:01 AM
3
340clone Offline OP
340clone  Offline OP
Awesome! Issue solved!
Thanks again to everyone for all the replies and help!
