Standard Steel Rim Lug Nut Plating #2432196
01/10/18 02:28 PM
01/10/18 02:28 PM
Indianapolis, IN
B5Cuda440-6 Offline OP
Indianapolis, IN
I was reading in the MMC Detroit Fastener Guide that left-handed standard lug nuts that came on steel rims with a wheel cover (like 450's) had a copper plating. Does anyone have any reference picture of an original LH lug nut I can use as a reference to re-create the plating?
Detailed question, I know. But I figured someone here has an original set of LH nuts with the plating. Mine are reproduction and plated clear zinc.
Thanks everyone.
Re: Standard Steel Rim Lug Nut Plating [Re: B5Cuda440-6] #2432476
01/10/18 10:08 PM
01/10/18 10:08 PM
Land of 10,000 Lakes
44D6PAKCUDA Online content
44D6PAKCUDA  Online Content
Rob-I think it should have read wheel studs,not the nuts.The left side studs were originally copper colored/plated.I know the front disc for sure and I can't remember on the rear axle if they were or not.
Re: Standard Steel Rim Lug Nut Plating [Re: B5Cuda440-6] #2432550
01/11/18 12:06 AM
01/11/18 12:06 AM
Indianapolis, IN
Indianapolis, IN
Thanks Jim. My LH studs are copper plated, both in the rear axle and the front rotor. But I also believe there was a plating applied to the nuts to help distinguish LH from RH.
Re: Standard Steel Rim Lug Nut Plating [Re: B5Cuda440-6] #2432588
01/11/18 01:00 AM
01/11/18 01:00 AM
VA
dragon slayer Offline
VA
Not sure if this is original OEM, but it is Mopar Left Hand Stud and nut and both are copper plated.
Re: Standard Steel Rim Lug Nut Plating [Re: B5Cuda440-6] #2432731
01/11/18 10:11 AM
01/11/18 10:11 AM
I did not know that.Good info Rob smile
Re: Standard Steel Rim Lug Nut Plating [Re: B5Cuda440-6] #2432742
01/11/18 11:07 AM
01/11/18 11:07 AM
Indianapolis, IN
Indianapolis, IN
Thanks dragon slayer. That is exactly what I was wanting to confirm.
Does the copper plating on the nut look the same as the stud? It looks like the nut is a little darker or dull. Might just be from age, however. Hard to see with the lighting in your pics.
Re: Standard Steel Rim Lug Nut Plating [Re: B5Cuda440-6] #2432881
01/11/18 04:58 PM
01/11/18 04:58 PM
VA
VA
It does look darker, but also has black spots on it so I am not sure if that is natural. The stud is new and came out of a parts draw. The nut is unused but was in an open container of lug nuts if I remember correctly. So I would ""Guess" the plating should be same.
Here are some close-ups also of the marks. I am no expert on this" G
Re: Standard Steel Rim Lug Nut Plating [Re: B5Cuda440-6] #2432894
01/11/18 05:20 PM
01/11/18 05:20 PM
Indianapolis, IN
Indianapolis, IN
Got it. Thanks for the clearer pictures.
Re: Standard Steel Rim Lug Nut Plating [Re: B5Cuda440-6] #2432939
01/11/18 06:31 PM
01/11/18 06:31 PM
MA
steve70 Offline
steve70  Offline
MA
original left hand stud
1970 Challenger T/A 4 speed
Re: Standard Steel Rim Lug Nut Plating [Re: B5Cuda440-6] #2432941
01/11/18 06:32 PM
01/11/18 06:32 PM
MA
steve70 Offline
steve70  Offline
MA
original right side stud
Re: Standard Steel Rim Lug Nut Plating [Re: B5Cuda440-6] #2433175
01/12/18 01:42 AM
01/12/18 01:42 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Rights are green
Lefts are red
Re: Standard Steel Rim Lug Nut Plating [Re: Morty426] #2433284
01/12/18 11:22 AM
01/12/18 11:22 AM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Originally Posted By Morty426
Rights are green
Lefts are red
Just like aircraft wing tips.
68 Charger
70 Cuda
Re: Standard Steel Rim Lug Nut Plating [Re: FC7cuda] #2433290
01/12/18 11:27 AM
01/12/18 11:27 AM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
68 Charger
70 Cuda
Re: Standard Steel Rim Lug Nut Plating [Re: B5Cuda440-6] #2433323
01/12/18 12:40 PM
01/12/18 12:40 PM
Indianapolis, IN
Indianapolis, IN
Thanks guys!!
Re: Standard Steel Rim Lug Nut Plating [Re: B5Cuda440-6] #2445868
02/03/18 09:08 PM
02/03/18 09:08 PM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
FYI I just acquired 2 NOS front 3549845 brake drums/hubs booth have left hand studs with L stamp but on only one there copper colored, the date codes on the drums are {copper stud 151 3} {black stud 298 3}.
