The variable part & the HD part.
Thanks Barry
I appreciate the clarification.
So, I'm thinking,
Variable load turn signal flasher - Variable wiper quickens the swipe of the wiper on the windshield based on how you move the adjuster on the wiper switch on the dash. A turn signal is just up or down when engaged, so where is the variable?
* Heavy duty stop lamp switch - I've taken many e-bodies apart over the years. the stop lamp switch, over the brake pedal, moves when you push the brake pedal down. How that could be "heavy duty"???
I'm thinking Chrysler just took the guy's $14.05.
