Page 2 of 3 1 2 3
Re: (Re)coating MLS gaskets prior to reuse [Re: Al_Alguire] #2431282
01/08/18 09:50 PM
01/08/18 09:50 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Originally Posted By Al_Alguire
I spray them with copper coat and use them. Yes you need to take them apart to clean them properly
I cleaned mine thoroughly but never use copper coat. I think you will be happier with the Cometics.
'63 Dodge 330
11.19 @ 121 mph
Re: (Re)coating MLS gaskets prior to reuse [Re: BradH] #2431341
01/08/18 11:18 PM
01/08/18 11:18 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I don't think I would try and separate the MLS gaskets. Also I prefer High Temp 1200 or 1500 Aluminum ceramic paint.
But in your case, with the stock coating flaking off, done/gone get rid of them.
Re: (Re)coating MLS gaskets prior to reuse [Re: BradH] #2431557
01/09/18 12:54 PM
01/09/18 12:54 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
You drill out a rivet, not like its complicated. I would NEVER reuse thme without cleaning them. Only way to clean them properly is to drill out the rivet and separate them to clean them. Maybe its the difference between compression ratios above 15-1 but I have NEVER had an issue taking them apart and cleaning them, then using copper coat on the outer layers. I've never used a Mr Gasket or anyone else's MLS gasket except Cometic. But they will tell you to either NOT reuse them or to wipe em off and never use anything.
Re: (Re)coating MLS gaskets prior to reuse [Re: Al_Alguire] #2431583
01/09/18 01:54 PM
01/09/18 01:54 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Heck I had to drill out 3 rivots and cut part of the gasket on my Keith Black block and B1 head combo. No big deal. The rivets wouldn't let my head seat properly.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: (Re)coating MLS gaskets prior to reuse [Re: BradH] #2431598
01/09/18 02:12 PM
01/09/18 02:12 PM
AndyF Offline
AndyF  Offline
I just use new gaskets whenever I pull the heads off. Easier that way....
Re: (Re)coating MLS gaskets prior to reuse [Re: pittsburghracer] #2431599
01/09/18 02:13 PM
01/09/18 02:13 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
Same with me, so you're basically there already up
Re: (Re)coating MLS gaskets prior to reuse [Re: BradH] #2431600
01/09/18 02:15 PM
01/09/18 02:15 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Yeah the rivets on the Cometics get in the way of MOST Mopar heads. I have none on any B1 stuff or the Predators.
Re: (Re)coating MLS gaskets prior to reuse [Re: BradH] #2431607
01/09/18 02:21 PM
01/09/18 02:21 PM
AndyF Offline
AndyF  Offline
We just put a small counterbore in the head or the block to clear the rivets. Then we never have to drill out the rivets.
Re: (Re)coating MLS gaskets prior to reuse [Re: BradH] #2431626
01/09/18 02:49 PM
01/09/18 02:49 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Originally Posted By BradH
... I'm not sure that those Mr. Gasket MLS head gaskets actually sealed properly. I can't put my finger on it, but I think it's because they both looked kind of wet (coolant seepage?), which didn't seem normal to me.
Additional evidence that the Mr G. MLS gaskets weren't sealing properly: Half of the cylinders have corrosion in the bores where the moisture collected above the ring lands on the outside walls while the pistons remained in the same position for weeks after the dyno session.
NOT impressed. puke
Re: (Re)coating MLS gaskets prior to reuse [Re: BradH] #2431709
01/09/18 05:42 PM
01/09/18 05:42 PM
AndyF Offline
AndyF  Offline
I tried the MR Gasket MLS gaskets once and then went back to Cometic. It also helps that I get a nice discount from Cometic. Mr Gasket is such a big company they don't care about little guys like me.
Re: (Re)coating MLS gaskets prior to reuse [Re: AndyF] #2431738
01/09/18 06:51 PM
01/09/18 06:51 PM
Mr. Gasket use to have their MLS gaskets made here in the U.S., not any more now that there made in China work
I have reused the Cometic dry as well as coated with Copper Coat, they worked both ways with no issues that I saw shruggy
Re: (Re)coating MLS gaskets prior to reuse [Re: AndyF] #2431798
01/09/18 08:34 PM
01/09/18 08:34 PM
BradH Offline OP
BradH  Offline OP
I've never re-used a head gasket before. The Mr. G's were new and they simply didn't seal properly.
I may consider some new Cometics, or save my money and use one of my remaining sets of the discontinued orange DG gaskets I mentioned previously. The only real issue I had w/ those is they're a big PITA to clean off the heads & block when disassembled... but they sure as He11 didn't leak.
Re: (Re)coating MLS gaskets prior to reuse [Re: Cab_Burge] #2431799
01/09/18 08:36 PM
01/09/18 08:36 PM
BradH Offline OP
BradH  Offline OP
Guess I must have purchased Chi-Com-etics. eyes
Re: (Re)coating MLS gaskets prior to reuse [Re: BradH] #2431809
01/09/18 08:49 PM
01/09/18 08:49 PM
I think it was around three or four years ago that one of the Mr. Gasket manufacturer reps. told me that they had quit making those MLS head gasket here in the U.S., this was after I called them about having to wait 2 to 3 weeks to get them from Summit shruggy
Re: (Re)coating MLS gaskets prior to reuse [Re: BradH] #2431883
01/09/18 10:42 PM
01/09/18 10:42 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
NOT impressed. puke
Did at any time leak down that engine??
I'm lazy,just bought new ones..........
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: (Re)coating MLS gaskets prior to reuse [Re: Al_Alguire] #2431914
01/09/18 11:20 PM
01/09/18 11:20 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
""Only way to clean them properly is to drill out the rivet and separate them to clean them.""
When doing this, I am assuming that you have to reassemble them on the same head and in the same order? Is this correct?
Thanks!
Re: (Re)coating MLS gaskets prior to reuse [Re: YO7_A66] #2431943
01/09/18 11:53 PM
01/09/18 11:53 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I bought a set of Mr Gasket mls gaskets from Jegs once and they came in a Cometic package cardboard insert, with a Mr Gasket sticker on them, that must of been their once upon a time american supplier before they went with wang chung gasket company.
Re: (Re)coating MLS gaskets prior to reuse [Re: dartman366] #2432625
01/11/18 02:23 AM
01/11/18 02:23 AM
BradH Offline OP
BradH  Offline OP
That's my understanding as well.
Re: (Re)coating MLS gaskets prior to reuse [Re: BradH] #2467048
03/15/18 08:09 PM
03/15/18 08:09 PM
New Mexico
UCUDANT Online content
Troll Hunter
UCUDANT  Online Content
Troll Hunter
New Mexico
I bought some Mr Gasket MLS gaskets in the summer of 2014 and they looked just like some Cometic 340 gaskets I have. I just had one start to leak coolant (I never re-torqued them) I removed the bolts one at a time in order and lubed the threads and re-torqued them one by one and it stopped leaking. up
Re: (Re)coating MLS gaskets prior to reuse [Re: BradH] #2467242
03/16/18 10:06 AM
03/16/18 10:06 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
With a quality fastener like ARP you can go 5 or 10 more # in tq to help stop any leaks so going from 70# to 80 would be ok.
Page 2 of 3 1 2 3
