Re: Ford builds its own "Dana 60"
[Re: dogdays]
#2431730
01/09/18 06:41 PM
01/09/18 06:41 PM
Posts: 25,949 Rio Linda, CA
John_Kunkel
Rio Linda, CA
It's a Ford corporate 9.75" not same as a Dana 60. Dana 60 has 10 cover bolts, corporate has 12.
[Re: John_Kunkel]
#2431741
01/09/18 06:55 PM
01/09/18 06:55 PM
Posts: 43,283 Bend,OR USA
Cab_Burge
How many bolts on the Ford 8.8 covers?
[Re: dogdays]
#2431821
01/09/18 09:13 PM
01/09/18 09:13 PM
Posts: 11,657 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
No reason to even look at it unless you're fooling around with a later model Ford truck. Plenty of other better choices.
[Re: gregsdart]
#2432024
01/10/18 01:53 AM
01/10/18 01:53 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
No reason to even look at it unless you're fooling around with a later model Ford truck. Plenty of other better choices. Due to a lack of race parts for it? I don't know what's available for it. Looks like nothing. Housings are supposed to be weak. Look like they are stupid heavy. Randy's shows some gear sets for it up to 5.13. The only yoke is a flange type. Axles are some queer 34 spline deal. No spools. Looks like parts are mostly year specific. With D60s and 9"s supported by the aftermarket, why even consider it?
[Re: dogdays]
#2432042
01/10/18 02:35 AM
01/10/18 02:35 AM
Posts: 4,210 New York
polyspheric
New York
Since some version of the F-9" is used on big tire pro mod cars, what's the advantage to more weight, more power lost, and all new parts?
Boffin Emeritus
[Re: polyspheric]
#2432124
01/10/18 11:55 AM
01/10/18 11:55 AM
Posts: 11,685 W. Kentucky
justinp61
W. Kentucky
Since some version of the F-9" is used on big tire pro mod cars, what's the advantage to more weight, more power lost, and all new parts? Plus if you break something in a 9" most likely someone in the pits will have parts for it.
[Re: dogdays]
#2432298
01/10/18 04:43 PM
01/10/18 04:43 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
It's not a 70 or an 80. It's a Sterling and it's a smaller version of their 10.5 used in full size trucks. And it's basically useless if you don't have a Ford truck. If you get beyond what a good 9" can withstand, then there are options beyond that from Strange, MW and others.
