Re: Transmission shield/blanket. 69 GTX stock floor
[Re: mercman1]
#2420956
12/19/17 03:07 PM
12/19/17 03:07 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
What shifter do you use?Cable or rod ?All but the CF will get burned depending on the headers[fender exit or under chassis]I liked the more flexible blankets w/full coverage.
[Re: mercman1]
#2420958
12/19/17 03:11 PM
12/19/17 03:11 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
Anyone run the short 727 blanket from A&A Transmission?
[Re: mercman1]
#2420990
12/19/17 04:13 PM
12/19/17 04:13 PM
Posts: 13,408 Marion, South Carolina [><]
an8sec70cuda
Mine is an E body w/ a hemi, but should be the same as B body in this situation. I use the carbon fiber CSR shield. Have to hammer the seam flat where the firewall meets the floorpan and have to cut the lugs off the trans case where the factory shift linkage bolts up. It's all snug, but works great. It saved my feet when my 727 exploded in 2008. I have 2.25" primary TTI headers and they fit fine.
[Re: mercman1]
#2421118
12/19/17 08:54 PM
12/19/17 08:54 PM
Clanton
northern,Ohio,USA
an8sec70cuda.... Do you have pictures you can post of the floor seam remodeling required? When I swap to the 727 I will not be pulling the engine, so if it can be done correctly with the trans out then no problem. That is why I posted the pic of the seam,you can see how far back iy is.
[Re: ProSport]
#2421230
12/19/17 11:57 PM
12/19/17 11:57 PM
Posts: 2,475 Sydney,Australia
tex013
Sydney,Australia
Anyone run the short 727 blanket from A&A Transmission? Is that the same as DJ Safety ? I will hopefully be fitting a short DJ blanket next week in my 68 Satellite I took some advice i read , will weld a curved rod to cable / trans bracket to support blanket off shift lever Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2421334
12/20/17 07:10 AM
12/20/17 07:10 AM
ProSport
Akron, Ohio
Anyone run the short 727 blanket from A&A Transmission? Is that the same as DJ Safety ? I will hopefully be fitting a short DJ blanket next week in my 68 Satellite I took some advice i read , will weld a curved rod to cable / trans bracket to support blanket off shift lever Tex Yes I believe DJ Safety makes it to A&A's specs.
[Re: mercman1]
#2421340
12/20/17 08:29 AM
12/20/17 08:29 AM
tex013
Sydney,Australia
Kool , as soon as new converter arrives i will be fitting it
Tex
[Re: tex013]
#2421344
12/20/17 08:45 AM
12/20/17 08:45 AM
ProSport
Akron, Ohio
Tex Perfect, let us know how it goes.
[Re: mercman1]
#2421378
12/20/17 11:49 AM
12/20/17 11:49 AM
an8sec70cuda
an8sec70cuda.... Do you have pictures you can post of the floor seam remodeling required? When I swap to the 727 I will not be pulling the engine, so if it can be done correctly with the trans out then no problem. Yes you can do it w/ the motor still in the car. I don't have any pics, but you'll see it immediately when you drop the trans. Just hammer it so it's flush w/ the rest of the floor. You can see what it looks like before hammering it flush in Clanton's pic. Rickraw...even if you have a billet drum, you still need some sort of shield or SFI bellhousing to be legal.
[Re: mercman1]
#2422133
12/22/17 12:52 AM
12/22/17 12:52 AM
tex013
Sydney,Australia
This is the modded canle bracket , holds blanket up off shift arm and cable
Tex
[Re: an8sec70cuda]
#2422138
12/22/17 01:04 AM
12/22/17 01:04 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Mine is an E body w/ a hemi, but should be the same as B body in this situation. I use the carbon fiber CSR shield. Have to hammer the seam flat where the firewall meets the floorpan and have to cut the lugs off the trans case where the factory shift linkage bolts up. It's all snug, but works great. It saved my feet when my 727 exploded in 2008. I have 2.25" primary TTI headers and they fit fine. Ditto,my engine is also set back a few inches.Also use a PB shifter with no issues.
[Re: mercman1]
#2430927
01/08/18 06:50 AM
01/08/18 06:50 AM
tex013
Sydney,Australia
Finally got all my stuff today - converter from A1 Fitted it all up . Blanket fits a treat , from ext housing gasket to just up bell housing . Plenty of space on passenger side to header . Barely 1/4" - 1/2" clearance on driver side . I fitted aluminium heat shield to help out . I go have Dougs headers , 3 1/2" collectors . Testing tbis saturday so any isdues let you know
[Re: mercman1]
#2431181
01/08/18 06:37 PM
01/08/18 06:37 PM
tex013
Sydney,Australia
the shield I use is a waffle type , same as factory oe . Have used it to protect shift cable with great results .Will find out .
Tex
