Crank trigger for ATI Balancer with chevy front for pulleys #2429839
01/06/18 11:46 AM
01/06/18 11:46 AM
ohio
Rjmpro Offline OP
Rjmpro  Offline OP
ohio
I'm looking to put a crank trigger on BB mopar will this kit work with a chevy front bolt pattern ATI balancer It Has different alignment holes on the wheel? anyone done this with chevy front bolt pattern Balancer before
Chrysler Big Block Crank Trigger Kit
PART# 8636
https://www.msdperformance.com/products/crank_triggers/crank_trigger_kits/parts/8636
Re: Crank trigger for ATI Balancer with chevy front for pulleys [Re: Rjmpro] #2429869
01/06/18 12:47 PM
01/06/18 12:47 PM
Farmington Hills, Mich
Chuck@Best_Machine Offline
The Mopar crank trigger wheel will fit the 6 bolt Mopar pattern or the 3 bolt Chevy. The kit comes with the proper spacer rings to center it to the balancer hub
Re: Crank trigger for ATI Balancer with chevy front for pulleys [Re: Rjmpro] #2429875
01/06/18 01:09 PM
01/06/18 01:09 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
What is your opinion on the ATI balancer shell with the magnets in the shell? Has anyone used this method??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Crank trigger for ATI Balancer with chevy front for pulleys [Re: Rjmpro] #2429881
01/06/18 01:26 PM
01/06/18 01:26 PM
We use them all the time, they work great and make things easier when using after market pully systems for dry sumps and vac pumps
Re: Crank trigger for ATI Balancer with chevy front for pulleys [Re: Rjmpro] #2429913
01/06/18 02:05 PM
01/06/18 02:05 PM
hemi-itis Offline
hemi-itis  Offline
Thanks Chuck up
Re: Crank trigger for ATI Balancer with chevy front for pulleys [Re: Rjmpro] #2429937
01/06/18 02:25 PM
01/06/18 02:25 PM
AndyF Offline
AndyF  Offline
I make a shorter pickup bracket just for the ATI damper with magnets.
http://arengineering.com/home-page/crank-trigger/
Re: Crank trigger for ATI Balancer with chevy front for pulleys [Re: Rjmpro] #2429968
01/06/18 02:54 PM
01/06/18 02:54 PM
AndyF Offline
AndyF  Offline
I looked in my stash of spare parts and I think I have everything you need. I have a used 8 inch Chevy wheel, a Mopar bracket and a used MSD sensor. I'll sell you everything for $200 shipped. Just shoot me a PM if interested.
Re: Crank trigger for ATI Balancer with chevy front for pulleys [Re: Rjmpro] #2429978
01/06/18 03:04 PM
01/06/18 03:04 PM
With a wheel that big on the OD it could hit the bottom of a stock type water pump housing
Re: Crank trigger for ATI Balancer with chevy front for pulleys [Re: Rjmpro] #2429987
01/06/18 03:17 PM
01/06/18 03:17 PM
AndyF Offline
AndyF  Offline
I have a used Mopar trigger wheel if he would rather have the smaller Mopar one. Doesn't matter to me, I'll sell either one or both. I'm switching to EFI and don't really need the old MSD stuff anymore.
Re: Crank trigger for ATI Balancer with chevy front for pulleys [Re: hemi-itis] #2430223
01/06/18 10:46 PM
01/06/18 10:46 PM
Scatchamatoon
Saskabusa Offline
Saskabusa  Offline
Scatchamatoon
I use one, I like it.
Pricey
1974 Roadrunner
1967 Charger
Re: Crank trigger for ATI Balancer with chevy front for pulleys [Re: Rjmpro] #2430245
01/06/18 11:40 PM
01/06/18 11:40 PM
hemi-itis Offline
hemi-itis  Offline
Switching to a trigger is on my list of things to do.Is an MSD shell with magnets any better or worse than using a wheel? I have a SuperDamper but would need to buy a new shell that has magnets,so I could go either way......
Re: Crank trigger for ATI Balancer with chevy front for pulleys [Re: hemi-itis] #2430892
01/08/18 02:18 AM
01/08/18 02:18 AM
AB
E
Efidart Offline
Efidart  Offline
E
AB
After tuning many cars with a 36-1 and 60-2 wheel and MSD crank triggers.. I still run an MSD crank trigger.
Reason why- "Its supposed to be more accurate". Yes at idle a 36 or 60 tooth wheel will be with a large cam that doesn't idle nice and smooth. There are smaller timing errors (.1 degree vs upto .5 degrees at most on an MSD wheel) but under WOT I always see timing error on 36 and 60 tooth wheels vs 0% on a 4 magnet MSD crank trigger.
Is there any real world difference under power between a 36-1/60-2 and MSD crank trigger. NO.
On transient RPM changes you see more error on an MSD wheel but it is so little that it would not be picked up with a timing light. Under straight WOT acceleration I have observed zero timing error vs a higher tooth count wheel.
Advantage to a 36-1 wheel vs a 4 magenet, you can run wasted spark if COP/CNP and semi sequential still if your cam sensor fails.
Is this to say in the future the processing and ECU technology will be better and be able to take advantage of higher tooth wheels. Yes but for now and 99.9% of the projects out there it makes 0% difference.
TT Predator headed 572 7 Second Street Car.
Fastest Mopar Drag Week 2015
Fastest Mopar & Dodge Drag Week 2017
Pro Street Power Adder Champion Drag Week 2017
Re: Crank trigger for ATI Balancer with chevy front for pulleys [Re: Rjmpro] #2431030
01/08/18 01:44 PM
01/08/18 01:44 PM
hemi-itis Offline
hemi-itis  Offline
How are you able to see any timing variations at WOT acceleration? I have an MSD that can change RPM every 100 rpm and a map sensor that will take out programmed timing per pound of boost,but have no way of verifying what I have programmed work
Re: Crank trigger for ATI Balancer with chevy front for pulleys [Re: Rjmpro] #2431060
01/08/18 02:42 PM
01/08/18 02:42 PM
AB
E
Efidart Offline
Efidart  Offline
E
AB
The timing variation/error is logged by the ECU showing % of timing error.
Re: Crank trigger for ATI Balancer with chevy front for pulleys [Re: Rjmpro] #2431925
01/09/18 11:32 PM
01/09/18 11:32 PM
hemi-itis Offline
hemi-itis  Offline
Race Pak does not see that....
