Re: How long would you leave valve springs compressed? [Re: mickm] #2429174
01/04/18 09:27 PM
01/04/18 09:27 PM
AndyF Online content
AndyF  Online Content
How long would you leave a book sitting on a shelf? The valve springs in that engine are probably under no more load than the book shelves in your house or the kitchen table.
Re: How long would you leave valve springs compressed? [Re: mickm] #2434290
01/14/18 06:16 AM
01/14/18 06:16 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
I have been waiting for a theoretical engineer type to tell us that a spring sitting in a compressed state,,,valve open,,,,undergoes any more stress than operating at 1000's, millions of opens and closings over a period of time,,,,just wondering. Like a bolt torqued to say a 100 pounds for 10 years,,,will the bolt stretch any amount that after 10 years, would it would show any less torque than initial torque reading.
Re: How long would you leave valve springs compressed? [Re: mickm] #2434309
01/14/18 10:32 AM
01/14/18 10:32 AM
gregsdart Online content
gregsdart  Online Content
I believe Monte Smith said not to worry about leaving them compressed. It probably has more to do with the quality of spring material than whether they are compressed or not.
Re: How long would you leave valve springs compressed? [Re: mickm] #2434331
01/14/18 11:39 AM
01/14/18 11:39 AM
E
earlymopar Offline
earlymopar  Offline
E
A spring that is properly designed, correctly manufactured and in an application that is allows it to operate within design specs, can sit compressed indefinitely.
- EM
Re: How long would you leave valve springs compressed? [Re: mickm] #2434346
01/14/18 12:16 PM
01/14/18 12:16 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I was told it's the amount of cycles a spring goes through determines it's lifespan. work
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: How long would you leave valve springs compressed? [Re: hemi-itis] #2434361
01/14/18 12:44 PM
01/14/18 12:44 PM
moparx Offline
moparx  Offline
would spring compression, leaving valves open inviting rust on valves and seats, possibly causing valve sealing issues be somewhat a more important issue to be concerned about than loss of spring tension ?
beer
Re: How long would you leave valve springs compressed? [Re: moparx] #2434382
01/14/18 01:22 PM
01/14/18 01:22 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
I would be more concerned using a hydraulic cam and lifter setup in a motor that has intersecting valve centerlines. twocents
