Indy 572-13 heads (HELP)
#242803
03/04/09 11:51 AM
03/04/09 11:51 AM
Posts: 345 Arkansas
JoWeTu_6
Arkansas
Can someone measure the distance of the intake manifold bolt hole center line: from the block side of the head up to the bolt hole center line and then the distance from the valve cover side of the head down to the bolt hole center line, and let me know what they get, I may have a pair of bad heads. Jesus I hope not. Thanx: JoWeTu_6 I hope it's just a set of bad gaskets though Hears a new pic it shows what I need to know, I would realy apreciate any help on this
Re: Indy 572-13 heads (HELP)
[Re: JoWeTu_6]
#242805
03/04/09 06:27 PM
03/04/09 06:27 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
i have a old set of max wedge gaskets from a cnc ported 440-1 heads, if they are the same I will measure them up for you..looks like your not getting much response.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: JoWeTu_6]
#242807
03/04/09 08:11 PM
03/04/09 08:11 PM
What do you think is wrong with them, does your manifold not fit properly? or do you think they're excesively milled?
[Re: Moore & Moore]
#242812
03/05/09 02:37 PM
03/05/09 02:37 PM
Posts: 345 Arkansas
JoWeTu_6
Arkansas
That true im sure but 3/16 off that seems to be a bit much, or is that the norm with Indy products? Jowetu_6
[Re: JoWeTu_6]
#242813
03/05/09 02:50 PM
03/05/09 02:50 PM
Posts: 2,938 A shed in England
Tig
A shed in England
I can pull the intake off at the weekend and check then, if you can wait that long. Motor has to come apart for freshening / upgrades anyway.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: JoWeTu_6]
#242816
03/05/09 04:46 PM
03/05/09 04:46 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I have a new set in the shop for a customer as well, and also all the different Indy gaskets, so I'll take a look later and hopefully report back if still needed.
RIP Monte Smith
[Re: JoWeTu_6]
#242819
03/05/09 05:46 PM
03/05/09 05:46 PM
440-1 heads take gasket part number 440-G1-221 opening size is (1.340"x2.650") 572-13&600-13 gasket part number 440-G1-222 opening size (1.475"x2.70") also the exhaust are not the same 440-1 takes gasket part number 440-G1-221 opening size is (1.890"x1.650") 572-13&600-13 take gasket part number 440-G1-222 opening size is (2.200"x1.820")
[Re: JoWeTu_6]
#242821
03/05/09 07:16 PM
03/05/09 07:16 PM
Posts: 1,200 UK
602heavy
UK
Do the holes in intake line up with holes in head? , i got a set of intake gaskets that i had to open up on the bolt holes , seems i was sent the wrong gaskets , have now got the correct one's from Indy , they line up perfectly. If the gaskets are cut @ a 45* angle on the ends then they are correct , if they are cut square then they are for a different application.
